Author Topic: MSI Z87 MPower MAX vs MSI Z87 MPower - Differences?  (Read 1530 times)
Nelly.Topic starter
  • STAFF SERGEANT
Hey MSI Mods / Techs, can you confirm this is correct for me please? Thanks.  :)
MAX-Version has 20 Digital Phase (600W+ CPU Power), Non-Max version has 16 Digital Phase (480W+ CPU Power)
The MAX version includes a display port, but the non-MAX version has TPM/Bitlocker, not sure if that's a typing error though on the MSI website. Also the MAX has 1 x USB 3.0 Bracket
i5 2500k@ 4.9 GHz|MSI Z77 MPOWER|G.Skill Trident 8GB 2400C10|MSI GTX 970 4GB Gaming Edition @ 1542/7516 |Corsair HX 750 PSU|Samsung 256GB SSD 830|Creative ZxR|Thermalright Silver Arrow|NEC 24WMGX3 24" TFT|Cooler Master HAF X
asdf1221
  • SECOND LIEUTENANT
« Reply #1 on: 05-June-13, 11:48:21 »
The boards have the same features except from the increased number of phases and the extra USB 3 header on the MAX version.
The MAX version also has different circuit layout (not quite important) and extra audio filtering on the sound front header (see those 2 capacitors next to the header?). If you use the front header for audio output (headphones and such) then it's a plus.
Nelly.Topic starter
  • STAFF SERGEANT
« Reply #2 on: 05-June-13, 21:21:36 »
Thanks, for the sake of £20 people may as well opt for the MAX version, unless money is tight.
From the looks of the BIOS, it seems this time MSI have implemented voltage offset, as well as the usual Vdroop offset, good to see.
asdf1221
  • SECOND LIEUTENANT
« Reply #3 on: 05-June-13, 23:05:11 »
Yeah, starting from the FM2 AMD boards and the 8 series Intel boards MSI started using digital PWMs on some of their boards, thus making offset voltage control possible.
