Author Topic: Raid mode and Win 8 features  (Read 8503 times)
xmadTopic starter
  • Salisbury MD
« on: 20-November-12, 21:06:29 »
Once you enable raid mode and win 8 features in bios, you will notice you no longer see the raid controller bios. The raid controller is now operated inside of uefi bios. You are able to create and handle the raid arrays from there. This is found in uefi bios > Settings >  advanced
The screen shots below were taken on a z77a-gd80 as a reference.
Mainboard: X79A-GD65 (8D)
CPU: I7-3930K
Setting: 2400 CL:10
SSD: Corsair GS 256GB
Corsair Link
Cooling: Corsair H100I
peddler
Re: Raid mode and Win 8 features
« Reply #1 on: 14-July-13, 09:47:45 »
whats that MSI software your using ?
xmadTopic starter
  • Salisbury MD
« Reply #2 on: 18-July-13, 15:28:11 »
That is a screen shot of the bios from my old z77a-gd80.
CPU: I7-3930K
Setting: 2400 CL:10
Corsair Link
Kusky
  • CORPORAL
« Reply #3 on: 17-January-16, 11:20:54 »
Hi. I've done the same thing as you, but my problem is that the intel rapid storage doesn't recognize the raid 0 that I've made, so I can't actually use it at all. And if I try to restart the computer in "Raid mode", it doesn't turn on so I have to change it back to UEFI. I don't know if you have any ideas about what I can do to make it work.
Thank you in advance
bebeandy87
« Reply #4 on: 23-March-16, 18:27:53 »
I have tried this advice,may be I did wrong steps ,the problem still there.
vito0821
« Reply #5 on: 17-May-16, 10:01:19 »
useful post
maxjordan095
    • https://www.customersupportphonenumber.co/hp-printer-support
« Reply #6 on: 10-July-19, 02:56:59 »
very good news for windows users.
l.r.gardner
  • STAFF SERGEANT
« Reply #7 on: 17-October-19, 16:28:31 »
In 2019 there is zero reason to use your built in motherboard RAID controller. Maybe if you had an HEDT system with the pci express connectivity to actually get a benefit of being in striped mode on nvme SSD's. It's just a bad idea all around.
Ryzen 5 3600@stock
MSI B450-A Pro Bios AC.1
16GB 2x8 Crucial Ballistix Sport LT 3200@1.35-3733
ASUS ROG STRIX-RX480-O8G-GAMING
Intel 660p 1TB NVME
WD Blue WD20EZRZ 2TB
Corsair CX850M PSU
juliluli80
« Reply #8 on: 03-December-19, 04:51:10 »
whar that MSI software your useing?
it is useful post thanks
