Author Topic: MS-7175 Windows XP (32 bit) drivers  (Read 8903 times)
hh_shanTopic starter
« on: 27-March-13, 04:54:20 »
I was wondering where can i get the motherboard drivers for MS-7175 1A. I had to put windows XP recently again and I cant seem to find the drivers anywhere online.
Help would be much appreciated :)
Thank you very much :)
HenryW
« Reply #1 on: 27-March-13, 07:06:55 »
 If your MB is RC410M then you can find what you are looking for here, click the OS arrow button and select your specific OS from the menu for drivers you need:
 http://www.msi.com/product/mb/RC410M-F--L--FI--LA.html#/?div=Driver&os=Win7%2064
Z77A-GD65/BIOS 10.5, i7 2700K
W 7 Home Premium x64/SP1
Corsair TX650W
Lite-On CD/DVD combo burner
MSI 560 HAWK, Drv. 368.82
« Reply #2 on: 27-March-13, 07:15:09 »
Thank you very much for the reply! :)
May i know wht is MB and how to check if its RC410M?
droid-I
  • FIRST LIEUTENANT
« Reply #3 on: 27-March-13, 12:46:59 »
MB = motherboard. Use a program like CPU-Z or PC Wizard and it will tell you details of your motherboard and system.
HenryW
« Reply #4 on: 27-March-13, 21:01:30 »
 Sorry, I got the wrong MB. I made a typo in my search and ended up with MS-7173 by mistake. I'm looking for the 7175 now and will be back.
 However there should be the name of MB either between the PCI slots as shown here for K8N Neo4 H or next to the memory slots as in this picture of the MS-7173.
Corsair TX650W
HenryW
« Reply #5 on: 28-March-13, 00:38:49 »
 I'm at a loss, I can't find any useful information for MS-7175 MB on the internet I's not often that happens but this one seems to have led me to a dead end. You can try contacting MSI support directly and see if they can provide anything for you.
 That must be a MB made specially for PC manufacturer such as HP, Gateway, Medion or some other one.
 That model number leads nowhere, if it had a model name as shown in my pictures I might be able to find something.
Corsair TX650W
« Reply #6 on: 28-March-13, 05:07:07 »
ohh..okeyyy..thank you for the valuable information :) very much appreciate your effort :) yeaa..il try doing that :) thank you again :)
droid-I
  • FIRST LIEUTENANT
« Reply #7 on: 28-March-13, 20:52:09 »
MS-7175 = Pegasus-36S, maybe used in Samsung desktops? Socket 775 board, intel 915G chipset.
http://www.google.fi/url?sa=i&rct=j&q=&esrc=s&source=images&cd=&cad=rja&docid=Q8hYvKhGhrQ0hM&tbnid=dQVS7-BESWuPxM:&ved=0CAUQjRw&url=http%3A%2F%2Felektrotanya.com%2Fmsi_ms-7175_rev_0a_sch.pdf%2Fdownload.html&ei=2ZxUUdCKMYuL4gSe54HAAg&bvm=bv.44442042,d.Yms&psig=AFQjCNGYsL9kss7fyZm5W2mkcRzOV08uFg&ust=1364578591214282
Motherboard chipset driver can be found at intel website.
Motherboard on-board VGA (915G), driver from intel.
Audio driver, look for ALC880 from realtek.
LAN, look it up at intel website.
Firewire, chip by VIA, VT6307, think windows stock driver will work.
http://ark.intel.com/products/codename/2052/Grantsdale
Hope this helps.
HenryW
« Reply #8 on: 28-March-13, 22:27:16 »
 Thanks go_for, that helped some but still can't do much else for him. With this little bit we could come up with he's pretty much at the mercy of whatever he can find at chip manufacturers websites for drivers. If MB is from Samsung PC as far as I know it's something that was only sold in Korea.
 Is this the MB you have?
 Sorry I couldn't help more but I'm done here, bye. :wave:
Corsair TX650W
« Reply #9 on: 29-March-13, 03:45:41 »
thank you go_for and XFM... yes it is a samsung MB and yeaa..it is from Korea.and yep..that is exactly what it looks like ^_^ well anyway..thank you for you help :)
HenryW
« Reply #10 on: 29-March-13, 04:22:35 »
 Good luck rounding up the right drivers. :biggthumbsup:
 As far as Intel chipsets go you should be able to simply download Intel INF driver package and system will install drivers automatically for what ever chipsets the MB has. The INF package has just about any Intel chipset drivers you can think of in it so you don't need to go rummaging around trying to find a particular driver on it's own. Like go_for said the ALC880 audio can be had from Realtek website no problem. Should be no problem to get the rest of the drivers the same way, just takes a bit of time on your end.
Corsair TX650W
