Author Topic: PCIe 2.0 and PCIe 3.0 Help.  (Read 2851 times)
EmpireEchoTopic starter
  • Da Greek
  • SERGEANT
    • Battlelog
« on: 03-June-13, 01:02:02 »
Hello There,
im using MSI 970A-G45 and i have Radeon HD6850 . 6850 running with 2.0 PCIe x16 .im planning 1 week to buy new Radeon HD 7850 and i found from pokerSeries with Core CLock:910 MHz well bus type is PCIe 3.0 x16.
i stucked when i saw that... can my 970A-G45 run this card? or not? and whats the difference on 2.0 to 3.0 on plugs.
Thank You
OS:Windows 7 64 bit
Motherboard : MSI 970A-G45, Watercooled
CPU: FX 6100 3.6Ghz Overclocked / Watercooled
DDR3 Ram: Vengeance — 16GB Dual/Quad Channel
GPU: Radeon HD6850
PSU: Corsair GS800
Case: Coolermaster Haf 912 Plus
Led Strips Blue , Led blue x2 Big Fans
LCD Screen for Temps about the system
xmad
  • Salisbury MD
« Reply #1 on: 03-June-13, 04:37:13 »
The cards are backwards compatible, it will just run at pcie 2.0 which won't make a huge difference anyway.
I would suggest updating your bios prior to installing the card though.
Mainboard: X79A-GD65 (8D)
CPU: I7-3930K
Setting: 2400 CL:10
SSD: Corsair GS 256GB
Corsair Link
Cooling: Corsair H100I
  • Da Greek
  • SERGEANT
    • Battlelog
« Reply #2 on: 03-June-13, 09:22:22 »
actually my biggest questio is the PCIe version. is about the mainboard? or i need to update the BIOS as you said?whats the latest BIOS? because i checked with the live update 5....
yea i know that.. the difference on the Battlefield 3 is only 0.45 betwixt 2.0 and 3.0 version.
OS:Windows 7 64 bit
GPU: Radeon HD6850
PSU: Corsair GS800
  • 微星科技
« Reply #3 on: 03-June-13, 19:10:59 »
The board is PCI-E 2.0 and nothing won't change that. The bios update is meant for ensuring compatibility. As xmad said a 3.0 card will work fine in a 2.0 slot.
MSI Radeon RX Vega 64 WAVE 8G
Seasonic G-750 • +12V: 62A • +3.3V: 20A • +5V: 20A
Windows 10 Pro
Cooler Master Masterbox 5 MSI Gaming Edition
  • Da Greek
  • SERGEANT
    • Battlelog
« Reply #4 on: 03-June-13, 19:23:02 »
i dont really care if it works as PCIe 2.0 or 3.0 i care if it will works generally :P .i updated the BIOS before 8 months i think .without flash . or something like this. i download the bios from live update and i installed it with .exe ... is this right?...
OS:Windows 7 64 bit
GPU: Radeon HD6850
PSU: Corsair GS800
  • 微星科技
« Reply #5 on: 03-June-13, 21:32:18 »
It's maximum risk but as you already did it and it worked fine. The new .exe bios versions in fact can just be flashed with the method it comes with.
Windows 10 Pro
  • Da Greek
  • SERGEANT
    • Battlelog
« Reply #6 on: 03-June-13, 21:40:46 »
actually i tried before 1 hour. i cant now . can i brows the file with MSIHQ tool ?
OS:Windows 7 64 bit
GPU: Radeon HD6850
PSU: Corsair GS800
  • 微星科技
« Reply #7 on: 03-June-13, 21:44:38 »
Unfortunately currently the only way is the .exe method.
Windows 10 Pro
  • Da Greek
  • SERGEANT
    • Battlelog
« Reply #8 on: 03-June-13, 22:16:18 »
so i plug in a USB flash and im making a folder with the bios update and after? im loggin from bios to USB and open the .exe?
OS:Windows 7 64 bit
GPU: Radeon HD6850
PSU: Corsair GS800
  • 微星科技
« Reply #9 on: 04-June-13, 17:55:10 »
Follow the guide linked with the bios update: http://www.msi.com/files/pdf/Bios_update_SOPAll.pdf (Updating BIOS from Windows Mode for AMD Series)
Windows 10 Pro
