Author Topic: ZH77A-G43 JPWR2 connector  (Read 1758 times)
xs11eTopic starter
« on: 29-November-12, 20:05:03 »
My power supply has only a 4 pin connector for this socket, other motherboards will work with a 4 pin connector plugged into pins 1, 2, 3 and 4 but I can't find any information about that in the manual, FAQS or here in the forums.
Anyone know?  I'd hate to have to buy a new power supply if I don't have to.
PS, please don't ask about system configuration, the board is in the box, uninstalled.  Eventually it *PROBABLY* will have an i7-2700K installed with 8GB of memory, 2 SATA optical drives and 2 SATA HDs.  I'll probably use the on-board video for now.
  • 微星科技
« Reply #1 on: 29-November-12, 21:29:52 »
What psu model do you have?
MSI Radeon RX Vega 64 WAVE 8G
Corsair HX1200i • +12V: 100A • +3.3V: 30A • +5V: 30A
Windows 10 Pro
Cooler Master Masterbox 5 MSI Gaming Edition
xs11eTopic starter
« Reply #2 on: 01-December-12, 01:05:33 »
No idea, it's running my current PC and I don't want to take it out until I cannibalize it to build the new one.
It's 460 Watts and whatever HP stuck into their Pavilion Elite e9180t CTO.  I can see by looking at the MB on HP's site that the ATX CPU power connector is 4 pin.
I did get an answer from Tech Support that I can use the 4 pin plug in the 8 pin socket, I'm guessing it should be in pins 1, 2, 5 and 6 which are the left most pins, I suppose if I use pins 3, 4, 7 and 8 it wouldn't make any difference?
I also see I can get an adaptor but my understanding is that they don't accomplish anything much?
  • 微星科技
« Reply #3 on: 01-December-12, 01:09:16 »
The psu might be too weak for a modern setup but in general board should post with just 4pins.
Windows 10 Pro
Froggy Gremlin
  • Master Air OC'er
« Reply #4 on: 01-December-12, 02:03:58 »
How old is that PSU? They degrade over time. It may be unwise to use it in a new build. PSU is not a component to take lightly as it is the 'heart' of the system. Recommend a quality +12V single rail model of adequate amps.
IXOYE
