Author Topic: Unboxing MSI X79A-GD45 Plus  (Read 2481 times)
gzhilTopic starter
  • Hardware Reviewer
  • SECOND LIEUTENANT
« on: 02-April-13, 21:10:45 »
Glad to be back hehehe  ;D
The X79A-GD45 Plus is quite unique because of the new Black and Grey color theme that MSI applied on the board and also for its new chipset heatsink design. In terms of new features, the board’s audio software is improved. From the previous THX audio software it is now updated to Sound Blaster Cinema, giving the listener better audio experience.
The packaging is same as last year’s. The Military Class III logo in front indicates “5 Stars” meaning that the board is equipped with reliable and sturdy components such as Hi-C Capacitors, Solid Capacitors, Super Ferrite Choke and lastly DrMos II (Driver Mosfet).
Turning the board around, you will find more info about the board’s other features – Click Bios II, Instant OC, Super-Charger and OC Genie II.
Below are the bundles:
• Mainboard Manual and Quick Installation Guide
• Software & Application Manual
• Short Overclocking Guide
• Certificate of Quality and Stability (Military Class III Components)
• Driver & Utility Disc
• M-Connector
• 3x SATA 6GB/s Cable
• SLI Bridge
• I/O Back Plate
Check out the board. I’m glad that MSI released a motherboard with this kind of color scheme. The layout is clean and sleek looking.
Basic Specification of the Board:
•CPU: Supports 2nd Generation Intel® Core i7 processors in LGA2011 package.
•Chipset: X79
•Memory:  Supports eight unbuffered DIMM of 1.5 Volt DDR3 1066/1333/1600/1800*/2133*/2400*   (*OC) DRAM, 128GB Max
• 3 PCI Express gen3 x16 slots / 2 PCI Express gen2 x16 slots / 1 PCI Express 2.0 x1 slot
• Supports four SATAII ports (SATA3~6) by X79 / Supports two SATAIII ports (SATA1~2) by X79
• 3x USB 3.0 / 8x USB 2.0
Closer look on the upper area of the board. 9 Power Phase for the CPU Socket and I think 4 for the DIMM slots.
Your choice:  SLI, Crossfire or 3-Way SLI  (16,16,8x Speed) .  Below the Slots you will find the Easy Buttons – OC Genie and Power Button. Headers are also present like USB 2.0/ USB3.0 etc…
Starting on the left, we have the 4 pin Molex connector to provide additional power for a multi-graphic card setup. Then 4x SATA 3GB/s Connector and the last two are SATA 6GB/s Connector.
By the way, there is also a hard switch for Multi-Bios Selection in between of the SATA ports and the 24Pin Power Connector for the motherboard.
• 1x PS/2 Keyboard port
• 1x PS/2 Mouse port
• 1x Clear CMOS button
• 1x Coaxial SPDIF-out port
• 1x Optical SPDIF-out port
• 1x RJ45 LAN Jack
• 6x USB 2.0 ports
• 2x USB 3.0 ports
• 1x 6 in 1 audio jack
That’s it for the unboxing  :) Thanks…
MSI XPower
Intel Xeon
MSI N580GTX Lightning
OCZ Solid 3 60GB SSD 6GB/s
Seagate 500GB 3GB/s
A4Tech X7 G700 Keyboard
A4Tech X5-70MD
Creative 5.1 Speakers
Hanns-G HG281 28" LCD Monitor
neoroy
  • FIRST LIEUTENANT
Re: Unboxing MSI X79A-GD45 Plus
« Reply #1 on: 08-April-13, 11:12:12 »
Nice pics Gzhil :) Hmm there are 9 powerphase for CPU right? Plus 2 powerphase for memory and 1 powerphase for CPU IO/VTT, am I right? or ... ?
No V-Check point.
Intel Xeon E5-2623 V3 @3.3GHz
MSI X99A SLI Krait Edition
GALAX GTX980Ti GOC LN2 @1500MHz stock volt
Gskill Ripjaws V 4x4G 2400MHz DDR4
Pioneer SSD APS-SL3N 240GB
Seagate HDD 1TB 7200rpm SATA3
Seagate HDD 500GB 7200rpm SATA3
DELL U2713HMT
CoolerMaster SilentPro M2 1000W Silver
Cooler Master Hyper 212X Turbo
Razer Mamba TE Chroma
Razer Goliathus Extended
SAMSUNG Bluray Combo SH-B123L
Windows 10 Pro 64bit
