Author Topic: C847IS-P33 last Bios problem  (Read 925 times)
maxmax80Topic starter
  • STAFF SERGEANT
« on: 10-May-13, 00:11:12 »
Hi guys.
I became a father of yet another MSI motherboard! :pompom:
it' s the petite C847IS-P33!
a nice diamond for multimedia HTPC... :agrees:
I just updated the bios (the second and last version, the 7836v11) and what happens?
that in the "hardware monitor" page management CPUFAN fan has disappeared! :nooo:
management SYSFAN1 remained only!
so, the 40x40 CPU fan runs full at 12Volt really a propeller's airplane 6000rpm more or less!
I saw that you upload one beta bios for enabling VT-X...
can you do the same for this bug?
thanks
max
MY MSI:
MSI Z68MA-ED55 (B3) | MSI H67MA-E35 (B3)  |  MSI H61MU-E35 (B3)| MSI P45 Diamond | MSI P45-8D Memory Lover  | MSI Ati R6450-MD1GD3/LP | MSI Ati R5450-MD1GH | MSI-Creative SB X-Fi Xtreme PCI-ex | MSI SATA-6G PCIe SataIII  | MSI V2 US300EX USB WiFi
  • STAFF SERGEANT
« Reply #1 on: 14-May-13, 15:44:41 »
response from customer service:
Dear Max, Thanks for contacting MSI technical support.
Regarding your concern, we are sorry That this option for CPU smart fan Has Been hiden since the fan speed can not changed for this MB.
Thanks and sorry for any inconvenience Caused!
Thanks for your cooperation in advance!
Best Regards,
MSI Technical Support Tea
objectively I'm not 100% sure if originally the fan of the cpu (varying the voltage) worked in full in any case,
but I seem to remember that instead I had lowered its rotation, and then fan monitoring / pwm there was ..
also because otherwise why would have put the connector (4-pin even)?
pity that the first thing I did before using a little card was done immediately update the bios!
MY MSI:
Bernhard
  • GENERAL
« Reply #2 on: 14-May-13, 17:49:34 »
That is not what you wanted to hear.
If you feel comfy with it, the only thing to do is flash the BIOS back and then you will know if the lower fan speed was your imagination or if it did in fact run slower.
Thats the only way to determine if a change was indeed made.
1.B350F Gaming; R5-1600; Crucial MX300 275GB, Ballistix Sport LT BLS16G4D240FSC 2X8gb; Sapphire RX580 Pulse 8gb; Seasonic750W; Win10-64; LG DVD
2.FUJITSU LIFEBOOK S751 QM67;i5-2520M;2 X 4GB 1333Crucial CT256 MX100; Win10-64; Orico Dual Bay USB3 Dock
"veni vedi doctus"
MSI 미친
