Author Topic: Need driver for pc60g-f 108m wireless pci card  (Read 4091 times)
vinZiggyTopic starter
« on: 30-April-13, 17:20:56 »
Cannot find it anywhere, needed to format my hard drive. Have now installed XP Pro successfully but unable to install my MSI wireless card.
please help
regards
Vinziggy
  • T9246ED, Бивша комета
  • Administrator
« Reply #1 on: 30-April-13, 17:24:45 »
« Reply #2 on: 06-May-13, 15:10:41 »
Thanks for a quick response, the card is alive.  I can now see all active connections, but when I select my home connection the machine does not promt me for network security key, just tries to connect and  then gives me the message " Unable to connect to the network...."
any ideas?
regards
VinZiggy
The CPU Whisperer
  • I must be menthol
  • FIRST LIEUTENANT
  • Burn baby burn
« Reply #3 on: 07-May-13, 09:34:51 »
If the network is secured with WPA(2), you'll need at least XP SP2 if I'm not mistaken.
