Author Topic: Hp USB Format Tool & Win 98 System Files  (Read 45009 times)
xmadTopic starter
  • Salisbury MD
I have attached the HP USB Format Tool & win98boot files for use when necessary to create a bootable usb stick.
The Win98boot files are the required DOS system files. To create the stick simply follow the steps shown below:
Mainboard: X79A-GD65 (8D)
CPU: I7-3930K
Setting: 2400 CL:10
SSD: Corsair GS 256GB
Corsair Link
Cooling: Corsair H100I
Froggy Gremlin
  • Master Air OC'er
Re: Hp USB Format Tool & Win 98 System Files
« Reply #1 on: 07-January-13, 23:15:36 »
Not that it may possibly matter, but are the Win98 boot files linked the basic 98 or 98SE files? Not sure if one has any benefit over the other. Thanks for posting the thread.
IXOYE
xmadTopic starter
  • Salisbury MD
« Reply #2 on: 08-January-13, 11:34:07 »
Doesn't matter this is just basic 98, and it is just the boot files.
CPU: I7-3930K
Setting: 2400 CL:10
Corsair Link
Stu
  • Birmingham, UK
    • StuOnline.co.uk
« Reply #3 on: 08-January-13, 13:28:58 »
MSI provide Unetbootin to make bootable USB disks, and include a FreeDOS floppy disk image:
http://www.msi.com/service/download/nbdriver-17247.html
I used this to make a bootable USB stick to flash the EPF firmware on my Windpad 110W, very simple and easy to use.
delacruzpaolo19
  • SERGEANT
« Reply #4 on: 06-August-13, 01:30:48 »
Hi Xmad I tryed using the msi flash tool to update my z77 mpower bois to no avail,
so I tryed formatting my thumb drive using hp usb disk storage format tool and
and created a bootable windows98, after that I then used msi usb flash tool again to
process the latest bios archieve file that I downloaded directly, after that I tryed booting
my usb again and followed the instructions and it successfully updated my bios,
I just wanted to know if my method is safe?
xmadTopic starter
  • Salisbury MD
« Reply #5 on: 07-August-13, 21:16:10 »
The forum tool will only work on z87 boards with mode 2 and point the tool at just the extracted bios file.
The other option is M-flash w/ ME although M-flash is the best flash program in the world.
CPU: I7-3930K
Setting: 2400 CL:10
Corsair Link
SMOK3Y
  • CORPORAL
« Reply #6 on: 10-August-13, 15:03:18 »
will the windows98 work on Z87 boards xmad? also tbh what the hell do I do with all those files in w98?
copperred
« Reply #7 on: 02-October-13, 21:48:43 »
I don't see a mode 2 option when I run the tool. I have a z87-g45 that's not working and so need to flash its BIOS and am using an MSI notebook to try to get the stick to flash, but see no mode 2 option :(. What am I doing wrong?
xmadTopic starter
  • Salisbury MD
« Reply #8 on: 17-October-13, 23:21:04 »
The latest bios posted here: >>BIOSes<<
Can be flashed via Mode 1, I didn't however update the older ones.
When you run the tool in windows, you will select the first option and point it at the compressed archive.
CPU: I7-3930K
Setting: 2400 CL:10
Corsair Link
neoroy
  • FIRST LIEUTENANT
« Reply #9 on: 22-October-13, 11:02:07 »
It just files needed for booting with USB FD via HP USB Format Tool, you can put it in anywhere in windows. But first you need to create bootable USB FD and targeting to Win98 folder.
I think this tool will also works in Z87 because it's universal basic tool, I guess so.
Intel Xeon E5-2623 V3 @3.3GHz
MSI X99A SLI Krait Edition
GALAX GTX980Ti GOC LN2 @1500MHz stock volt
Gskill Ripjaws V 4x4G 2400MHz DDR4
Pioneer SSD APS-SL3N 240GB
Seagate HDD 1TB 7200rpm SATA3
Seagate HDD 500GB 7200rpm SATA3
DELL U2713HMT
CoolerMaster SilentPro M2 1000W Silver
Cooler Master Hyper 212X Turbo
Razer Mamba TE Chroma
Razer Goliathus Extended
SAMSUNG Bluray Combo SH-B123L
Windows 10 Pro 64bit
numaru7
« Reply #10 on: 15-December-13, 02:29:07 »
i used the tool and i clicked to make a dos startup disk, pointing to the files that i dearchived from win98boot, and it takes a while to complete... and afterwards.. there are no files on the stick. not even hidden ones.
  • T9246ED
  • Administrator
« Reply #11 on: 15-December-13, 06:24:14 »
they are system files along hidden one, the files are there, but you have to click to show system files too if you want to see them for some reason
numaru7
« Reply #12 on: 15-December-13, 07:05:22 »
true, 3 system files: command.com , io.sys and msdos.sys
FATAL1TY
  • CORPORAL
« Reply #13 on: 29-December-13, 19:11:36 »
The version of first post is 2.1.8
The latest version is 2.2.3
better to use the last one? or the older have "something special"?
  • T9246ED
  • Administrator
« Reply #14 on: 30-December-13, 04:50:24 »
both will works fine, use which one you want
neoroy
  • FIRST LIEUTENANT
« Reply #15 on: 15-January-14, 10:16:39 »
I use 2.2.3 :)
And had no problem also with 2.1.8 long time ago.
DELL U2713HMT
DrKukary
  • CORPORAL
« Reply #16 on: 25-March-14, 01:25:26 »
I think the old versions had issues with some antivirus programs.
neoroy
  • FIRST LIEUTENANT
« Reply #17 on: 26-June-14, 12:29:27 »
Perhaps you are right, better disable anti virus while doing this  :-))
DELL U2713HMT
emilmlassen
« Reply #18 on: 19-September-15, 07:28:53 »
I kept getting an error booting from the boot disk saying "Load Error: No DPMI Memory".
So what I did instead was download Rufus 2.3 and create a FreeDOS disk instead.
Just flashed my GPU and everything worked fine, just in case anyone has a similar issue.
golovaraoul
« Reply #19 on: 23-October-17, 07:43:04 »
The image is offline. Could you please reupload it or provide another image?
Thank you very much!
GolovaRaoul
  • 微星科技
« Reply #20 on: 23-October-17, 10:00:53 »
it is done
AMD Ryzen 9 3900X
Windows 10 Pro
svandrei
« Reply #21 on: 27-October-17, 14:37:03 »
There are no attached files in the first post....
Or am I missing something?
  • 微星科技
« Reply #22 on: 28-October-17, 05:46:24 »
Yes, corrected
AMD Ryzen 9 3900X
Windows 10 Pro
da_jago
« Reply #23 on: 11-February-20, 08:10:39 »
No image for intructions..
  • 微星科技
« Reply #24 on: 11-February-20, 09:00:43 »
Yes... as this is 7 years old.
:floblock:
AMD Ryzen 9 3900X
Windows 10 Pro
