Author Topic: MSI Z87-GD65 Gaming Motherboard Booting Windows 7 Trouble  (Read 4671 times)
TrisXDTopic starter
  • CORPORAL
Hi guys, today I bought the MSI Z87-GD65 Mobo, 2 Sticks of 4GB RAM and the Intel i7 4770. I bought these to upgrade my old system and the only other parts im using is my Nvidia GTX570, PSU and my 2TB Seagate HDD.
Everything hardware works normal, no abnormal signs.
My problem is when it boots up, it says "find --set-root --ignore-floppies --ignore-cd /win7ldr. Error 15: File not found"
I've tried using my windows 7 disc and it says all my stuff is still there and the startup troubleshooter doesn't find any issues. I tried putting my RAM in properly and its in nicely. (they are in the 3rd and 4th slot though) My power is fine, its just the BIOS isn't booting it =(
-The BIOS is updated
-No Hardware faults
Note: when i press any key to continue, it comes up with GRUB4DOS and has options like: "Windows 7 with SLIC Loader (Default)"
Please help me if you know anything!
arturk
« Reply #1 on: 10-July-13, 13:18:11 »
I assume you didn't reinstall your Windows and your are using your old Windows installation with new mobo? I don't think it will work, you need to reinstall your Windows.
Board: Z87M-G43
Bios: Version 2.31
VGA: Geforce GTX770 2048MB DDR5/256bit GV-N770OC-2GD
PSU: SST-ST60F-P Strider Plus 600W (42A +12V1)
Intel CORE I7-4770K 3.5GHz LGA1150 BOX HASWELL BX80646I74770K
MEM: G.SKILL DDR3 16GB 2x8GB TridentX 1600MHz CL7 (F3-1600C7D-16GTX)
HDD0: ADATA SX900 ASX900S3-128GM-C
HDD1: WD Caviar Green, 3.5'', 2TB, SATA III, 64MB cache (WD20EARX)
OS: Windows 8 64bit
Mummy
  • SECOND LIEUTENANT
« Reply #2 on: 10-July-13, 17:47:47 »
-No Hardware faults
Those memory sticks should be in slots 2 and 4  for dual channel use.
Is there code AD or A0 leds on in MB, when that boot up message is showing?
Is that new or old install of Windows 7?
CPU: i5-4670K MB: MSI Z87-GD65 Gaming Memory: 2x4GB G.Skill Sniper 1866DDR3 GPU: ASUS HD7970 Storage: 2x Samsung 840 EVO 250GB @RAID 0 PSU: Seasonic SS-520FL2
Cooling: Radiators: Alphacool Monsta 480, Blocks: EK-Supreme LT and EK-FC7970, Pump: Aquacomputer Aquasream XT Ultra, Liquid: EK-Ekoolant Blood RED.
Froggy Gremlin
  • Master Air OC'er
« Reply #3 on: 10-July-13, 20:11:56 »
As mentioned, you have too many conflicts if using a previous (migrated) OS installation. Recommend a fresh OS install. And as Mummy said, RAM for dual channel goes in the Dimm2 and DIMM4 slots.
IXOYE
TrisXDTopic starter
  • CORPORAL
« Reply #4 on: 13-July-13, 15:14:26 »
I managed to fix the problem by reinstalling windows, its annoying but worked, im only having an issue with my USB Headphones working now
xmad
  • Salisbury MD
« Reply #5 on: 13-July-13, 15:52:51 »
Did you install the ram properly as previously noted? Not doing so will lead to slowdowns at minimum and mostly likely crashes etc. Some times it can even lead to seemingly unrelated issues such as the usb issue you are now reporting.
As for the USB issue, flash the bios to the most recent version using M-flash + ME.
>>Beta BIOSes<<
Mainboard: X79A-GD65 (8D)
CPU: I7-3930K
Setting: 2400 CL:10
SSD: Corsair GS 256GB
Corsair Link
Cooling: Corsair H100I
TrisXDTopic starter
  • CORPORAL
« Reply #6 on: 15-July-13, 13:09:12 »
Yeah about the USB issue, its for my Razer Megalodon Headphones, I've tried different ports, it works on other PCs... I am going to try change the RAM around and see if that might fix it. I'm hoping I don't have to risk flashing the BIOS, because I've never done it before.
Update: Did not work, I tried it in the USB 2.0 slot and instead of it usually installing it as a Unknown Device, it said Razer Megalodon for 3-4 seconds before identifying it as an unknown device.
« Last Edit: 15-July-13, 20:33:17 by TrisXD »
TrisXDTopic starter
  • CORPORAL
« Reply #7 on: 15-July-13, 13:12:10 »
Its a fresh install of Windows 7, i had to do it to fix my original problem =/
Update: I changed the RAM and put them in the slots u suggested, no change.
« Last Edit: 15-July-13, 20:30:29 by TrisXD »
Mummy
  • SECOND LIEUTENANT
« Reply #8 on: 17-July-13, 20:40:15 »
Sorry, when i post my last anser, i didnt know your new problem :hiha:
Sounds like old problem from time of XP to Vista.
Firsth. Take out that USB connection of your headset from PC.
Secend. Uninstall any driver that headset (or you) may have installed to your OS.
Third. Run registercleaner program.
Fourth. Shotdown PC and then start again (dont just reboot!)
Fifth. Download and/or Install drivers for that USB headset.
Sixth. Reboot that PC.
Seventh. Insert that USB connection.
I hope this helps! Cheers, Mummy :hat tip:
If not i would try to ubdate intel chipset drivers(if MSI ones dont work, i would go to Intel site and try them from there) and if those dont help then another reinstall of OS and member to inser USB device after installing drivers for the device.
HenryW
« Reply #9 on: 17-July-13, 22:22:07 »
 Does a normal USB headphone set work OK or don't you have one to test? There have been issues with various Razer devices on plenty of different MBs that required a modified BIOS from MSI.
Z77A-GD65/BIOS 10.5, i7 2700K
W 7 Home Premium x64/SP1
Corsair TX650W
Lite-On CD/DVD combo burner
MSI 560 HAWK, Drv. 368.82
TrisXDTopic starter
  • CORPORAL
« Reply #10 on: 18-July-13, 02:20:41 »
Hi guys, thanks for replying =) I don't have any other USB Headphones to test out, but I reckon ill try Mummy's suggestion and run that registrycleaner. but another thing is that it uses a windows Generic USB Audio driver and not its own =/ so thats a bit tricky. Two MSI Moderators suggested i flash my BIOS, but that's really risky and I don't want to stuff up and have a useless mobo
Mummy
  • SECOND LIEUTENANT
« Reply #11 on: 18-July-13, 17:21:55 »
There are allso drivers under "Sound, video and gamepad devices"
If Razer dont have those or you havent installed them then it probably says USB-Soundevice and its MS driver from 2010
TrisXDTopic starter
  • CORPORAL
« Reply #12 on: 19-July-13, 04:22:33 »
I have Nvidia High Definition Audio and Realtek High Definition Audio under that.
I'm running 64x Windows (Service Pack 1) btw.
I'm gonna try and reinstall the Intel Chipset Drivers and see if that will workout
TrisXDTopic starter
  • CORPORAL
« Reply #13 on: 23-July-13, 03:25:04 »
I successfully updated my BIOS to the latest version, and no change =/
TrisXDTopic starter
  • CORPORAL
« Reply #14 on: 23-July-13, 04:10:24 »
I just found how to disable the onboard HD Audio Manager in the BIOS, my headphones were able to be installed oO.
Update: Solved. I disabled the onboard sound card and then it let my headphones install the windows USB Audio driver, restarted with the onboard soundcard enabled and it works =D
« Last Edit: 23-July-13, 11:34:52 by TrisXD »
