Author Topic: cant install windows 8.1 preview  (Read 2762 times)
gd98
  • Winki
« on: 27-June-13, 20:54:20 »
Im trying to install the windows 8.1 preview on a GT 60 2oc 003.  The installing keeps failing with this error
Error 0xC1900101 - 0x30018, Couldn't update to Windows 8.1 Preview
Any idea on what is going on?
Stu
  • Hawk
  • Birmingham, UK
    • StuOnline.co.uk
Re: cant install windows 8.1 preview
« Reply #1 on: 27-June-13, 21:03:00 »
Do you currently have Windows 8 installed?
You might not be able to 'upgrade' a system with a current Windows 8 full retail version to a 'preview' version.
gd98
  • Winki
« Reply #2 on: 27-June-13, 21:51:54 »
yes win 8 is installed and working fine.
  • Lightning!
    • event.msi.com/vga/lightning/
« Reply #3 on: 27-June-13, 22:23:26 »
As Stu said that's the problem.
MSI Z87 MPOWER MAX (MS-7815) Bios 1.7B4
Core i7 4770K (C0) @ 4300.54 MHz, 1.216V
2*4GB ADATA AX3U2000GC4G9B-2G (1:8) 1066.8 MHz (DDR3-2133) @ 10-11-11-28-2T 1.54v
2*MSI GTX 780Ti GAMING 3G @ 1210/3500 (SLI)
256GB Samsung 830 SSD + 250GB Samsung 840 EVO
Corsair HX1050 +12V: 87.5A • +3.3V: 30A • +5V: 30A
Windows 8.1 Pro
gd98
  • Winki
« Reply #4 on: 27-June-13, 22:31:05 »
So you think the issue is I cannot upgrade a windows 8 to the windows 8.1 preview?
Doesnt seem to make sense seeing that the only way to get the preview is through the windows 8 store.
gd98
  • Winki
« Reply #5 on: 28-June-13, 15:09:34 »
well after a little more digging its seems to be failing on one of the nvidia drivers nvlddmkm.sys  I have checked MSI support section and they dont even have a driver that supports the GTX770M that comes in the GT60.  It looks like the only place I can get the driver is on the cd that came with the laptop at the moment.
