Author Topic: msi X79-GD45 (8D) CPU killer  (Read 2149 times)
viper
« on: 25-April-13, 13:50:35 »
my x79-gd46 (8d) died was replaced with second board one of the boards that died killed the cpu.Has anyone had problems with board or bios 12.1 killing cpu thx
asdf1221
  • SECOND LIEUTENANT
« Reply #1 on: 25-April-13, 14:57:57 »
  • Best Answer
  • It was probably some overclocking and the "custom watercooling" of yours that killed that CPU and the first board. You don't have to make two threads to let the world know.
    If no-one replied in your first thread (https://forum-en.msi.com/index.php?topic=168373) it means that it's not a known fault of the board.
    viper
    « Reply #2 on: 25-April-13, 15:07:32 »
    sorry no water leaks.and no overclocking in place at all.thx for the input :)
    « Last Edit: 25-April-13, 22:14:27 by viper »
    Froggy Gremlin
    • Master Air OC'er
    « Reply #3 on: 25-April-13, 20:24:55 »
  • Best Answer
  • If the 3930k is a C1 stepping, I had one that just up and refused to initialize when it was moved from an X79A-GD65(8D) to a Big Bang XPower II. Intel replaced the CPU under warranty as it was determined to be faulty.
    IXOYE
    viper
    « Reply #4 on: 26-April-13, 03:45:06 »
    thanks heaps froggy my problem is the cpu is c2 the replacement one is a c2 as well.I have a replacement board in at moment it,s the 3rd board.i would like to move to windows 8.1 when released but am concerned about  this board as well.I,m not sure if this board, like the others can be trusted after all $595.00 on cpu is to much to keep having a unreliable board kill the cpu  :) thanks again for responding  :biggthumbsup:
    ps bios on this board is 10.7
    « Last Edit: 26-April-13, 10:47:35 by viper »
    viper
    « Reply #5 on: 29-April-13, 15:25:59 »
    hi froggy just updating you on my msi x79-gd45 (8d) the bad news is my feeling was right about that board number 3 died yesterday reseller asked did i want the same board lol i said not after 3 boards dying the same way.would like to people for taking take to respond to post and tried help out so thx people.
    RemusM
    • Memory Expert
    • LIEUTENANT COLONEL
      • Necromanthus
    « Reply #6 on: 29-April-13, 15:52:21 »
  • Best Answer
  • the bad news is my feeling was right about that board number 3 died yesterday reseller asked did i want the same board lol i said not after 3 boards dying the same way.
    You have a damaged component (PSU/graphics card/sound card/ ...) and you will continue to "kill" mainboards and processors.
    And that reseller is not smart at all: your warranty should be lost after the 2nd bricked board.
    I bet you are an  :oc:
    Mainboard: HC85
    Processor: Zilog Z80 3.5MHz
    System RAM: 48KB
    PSU: 5V/3A
    OS: BASIC Spectrum Sinclair
    note: NO overclocking!
    viper
    « Reply #7 on: 30-April-13, 13:06:19 »
    hi RemusM did you read earlier posts,no overcolcoking in place at all.All other parts was placed on my fx8350 990fx with gpu,s mem,hd,s everything else checked out perfect.thx anyway but i no longer have that model board anymore.Reseller said to leave them alone and replace with better board and differant brand.:)
    « Last Edit: 30-April-13, 21:12:39 by viper »
    RemusM
    • Memory Expert
      • Necromanthus
    « Reply #8 on: 30-April-13, 14:50:30 »
  • Best Answer
  • hi RemusM did you read earlier posts,no overcolcoking in place at all.
    If so, why do you need "custom watercooling"?
     ;D
    Sure.
     ;D
    Mainboard: HC85
    System RAM: 48KB
    PSU: 5V/3A
    viper
    « Reply #9 on: 01-May-13, 04:37:47 »
    good question so where do you live.i,m in southern australia and right out the back door is the simpson desert south austraila is the hottests and most dry state in this country.my bedroom during summer has had a ambience temp of 38c with no airconditioning.Now i hope that is enough reason for you for me to have watercooling so overclocking just isn,t a option where i live lol
    « Last Edit: 01-May-13, 11:53:16 by viper »
