Author Topic: ZH77A G43 usb3 write slow  (Read 2050 times)
robino62Topic starter
« on: 21-March-13, 10:03:20 »
o.s win7 home premium sp1
the stick is verbatim store and go 16 gb and is correctly recognized
i have tested with Crystal Disk
read speed is 80 mb/sec
but write speed is only 11mb/sec
the bios is update to 1.7 version
xmad
  • Salisbury MD
« Reply #1 on: 21-March-13, 17:13:38 »
Have you installed / re-installed all of the most recent drivers from here: http://www.msi.com/product/mb/ZH77A-G43.html#/?div=Driver&os=Win7%2064
Mainboard: X79A-GD65 (8D)
CPU: I7-3930K
Setting: 2400 CL:10
SSD: Corsair GS 256GB
Corsair Link
Cooling: Corsair H100I
« Reply #2 on: 22-March-13, 08:31:27 »
i have reinstalled only Intel USB3.0 Driver
Bernhard
  • GENERAL
« Reply #3 on: 22-March-13, 08:39:26 »
Did you not install all the drivers for the MB ?  If not, you should.
Then you should also check with another USB3 device or test that USB3 device on another machine with USB3 to check if there is a difference.
1.B350F Gaming; R5-1600; Crucial MX300 275GB, Ballistix Sport LT BLS16G4D240FSC 2X8gb; Sapphire RX580 Pulse 8gb; Seasonic750W; Win10-64; LG DVD
2.FUJITSU LIFEBOOK S751 QM67;i5-2520M;2 X 4GB 1333Crucial CT256 MX100; Win10-64; Orico Dual Bay USB3 Dock
"veni vedi doctus"
MSI 미친
« Reply #4 on: 22-March-13, 11:25:43 »
i have tested before of this , pen drive dataTraveler 111 16gb but with the same result, i have now also installed the new chipset driver and  Intel Rapid Storage Technology Driver for 7x series , but nothing is changed
CrystalDiskMark 3.0.2 x64 (C) 2007-2013 hiyohiyo
                           Crystal Dew World : http://crystalmark.info/
* MB/s = 1,000,000 byte/s [SATA/300 = 300,000,000 byte/s]
           Sequential Read :    80.598 MB/s
          Sequential Write :    11.163 MB/s
  Test : 1000 MB [G: 0.0% (0.0/14.4 GB)] (x1)
  Date : 2013/03/22 11:44:39
    OS : Windows 7 Home Premium Edition SP1 [6.1 Build 7601] (x64)
Bernhard
  • GENERAL
« Reply #5 on: 22-March-13, 14:53:42 »
I will urge you to test it again on another machine with USB3 to see if it performs any different. Same test you used here.
You may want to inspect these tests and compare.
http://www.whoratesit.com/Verbatim-Store-n-Go-V3-USB-30-16GB/Rating/1347
Depending on the file sizes used, even Verbatim only claims 60/12
The ATTO results for the Store n Go are broadly in line with the CrystalDiskMark scores and at 72/46 MB/s come in at reasonable levels especially considering Verbatim only claims read/write speeds of 60/12 MB/s.
"veni vedi doctus"
MSI 미친
RemusM
  • Memory Expert
  • LIEUTENANT COLONEL
    • Necromanthus
« Reply #6 on: 22-March-13, 15:40:53 »
That's all you can get from that stick.
http://www.pcmag.com/article2/0,2817,2405392,00.asp
"The Verbatim Store 'n' Go V3 offered up passable performance in our timed data transfer tests,
clocking in with write speeds of 10.7 MBps and read speeds topping out at 79.2 MBps using USB 3.0."
 :beerchug:
Mainboard: HC85
Processor: Zilog Z80 3.5MHz
System RAM: 48KB
PSU: 5V/3A
OS: BASIC Spectrum Sinclair
note: NO overclocking!
Rube
  • STAFF SERGEANT
« Reply #7 on: 23-March-13, 08:34:39 »
you need to update Intel USB 3.0 eXtensible host controller and Intel USB 3.0 Root Hub
