Author Topic: MSI Z87-G45  (Read 2083 times)
Steve888Topic starter
MSI Z87-G45
« on: 21-July-13, 23:41:39 »
Hi, Got a few issues with the MSI Z87-G45 (so far):
1) Wont boot with a Logitech G15 keyboard (searching for reason).
2) OS (Win 7 64 Home) wont recognise OCZ Vertex 2, listed in BIOS (known issue).
3) NIC refuses to run at 1000 mbps - connected to a Netgear GS605 v2 (searching for reason).
All with up to date drivers / BIOS.
i7-4770K, Corsair Vengeance DDR3.
Any suggestions welcome.
Cheers,
Steve.
Board: MSI Z87-G45 Gaming
Bios: Version 1.3
VGA: MSI GTX 660Ti Power Edition
PSU: Corsair HX1000 (80a +12v rail)
CPU: Intel Core i7-4770K Haswell 3.5GHz (3.9GHz Turbo Boost) LGA 1150 84W
MEM: Corsair Vengeance 2x8gb CMZ16GX3M2A1866C9
HDD: WD Velociraptor (2x Raid 0), Raptor, Samsung 840 Pro SSD (OCZ Vertex SSD not working)
COOLER: Custom water cooling, EK-Supreme LTX CSQ
OC: XMP ram only atm
OS: Windows 7 64bit Home
Case: CosmosS
SynchronicBoost
  • SERGEANT
« Reply #1 on: 22-July-13, 01:22:35 »
Try clearing CMOS and see if it comes back, and check USB legacy settings
Board: MSI Z77A-G41
Bios: Version 2.09
VGA:   IGP
PSU:   Thermaltake TR500
Intel Core i5-3570K Ivy
MEM: Corsair 1600 mhz
HDD: Toshiba 500 GB 7200 rpm
COOLER: Thermaltake Water 2.0
OC: 4.2 Ghz
OS: Windows 7 64bit Professional
Case:  MSI Raptor 3 fans
Froggy Gremlin
  • Master Air OC'er
« Reply #2 on: 22-July-13, 02:49:03 »
That OCZ SSD is not going to work. At this time, no known fix is possible. Another user has reported his keyboard is not compatible as well. That will take a UEFI/BIOS revision. A standard USB keyboard did work. Disable all Killer Management functions. MSI has a standalone driver without the bloat. Recommend to contact them;
  >> How To Contact MSI <<
IXOYE
« Reply #3 on: 25-July-13, 20:30:19 »
Update:
1) G15 Keyboard now working ok after second BIOS re-flash, CMOS re-set.
2) No fix imminent, got a Samsung 840 Pro coming tomorrow (crosses fingers).
3) Logged with MSI support, on-going. Disabled the killer monitoring, no joy.
Steve.
Bios: Version 1.3
Case: CosmosS
SynchronicBoost
  • SERGEANT
« Reply #4 on: 02-August-13, 16:57:13 »
Good luck with that, it sucks that it is so buggy out of the box.
Board: MSI Z77A-G41
Bios: Version 2.09
VGA:   IGP
OC: 4.2 Ghz
« Reply #5 on: 02-August-13, 20:33:15 »
Having bought a Samsung 840 Pro am now back gaming  8-)).
Still have issue with NIC not running at Gigabit, MSI support gave up on me, said to RMA it.  Asked for the standalone driver but ignored question.  Refuse to believe it's a board problem.  Tried CAT 6 cable, haven't tried a different switch yet as don't have access to another.  The killer software is a joke, keeps loosing settings.
Bios: Version 1.3
Case: CosmosS
xmad
  • Salisbury MD
« Reply #6 on: 02-August-13, 20:35:52 »
Have you tried the most recent beta bios?
>>Beta BIOSes<<
Edit:
I also had to retire my G15 recently :(
Logitech isn't going to update the firmware and apparently has issues with some of the newer hardware. I was getting intermittent disconnections etc. (Could have just been the keyboard failing of course as well)
Mainboard: X79A-GD65 (8D)
CPU: I7-3930K
Setting: 2400 CL:10
SSD: Corsair GS 256GB
Corsair Link
Cooling: Corsair H100I
« Reply #7 on: 02-August-13, 21:34:33 »
>>Beta BIOSes<<
Edit:
Not yet, looks like a thunder storm brewing here  :shocked_anim:, will give it a miss tonight.
G15's been ok for me so far, having flashed to 1.3.
Bios: Version 1.3
Case: CosmosS
