Author Topic: Z77A-G43 BIOS Error Codes  (Read 1186 times)
DaveOliver
  • Neo
« on: 10-December-12, 09:51:37 »
System has been working great for months, Running Windows 8.
Today turned on Hyper V and rebooted.
Error Code 99 followed by B4, 92 and then A2 before booting normally.
Anyone know how to remedy this?
badboy2k
  • Online Online
Re: Z77A-G43 BIOS Error Codes
« Reply #1 on: 10-December-12, 10:16:27 »
all of those arn't error codes there normal post codes!
99 = Super IO Initialization
B4 = USB hot plug
92 = PCI Bus initialization is started
A2 = IDE Detect
are you by any chance using an SSD? if so see if there is a new firmware update for it and see if the problem if your having a slow boot is resolved!
Cooler: corsair H100 cooler
DaveOliver
  • Neo
« Reply #2 on: 11-December-12, 18:32:04 »
Thanks for the response and information
No SSD but I will try removing peripherals to see what is slowing the boot process.
The machine is only rebooted when necessary, so not a major issue but one I would like to resolve.
99 = Super IO Initialization is the slow responding post the others flash up very quickly and the machine boots  normally.
Many Thanks again.
Dave
badboy2k
  • Online Online
« Reply #3 on: 11-December-12, 18:48:25 »
ok if its hanging at super Super IO Initialization stage with your post code just after the hang have a look at the USB 2.0 Componants by first disconnecting the front pannel USB header cable and/or card reader if you have one on your case then if that has no effect pull one USB device at a time like mouse-keyboard-printer-USB hub or anything else like that one by one till it posts quick as it seems they are the most common causes!
good luck and report back if it has any effect or not!
