Author Topic: What is MSI Fast Boot?  (Read 2430 times)
Zach_n
  • Cyclone
« on: 11-October-13, 17:10:12 »
I've recently installed Windows 8 and I noticed that there are some Windows 8 features in my BIOS which I can enable, my board is a Z77A-GD65.
Can someone please explain what Fast Boot does along with the other Win 8 features? Also, I read in one thread that Fast Boot requires some specific protocol from the Graphics card, I have a GTX680....
Thanks for the help.
CPU: i5 2500K @ 4.5GHz (45x100 1.35V)
Cooler: Corsair H100i
Board: MSI Z77A-GD65 ~ BIOS 10.11
Memory: 2x4GB Corsair Vengeance DDR3-1600 LP
SSD: Samsung 840 Pro 256GB
HDD: WD 1TB Caviar Blue Sata 3.0
GPU: EVGA GTX680 SuperClocked Sig 2
PSU: Seasonic X-650 Gold 80+
Case: Corsair Obsidian 650D
OS: Windows 8.1 Pro x64
xmad
  • Salisbury MD
Re: What is MSI Fast Boot?
« Reply #1 on: 11-October-13, 17:11:46 »
MSI Fastboot is all of the fast boot options enabled & interacts with the MSI fastboot utility.
New:
Board MSI Z77 Mpower
Bios: Latest Official
VGA   MSI GTX 760
PSU:  Corsair GS700
Intel Core I7-3770K
MEM: Corsair 2133 2x4gb CL: 9 Dominator Platinum
500GB HHD
COOLER: Zalman 9900
OC: (Turbo)4.5Gh
Ram: 2133Mhz 1.55v
CL 9
Board: X79A-GD65 (8D)
Bios: 4.6
CPU: Intel 3930k Hexa-Core
Ram: Corsair Dominator Platinum 4x4gb 2133 CL:9
Vid: GTX 780TI 3GB in SLI
PSU: Corsair AX1200I
Cooler: Corsair 80I
SSD: Corsair Neutron GTX 240 GB SSD
Startech Raid Controller Card
HDD: 2x Seagate 500gb 7200 in Raid 0
HDD: 2x Seagate 1tb 7200 in Raid 0
OS: Win 8.1 Pro in UEFI mode
Corsair Link
Corsair H-100I Cooler
Zach_n
  • Cyclone
« Reply #2 on: 13-October-13, 12:34:03 »
Thanks for the reply but that doesn't really answer my question. Can you please explain what it does exactly and if I should enable it or not?  Thanks
MooseTracks
  • Easy OC
« Reply #3 on: 17-October-13, 02:19:20 »
I think he did.  Turn off MSI Fast Boot.  See all of those fast boot settings now?  It turns them all on.
The fast boot utility is here:
http://us.msi.com/product/mb/Z77A-GD65.html#/?div=Utility&os=Win8%2064
I don't use the utility, but I believe it lets you get into the BIOS on the next reboot.  Maybe someone elaborate all of the utility's features.  Fast boot skips USB & PS/2 initialization and makes it impossible to get into the BIOS without a utility.  You can also get into the BIOS using Windows 8's advanced boot options.
scaramonga
  • Easy OC
« Reply #4 on: 17-October-13, 05:10:17 »
MSI Fast Boot, is a utility that lets you enter BIOS while fast boot is enabled, think of it as a 'switch', software wise.
Fast Boot, is just that, no way to enter BIOS, unless you press the 'Goto BIOS' button on the board, assuming you have this turned on, and that Windows 8 features are enabled, and running said OS, or, as above, having to go into Windows 8 Advanced Boot Options.
Basically, a shortcut, but an unnecessary one ;)
« Last Edit: 17-October-13, 05:22:12 by scaramonga »
Board: MSI Z87-GD65 Gaming
Bios: Version 1.6b3
VGA: Palit GTX 780 EK Watercooled (vBIOS Modded)
PSU: Corsair TX 750 (60a 12v rail)
CPU: Intel Core i7-4770K Haswell 3.5GHz (4.4GHz) LGA 1150 84W
MEM: GSkill Trident X 2400 2x8Gb F3-2400C10D-16GTX
SSD: Samsung 840 Pro 256Gb
HDD: 2 x 1Tb WD Black RAID 0
COOLER: XSPC Raystorm Waterblock
OS: Windows 8.1 64bit Pro
Zach_n
  • Cyclone
« Reply #5 on: 21-October-13, 09:05:15 »
Thanks, that makes it more clear :)
neoroy
  • Platinum
« Reply #6 on: 22-October-13, 18:07:43 »
Yup Fast Boot will skip BIOS post and straight to the windows :) Ofcourse you will not able to get inside BIOS menu...unless you set that program to "Go to BIOS" in windows before restarting PC.
Intel Core i5 3570K [4.5GHz - 1.22v]
DeepCool Gammaxx300
MSI Z77A-GD80 V1.0 BIOS V1.50
MSI GTX780 LIGHTNING [1300/1650 1.25v Skyn3t VBIOS]
Gskill ARES F3-2133C9D-8GAB [2600MHz 11-13-12-21 1T - 1.65v]
WDC Black 500G 32mb SATA2
SAMSUNG Bluray combo SH-B123L
SyncMaster 2233SW
Creative Inspire T3030
Razer Death Adder Blue 3.5G+Goliathus Extended
Corsair HX750 80+Silver
Windows 7 Utimate x64
Acrylic Benchtable
a_asterix
  • Winki
« Reply #7 on: 23-October-13, 16:10:43 »
the "MSI fast boot" option in the bios has nothing to do with the fast boot option with win 8 in uefi mode.
"MSI fast boot" is only a initialization skip of the enumerated hardware options for the lagacy bios, it also works with win 7!
