Author Topic: MSI 7950 Twin Frozr 3 fan problem  (Read 2420 times)
Taters82Topic starter
« on: 23-February-13, 21:05:39 »
Hi everybody,
I just received this card today and i was initially impressed, that was until the fans kicked in.
It turns out that the fans will immediately jump to 100% anywhere between 55c - 60c, even when set to manual control. I've setup a profile in Afterburner and it hasn't helped. If i set the fan speed to 50% either in CCC or Afterburner, the fans will still override this and jump to 100% at 55c - 60c. I dunno what could be causing this issue. I've tried several different drivers, using 13.2 at the minute. I have a pretty fresh install of windows, but i've yet to test this in Linux (doing it as i speak).
Would it be possible that my psu is causing this? I have a Corsair HX850.
Thanks!
Edit: Oops, just realized others are having this problem here https://forum-en.msi.com/index.php?topic=166687.0.
« Reply #1 on: 23-February-13, 23:04:19 »
Oh and here's my bios and serial...
Serial - 602-V276-18SB1211085929
Current BIOS - http://www.mediafire.com/?vnrjp91780w8ifb
I know there's a thread on this already, but i've tried everything i can except flashing a bios. And i'm pretty sure the retailer will nag at me to do this anyway before they'll RMA  :)
Thanks!
Edit: I just tried stress testing in Linux and had the same issue, so i reckon that rules out any software/driver issues.
  • T9246ED, Бивша комета
  • Administrator
« Reply #2 on: 24-February-13, 12:21:00 »
here is latest version
lash it by booting from USB key, then execute:
atiflash -f -p 0 xxxx.BIN [ENTER]
where xxxx.BIN will be your vbios file
« Reply #3 on: 24-February-13, 12:45:42 »
Thanks, though i assume the bios needs the file extension changed from 1A1 to Bin?
  • Administrator
« Reply #4 on: 24-February-13, 12:47:56 »
flasher need .bin, you have to rename vbios image ext to bin
« Reply #5 on: 24-February-13, 12:57:21 »
Yeah just did it anyway...
Same problem, fan speed just runs away at 58 degrees.
Is it worth waiting for a bios fix or just RMA?
  • Administrator
« Reply #6 on: 24-February-13, 13:13:11 »
im not sure what's causing the problem
try different vga drivers, msi's vga drivers for your card [from supplied cd and from msi web],
latest one from amd site
« Reply #7 on: 24-February-13, 14:07:08 »
Just tried the MSI drivers, and still having the same issue.
Since it happens in Linux too, it would lead me to think it's not a driver issue anyway, but either bios or hardware.
Would it be worth trying a 7970 bios on it?
  • Administrator
« Reply #8 on: 24-February-13, 14:12:30 »
aha
ask msi then >>How to contact MSI.<<
