Author Topic: MSI Z87 G45  (Read 6871 times)
vernonTopic starter
MSI Z87 G45
« on: 23-July-13, 06:27:17 »
hi, just recently i've bought this board, my USB keyboard not working on the POST there, but in the windows its okay. i tot it would be the bios usb legacy enable/disable. i use the other keyboard and went to enable the usb legacy, but still the previous usb keyboard still not working by the POST time. i just dont want to switch to other keyboard when i wanted to go to the bios.
Any idea what's happening? :bonk:
HenryW
« Reply #1 on: 23-July-13, 06:57:53 »
 Read this: >> Posting Guide <<
 Please provide more info regarding all your components in your rig. See my signature below for an example of what to list. Include the brand and model of the keyboard that you're having the trouble with and BIOS version on your MB. There has been problems with various keyboards and MBs that needed a beta BIOS from MSI to cure it. The more we know about your rig the better chance there is to help you fix it.
Z77A-GD65/BIOS 10.5, i7 2700K
W 7 Home Premium x64/SP1
Corsair TX650W
Lite-On CD/DVD combo burner
MSI 560 HAWK, Drv. 368.82
vernonTopic starter
« Reply #2 on: 23-July-13, 16:36:35 »
Board: MSI Z87 G45 Gaming
Bios: V 1.2
VGA:   sapphire 7870xt
PSU:   Corsair vs650
Intel Core i5-4670K
MEM: Kingston HyperX 8gb khx1600c9d3/8gx
HDD: wd black 1tb
COOLER: intel
OC: not OCed
OS: Windows 7 64bit Professional
keyboard: armaggeddon nighthawk kai-5
should i update the bios?
Mummy
  • SECOND LIEUTENANT
« Reply #3 on: 23-July-13, 19:46:20 »
Have you tryed all USB Ports on MB back I/O -plate?
...if yes, then i would try to update the BIOS if possible.
Edit: Allso i would do them one step at time and not just go straigth to newest and also member to clear CMOS, everytime you update the BIOS!
CPU: i5-4670K MB: MSI Z87-GD65 Gaming Memory: 2x4GB G.Skill Sniper 1866DDR3 GPU: ASUS HD7970 Storage: 2x Samsung 840 EVO 250GB @RAID 0 PSU: Seasonic SS-520FL2
Cooling: Radiators: Alphacool Monsta 480, Blocks: EK-Supreme LT and EK-FC7970, Pump: Aquacomputer Aquasream XT Ultra, Liquid: EK-Ekoolant Blood RED.
Froggy Gremlin
  • Master Air OC'er
« Reply #4 on: 23-July-13, 20:05:36 »
IXOYE
PCasuarus
  • UBER NOOBER
  • SERGEANT
« Reply #5 on: 23-July-13, 23:27:41 »
Do you have fast boot installed? That keeps usb from working until windows starts to speed up the boot process.
MSI Z87-GD65 GAMING Mobo
Intel i5-4670K OC @ 4Ghz
8 Gig(2x4 Gig) Mushkin Enhanced Redline DDR3 1600 CAS 7
Samsung 840pro 256 Gig SataIII Boot Drive
2x Seagate Constellation ES SataIII in RAID0 Mass Storage
Liteon DVD-RW Lightscribe Sata ODD
Corsair H80i Water Cooler
Rosewill Green Series RG630-S12 630W 80+ BRONZE PSU +12v 50amp
MSI Gaming N770 TF 2GD5/OC
2x 42" 42LG70 2.7ms 120Hz 1080p LCD Panels
Logitech G230 32ohm 40mm Analog Headset
FiiO QOGIR-E09K Headphone Amplifier
Razer Nostromo Keypad + Naga Mouse
Popcorn
Mummy
  • SECOND LIEUTENANT
« Reply #6 on: 23-July-13, 23:52:18 »
So that stuff works under W7 even if its made for W8?  :noidea: that what i was thinking too when i see that :think: but as i wasnt sure i didnt try it...
PCasuarus
  • UBER NOOBER
  • SERGEANT
« Reply #7 on: 24-July-13, 03:35:59 »
It works under win7 but like the win8 built in feature it only really shaves off a few seconds. These new boards post so quickly that you are to the ssd and the desktop in seconds after powering on anyways.
I only installed it for the one click bios function so I can easily get into the bios for any changes.
Popcorn
vernonTopic starter
« Reply #8 on: 25-July-13, 03:53:10 »
the fast boot you mean software in the windows? or in the bios setting?
vernonTopic starter
« Reply #9 on: 25-July-13, 03:54:01 »
yes, all tried, non worked for me. :cry:
PCasuarus
  • UBER NOOBER
  • SERGEANT
« Reply #10 on: 25-July-13, 06:19:23 »
The fast boot software on the motherboards installation disk. If that is installed and enabled you won't be able to use any usb devices till after windows boots to the desktop.
Popcorn
vernonTopic starter
« Reply #11 on: 25-July-13, 09:15:47 »
that software has not been installed yet.
Mummy
  • SECOND LIEUTENANT
« Reply #12 on: 25-July-13, 10:08:59 »
I was thinking the Fast Boot options in BIOS under, Settings/ Advanced/ Windows 8 Configuration/...
But seams like "MSI FastBoot" should allso disable PS2 device.
And if you use normal Fastboot you should have needed to disable USB device your self atleast on my MSI Z87-GD65 Gameing MB BIOS in default they arent.
So check how those are set on your MB, to be sure.
Heres an picture of my BIOS. If i enable Fastboot i still need to diasble my device one by one.
Edit: hmm wait, if MSI Z87-G45 had that "MSI Fast Boot" -option then how you get in BIOS ?
1: Clearing CMOS yeah, but i would think then on that Board it dont disable ps2. Because otherwise you would need to save your settings in profile to get fast past setting all little things up..
vernonTopic starter
« Reply #13 on: 25-July-13, 12:57:01 »
before this i borrowed a keyboard from my friend, but had returned it, now i have no other keyboard other than the keyboard that i listed above... its a gold plated usb keyboard with named for gaming......
maybe i will wait for msi to update the bios......
Mummy
  • SECOND LIEUTENANT
« Reply #14 on: 25-July-13, 18:38:41 »
Well if its BIOS settings then there are nothing MSI to update on BIOS and Froggy Gremlin already give you link for newer BIOS.ses.
Did you try them?
vernonTopic starter
« Reply #15 on: 26-July-13, 04:33:31 »
already tried out to update bios to 1.3, still the same.
Froggy Gremlin
  • Master Air OC'er
« Reply #16 on: 26-July-13, 04:50:13 »
Fast Boot setting looks enabled to me, along with PS, SATA, and that other setting (Full Initial). Disable those things.
Clear CMOS with the PSU power cord pulled, the battery pulled, then reset.
If it's a Razor keyboard, it may not be fully compatible and will require the BIOS engineers to see if they can come up with a fix for it. If that is the situation, recommend to contact MSI Technical and open a ticket with them;
  >> How To Contact MSI <<
IXOYE
vernonTopic starter
« Reply #17 on: 26-July-13, 07:11:44 »
i never enable those function you mention.
 http://register.msi.com/  seems very slow to me, can't even load the page, since i bought the board.
Mummy
  • SECOND LIEUTENANT
« Reply #18 on: 26-July-13, 09:05:13 »
@ Froggy Gremlin; Sorry that was picture of my board BIOS, to get picture what to look for.
Shouldent those Keyboard commands be standard. I mean KB makers cant expect every MB maker to make change on theyr BIOS for them.  :think:
And so i would look FW update form KB maker, if thats what houlding it back...
@ Vernon; Clearing CMOS should make them enabled. As in firsth boot of MB you should get in BIOS no mutter what device you use.
Dos any USB device get power same time when you cant get in BIOS with your KB :confused2:
Froggy Gremlin
  • Master Air OC'er
« Reply #19 on: 26-July-13, 12:47:58 »
From what I am reading, yes, the keyboard is not compatible. Keyboard commands have nothing really to do with it if it won't intitialize properly during POST. If I understand it right, he had borrowed another USB keyboard and it was working.
IXOYE
Mummy
  • SECOND LIEUTENANT
« Reply #20 on: 26-July-13, 15:14:34 »
And i was thinking that the other Keyboard was PS2 version, but if that is not the case, then sadly i dont see how MSI would fix it and so i would go to ask fix from KB maker as there is no settings that could fix that issue, that i know.
Froggy Gremlin
  • Master Air OC'er
« Reply #21 on: 26-July-13, 21:57:12 »
Right. I may have missed that in all the thread text if it was a PS/2. MSI engineers have been able to resolve keyboard compatibility in the past, they may be able to again.
IXOYE
vernonTopic starter
« Reply #22 on: 27-July-13, 04:14:43 »
yup, i think i maybe wanna change to other keyboard......
MrTigros
« Reply #23 on: 26-May-14, 16:08:22 »
"lifting this topic up" !!
First of all my specs;
Intel Core i7-4770K  3.5GHz
MSI Z87-G45 Gaming, Socket-1150
MSI GeForce GTX 760 Gaming 2GB
2x Corsair Vengeance DDR3 1600MHz 4GB CL9
1000w PSU
sata 3 500gb HDD
I recently bought 2 of theese MB:s, one for my computer and also i build a computer for my GF..
im struggling ALOT with my keyboard sometimes not working neither from startup or in windows..
i have been updating BIOS to the latest, and while doin that i noticed in the info that there was some USB issues that had been "corrected".
Well apperently this issue i have is a pain and it wont give in.. i have been tryin 3 other keyboards and at the point its not working, no keyboard is working, EXCEPT, for the one i use for GF computer, wich is a wireless Logitech k850 something keyboard, That one works like a charm, but none of my wired ones..
Strange thing tho, is when it is working, i tapped into BIOS to check if there was some USB setting to change or smth, but nothing.. tho i noticed it said i had 2 keyboards installed o.O, 2 ?! no i only have 1..
Why does it say 2?
One more thing just, while keyboard aint working, my Bluetooth stick works, USB memory works, Mouse works, and External usb3 disc works..
Yet it says  this in the USB setting  that i have 7 of 8 unused ports, and 1 port with unknown device..
anyone know the solution to this? :3
Please write a line or two so i can fix this!
Best regards // Emil
PS; sorry for  bad english, im from sweden.
