Author Topic: z87 g45 gaming bios issues  (Read 511 times)
undersub
  • Neo
« on: 02-August-13, 18:45:14 »
I just mounted my new computer and I have issues with the motherboard.
When it boots, the boot screen does not have the right resolution and when I try to enter the BIOS, it's the same, also the graphics are messed up, elements are missing etc.
And when I try any option of the menu (for example , Settings) I got a message (bin is incorrect) and then the computer reboots.
The bios was version 1.2, I updated it to 1.3 and it's exactly the same.
I saw on internet, that I'm not the only one and the problem exists in other motherboards.
I think it's a BIOS software problem, any way to resolve this ?
Thank you !
xmad
  • Salisbury MD
Re: z87 g45 gaming bios issues
« Reply #1 on: 02-August-13, 19:41:42 »
What monitor?
Are you using IGD or and discrete card?
Have you tried different ways of hooking up the monitor? IE: HDMI vs vga vs DVI
New:
Board MSI Z77 Mpower
Bios: Latest Official
VGA   MSI GTX 760
PSU:  Corsair GS700
Intel Core I7-3770K
MEM: Corsair 2133 2x4gb CL: 9 Dominator Platinum
500GB HHD
COOLER: Zalman 9900
OC: (Turbo)4.5Gh
Ram: 2133Mhz 1.55v
CL 9
Board: X79A-GD65 (8D)
Bios: 4.6
CPU: Intel 3930k Hexa-Core
Ram: Corsair Dominator Platinum 4x4gb 2133 CL:9
Vid: GTX 780TI 3GB in SLI
PSU: Corsair AX1200I
Cooler: Corsair 80I
SSD: Corsair Neutron GTX 240 GB SSD
Startech Raid Controller Card
HDD: 2x Seagate 500gb 7200 in Raid 0
HDD: 2x Seagate 1tb 7200 in Raid 0
OS: Win 8.1 Pro in UEFI mode
Corsair Link
Corsair H-100I Cooler
undersub
  • Neo
« Reply #2 on: 02-August-13, 20:44:41 »
I have a msi 760 gtx as video card and I use dvi as output.
But I am pretty sure this a motherboard issue, because the bios is unusable, display is messed up and some option made it to freeze / restart.
It can even boot on usb for the forum way to flash
Also when I shutdown the computer, it restart, another proof that there is a problem with the bios.
I flashed it via windows twice with cmos clear and there is still the same problem (was there before I did the flash) as I can't boot usb and bios is too messed up to use mflash.
I opened a ticket at msi support regarding this issue
Regards,
xmad
  • Salisbury MD
« Reply #3 on: 02-August-13, 21:26:56 »
Have you tried the latest beta bios?
What is the s/n of the card?
Use nvflash for windows: >>Download NVFLASH for windows<<
syntax:
nvflash /v >rep.txt [ENTER]
At the bottom of the report it will tell your vbios version.
New:
VGA   MSI GTX 760
PSU:  Corsair GS700
Intel Core I7-3770K
500GB HHD
COOLER: Zalman 9900
OC: (Turbo)4.5Gh
Ram: 2133Mhz 1.55v
CL 9
Bios: 4.6
Cooler: Corsair 80I
Corsair Link
