Author Topic: MSI Ge70 windows ssd question  (Read 3107 times)
Kalekip21Topic starter
  • STAFF SERGEANT
« on: 02-August-13, 20:00:14 »
I am buying an SSD this sunday and was wondering how to turn a windows recovery CD into a clean windows 8 CD so i can install it on my SSD, since in win8 the key is encrypted into the bios.
Is there a way to remove most of the MSI things from the recovery CD?
Thanks in advance!
(also when i have installed win8 on the SSD can i remove all the partitions on my HDD and make it to 1 big HDD?)
--Kalekip21
  • T9246ED, Бивша комета
  • Administrator
« Reply #1 on: 03-August-13, 02:37:03 »
you can do a clean install on the SSD,
use original W8 Installation, make USB W8 installation and install it on SSD
its recommended to disconnect your HDD temporary, before install W8 on SSD,
and to reconnect it when its done
yes eventually, but my opinion there is no need to do this, because:
you will lost recovery function
also by that way you will have second backup OS to boot from in a case that OS on the SSD become messed up.
this also can help for easy OS restore.
after OS install on SSD and your program installation/updates, customizations and so are done,
you can boot from your HDD and to do a image file with Acronis true image from the SSD and to store it on HDD
then in a case of OS problem on SSD, you can restore it very quickly, by boot from HDD and restore image on SSD.
P.S: What SSD storage you gonna install?
  • STAFF SERGEANT
« Reply #2 on: 03-August-13, 09:00:18 »
Thanks for the answer! i will install a Samsung 840 Pro 128GB SSD.
How do i get the clean instalation from the recovery CD i can burn with MSI burnrecovery?
Thanks!
--Kalekip21
darkhawk
  • Online Online
« Reply #3 on: 03-August-13, 12:19:33 »
Thanks!
--Kalekip21
The MSI builds are actually rather clean already. Much less 'BS' software installed than other companies I've used.
After installing Windows, the last DVD should be installed once in Windows, and that should give you the option of what 'optional' software to install. (It did on my GT70 anyway) You could then choose to not install most of it and have a pretty clean installation of Windows. Assuming that its the same as my GT70 anyway.
MSI GS73VR 6RF
I7 6700HQ
16 GB DDR4
GTX1060 6GB
MSI X370 SLI Plus
Ryzen 5 1500X
16 GB DDR4
R9 290X
GTX1050Ti
  • Administrator
« Reply #4 on: 04-August-13, 00:20:43 »
that's not M-Sata SSD right?
then you will need an extra bracket if you want to keep HDD too,
because optical bay rack need special bracket to be installed to handle HDD
  • STAFF SERGEANT
« Reply #5 on: 04-August-13, 09:59:37 »
What kind of bracket? i though all 2,5inch ssd's would fit in laptops and M-satas were for netbooks.
  • STAFF SERGEANT
« Reply #6 on: 04-August-13, 14:04:47 »
Okay i have seen that normal SSD's dont fit in, i can choose between 2 drives but cant decide which 1:
Option nr 1: Mushkin Atlas deluxe 120GB
Option nr 2: Kingston MS200 120GB
Which one would you guys pick?
Thanks in advance
-Kalekip21
darkhawk
  • Online Online
« Reply #7 on: 05-August-13, 05:05:51 »
I'm currently running 2x Mushkin Atlas Deluxe 240GB mSATA SSD's in my GT70 and it is running great......
Granted I'm on a GT70 with the superraid adapter, but still, you get the idea.
MSI GS73VR 6RF
I7 6700HQ
16 GB DDR4
GTX1060 6GB
MSI X370 SLI Plus
Ryzen 5 1500X
16 GB DDR4
R9 290X
GTX1050Ti
