Author Topic: Setting my BIOS to AHCI mode prior to a clean win7 install, failed  (Read 1900 times)
slicey69Topic starter
  • CORPORAL
My hard drive is an old Western Digital, 74GB Raptor, which I believe supports NCQ.  Shouldn't this have worked on my A75-G35 board?  The PC was seeing my hard drive during set up, but I was being told that windows couldn't be installed on the drive.  It's the ONLY storage device connected to the mobo, at the time of install.  I had to set BIOS to IDE mode in order for the install to proceed.  What gives?
MSI A75-35 Motherboard
A8-3850 @stock speed, with stock air cooling
2*2GB OF GSkill F3-12800CL9-2GBNQ @stock speed
XFX 9870 video card
74GB Western Digital Raptor
Stu
  • Birmingham, UK
    • StuOnline.co.uk
« Reply #1 on: 10-February-13, 15:33:25 »
You mean that Windows sees the drive as an option you can select during Windows Setup?
Are there currently any partitions on this drive? If so, delete them, and then try again.
  • CORPORAL
« Reply #2 on: 11-February-13, 03:05:51 »
You mean that Windows sees the drive as an option you can select during Windows Setup?   Yes
I seem to recall, that there was a 15GB partition, but in all the years I've installed Windows, I've never partitioned a drive.
XFX 9870 video card
murf3347
« Reply #3 on: 15-February-13, 18:21:38 »
you should set it to ide if installing another os, after the install of the new system set the registry first to AHCI then reboot and set the bios to AHCI.
hope the info helps  :biggthumbsup:
xmad
  • Salisbury MD
« Reply #4 on: 15-February-13, 18:39:38 »
You can use diskpart from DOS. This is off the top of my head, so if you have any trouble let me know and I'll look it up.
Boot to DOS
COMMANDS
DISKPART [ENTER]
LIST DISK [ENTER]
SELECT DISK (# OF THE DISK YOU WANT TO FIX) [ENTER]
LIST PARTITION [ENTER]
SELECT PARTITION (WHICHEVER ONE LISTED YOU WANT TO DELETE) [ENTER]
DELETE PARTITION [NOERR] [OVERRIDE] [ENTER]
SELECT DISK (#OF THE DISK YOU WANT TO FIX) [ENTER]
CLEAN [ENTER]
LIST PARITION [ENTER]
Make sure no partitions are listed.
Mainboard: X79A-GD65 (8D)
CPU: I7-3930K
Setting: 2400 CL:10
SSD: Corsair GS 256GB
Corsair Link
Cooling: Corsair H100I
Principle
  • STAFF SERGEANT
« Reply #5 on: 16-February-13, 09:30:47 »
You want AHCI enabled before loading windows.  A lot of them wont work when trying to change it later, even with the registry fixes.  Windows install should have a partition delete function if you can see the drive.  And then it sets up the partition.  The MBR or something may be set up to say its an IDE drive, even if its AHCI compliant, until you delete the first partition.
MSI 890GXM-G65 (uATX) in Apex Supercase TX-381-C micro tower with 120x38mm Sunon front intake fan
-AMD Vishera FX-6300 @ 4Ghz base, 4.4-4.6GHz turbo, Cooler Master Geminii with dual Evercool AL12025 fans
-G.Skill Ripjaw 8GBx2 CL9 DDR3-2133 RAM running CL7-8-8-23-30-1T 1600@1.6V with 17 GB/s bandwidth
-Gigabyte Windforce AMD Radeon HD7850 @1GHz with 1GB GDDR5 VRAM @ 1.3GHz
-Seasonic X650 Gold PSU & Plextor M5S 128GB SSD
-CPU Vcore 1.4125 VID 1.45V max, CPU-NB voltage 1.3V, 55W Sleep, 62W idle, 105W utilization, 230W max gaming power consumption
-2013 Future Update: AMD HD8870 xFire
-2014 Future Update: 8-core Steamroller FX CPU
  • CORPORAL
« Reply #6 on: 18-February-13, 12:30:12 »
Yup, AHCI was enabled in BIOS prior to install attempt.  Got frustrated and set to IDE mode to install.
thanks, though
XFX 9870 video card
