Pages: 1 [2]  All   Go Down
Author Topic: How to fix issues with Killer Lan  (Read 231681 times)
flobelixTopic starter
  • 微星科技
Windows 10 Pro
MSI MAG BUNKER Case
cyborgmsi
Re: How to fix issues with Killer Lan
« Reply #51 on: 31-August-15, 18:59:36 »
Thank You sir for this invaluable post.. i was struggling with internet speeds from my provider and had like 3 -4 technicians visit to identify the  problem.. until I finally figured something could be wrong with the mobo's lan card.. which shouldn't have been the issue if msi had proper drivers for the lan card on this mobo ( max power z87 ) from the beginning it self...
Thanks again...
  • 微星科技
« Reply #52 on: 01-September-15, 09:25:59 »
:hat tip:
Windows 10 Pro
MSI MAG BUNKER Case
wspldng
« Reply #53 on: 03-September-15, 14:05:30 »
I can connect to internet but get "limited", might this fix that?
Here's a post I created on the subject if you might need more details on my issue.
https://forum-en.msi.com/index.php?topic=260524.0;topicseen
  • 微星科技
« Reply #54 on: 04-September-15, 12:32:07 »
This thread is for Intel mainboard section. Stick to your thread in notebook section.
Windows 10 Pro
MSI MAG BUNKER Case
ceebeejohnson
« Reply #55 on: 30-October-15, 19:35:24 »
Right,
The reason why this fix is not applicable to some because they 'clearly have another problem' or 'cant follow the non official representative of MSI's instructions' is because the information is half baked and theres some insistance that as admins they are absolutely correct. Despite following the various different instructions and bad work arounds here, i have still constantly had the issue of dropouts. Its not another issue, its not windows, its not my hardware, its exactly the same problem that admins here claim to have found a solution for, that they havent fixed. Ive finally completely smashed it out on my machine and have found additional clues to the problem on my MSI GE62 2DQ Apache - The SOLE issue i have with this wonderful machine has been the god awful killer ethernet drivers.Why the f some clown thought it would be a good idea to have a hard wired ethernet port that disconnected will still interfere with a connected wifi network is beyond dumb, and anyone who thinks these types of devices ACTUALLY increase any network traffic flow must be about 12 years old. Even the theory is suspect... but i digest. I dont use a wired ethernet connection at all, i use WiFi exclusively, so to have an ethernet device cause issues with my wifi network p****s me off to no end.
First of all - Remember its actually an ATHEROS AR8161 PCI-E Gigabit Ethernet Controller (NDIS 6.30) - This is what it will display directly in device manager WHEN YOU HAVE CORRECTLY FIXED THE ISSUE
OTHERWISE IT WILL KEEP ON DISPLAYING AS A KILLER ETHERNET DEVICE AND WILL REMAIN NON FUNCTIONAL.
Heres the poop -
Disabling the ethernet in your device manager doesnt stop the dropouts. It DOES however result in faster and sometimes even instant reconnections. This is sketchy tho.
I have no idea what this killer cleaner stuff does, as it seemed to do literally nothing that using the standard windows 'uninstall program' function does. It doesnt remove keys or drivers, only the killer suite. That is all.
Heres how to fix it, so it actually works.
Go to the atheros website and download the suggested standalone drivers, ive given you the device name above.,
UNINSTALL the killer suite using the programs and features menu NOT killer cleaner. (didnt make any difference at all whether i used this or not. i suggest dont use it because i know my steps work)
UNINSTALL the device in device manager, checking the box for deleting the drivers. I find at this stage, im still connected to the internet, as at this stage your wifi card is working exactly the way it should, as a standalone device not connected by software to some half arsed rebranded network card. DISCONNECT from the internet. DO NOT go into airplane mode or anything. Just disconnect.
HERES THE PART THE ADMINS ARE MISSING
REGEDIT - Do repeated searches for 'killer' and 'e2200' - D.F.E. (Delete Effing Every) single key you find with either of those terms in it. ALL KEYS LISTING KILLER OR E2200 NO EXCEPTIONS. THIS IS HIGHLY IMPORTANT. IF YOU DO NOT DO THIS, THEN EVEN IF YOU 'SUCCESSFULLY' INSTALL THE ATHEROS DRIVERS IT WINDOWS WILL A) - STILL LIST YOUR DEVICE AS KILLER ETHERNET AND B) - STILL ATTEMPT TO OVERRIDE YOUR OEM ATHEROS DRIVERS WITH RIVET/KILLER NETWORKS MICROSOFT SUPPLIED DRIVERS. - DO NOT RESTART AT THIS STAGE. Youll also notice when you read some of the notes on the registry keys something called 'Rivet networks' appearing - This also appears to be important but more on that in a moment.
THEN - Scan hardward for changes in device manager. Your device will now come up as a generic unknown ethernet device, THIS IS GOOD
Right click on the device not working - Properties - Update driver - Browse my computer - Let me pick from a list of drivers - Have disk - Locate the files for the drivers you just downloaded, and select the device i listed above **GO THROUGH IT IN THAT ORDER OR IT WILL STILL INSIST ON AUTOMATING THE PROCESS AND WILL RE-INSTALL THE DRIVERS YOU TOLD WINDOWS TO UNINSTALL AND DELETE, AND NOT THE DRIVERS YOU ARE TELLING IT TO INSTALL**
You will then see in your device manager - A Qualcomm Atheros AR8161 entry instead of Killer e2200 and youll very quickly find that you no longer get any dropouts. I did this last night, and have not had a dropout or connection problem since.
A FURTHER OBSERVATION - I then fired up my laptop this morning to keep an eye on whether this has worked and found that my computer had 'Failed' an update..... Windows has again, ATTEMPTED TO OVERRIDE MY DRIVER INSTALLATION by attempting to install what seems to be called some 'Rivet Networks' :censored:  so im guessing this is what micropoo are using to insist their software needs to be installed. Ill now have to find a way to block that from ever happening again so i can maintain some functionality during an update cycle. Ive never trusted an OEM with new drivers.
So, now you have the actual lowdown on why A) this problem was FAR from 'Solved' in these forums and B) what the issue is and how to fix it.
_NOW_ the problems are fixed.
Have a nice day.
zbelcas
« Reply #56 on: 02-November-15, 14:50:16 »
Hi all.  Just about to start a Z97 Gaming 5 build and the Killer Lan issue has my attention (big time!)  I've parsed everything in this forum and others as well and most (?all) of the proposed fixes assume that the Killer Suite/drivers have already been loaded (different approaches on ensuring complete removal of the Killer Suite bits and pieces).  My question is whether this problem can be wholesale avoided by loading the 'non-Killer' drivers made available by MSI (and/or Qualcomm) from the get-go and not the Suite??  Anyone have experience with this?  If it is possible, which NIC driver (MSI or Qualcomm) would be preferable?  Thanks for the collective wisdom...
  • T9246ED
  • Administrator
« Reply #57 on: 03-November-15, 06:31:16 »
you can go for latest one from Qualcomm
zbelcas
« Reply #58 on: 03-November-15, 11:04:23 »
Tnx Svet.  Can anyone supply a link to directly download the latest Qualcomm driver?  I've poked around and have only found nonofficial sites...
  • T9246ED
  • Administrator
zbelcas
« Reply #60 on: 03-November-15, 14:42:33 »
Hate to be the noob here.  Tnx to you Svet, I found the latest Win7_64 drivers.  3 files but no installer.  How do I load these if I haven't loaded some other NIC driver first.  Device manager?  Will it show a default NIC?  Tnx much for the help!
  • T9246ED
  • Administrator
« Reply #61 on: 04-November-15, 05:33:14 »
you mean Standard Drivers (no Killer features) or?
zbelcas
« Reply #62 on: 04-November-15, 07:54:14 »
right, standard drivers without Killer features.  have win7_64 os so downloaded the ke2200w7 files via the link you passed along.  will the os have a default NIC driver that I replace or is there some other method for installing the ke2200w7 files?  tnx again..
  • T9246ED
  • Administrator
« Reply #63 on: 04-November-15, 07:58:29 »
you have to go to device manager to locate your device with yellow mark or the network killer card,
then to right click and to point to the folder where those files are located and to select the .inf file from there.
D4rKy
  • STAFF SERGEANT
« Reply #64 on: 17-November-15, 12:29:14 »
Could someone have Killer Cleaner 64 bit link download ? the link in this post is not available anymore ? :(
i am experience similar problems now if i download over 20 mbs per sec my network goes down, then it says my router is defect, i did not had this problem before with my x79 mainbord how do i fix this ?
I am using wired lan cable btw.
5930k @ stock // Corsair h110i GTX // MSI Godlike // Vengeance LPX 16 GB DDR4 2133 // Gigabyte G1 GTX 980 Ti SLI // Corsair AX 1500 // Crucial M5 480 GB // Samsung S27A950D //Thermaltake Core V71  // Windows 7 Ultimate // Logitech Orion Spark // Logitech G400S // Creative Gigaworks T3.
  • 微星科技
« Reply #65 on: 18-November-15, 11:00:50 »
Open an own topic.
Windows 10 Pro
MSI MAG BUNKER Case
agatenby
  • CORPORAL
« Reply #66 on: 30-December-15, 16:29:54 »
Is this still an issue or has MSI updated the killer suite so that all is well and safe to install?
Nichrome
« Reply #67 on: 30-December-15, 17:24:46 »
Hi
It's rather random issue, and most commonly: caused by the whole suite (whereas installing just driver works perfectly fine).
agatenby
  • CORPORAL
« Reply #68 on: 30-December-15, 18:54:27 »
Okay, thank you
barrekj
« Reply #69 on: 16-February-16, 20:24:39 »
Hi I am having the same problem with the killer network built in Lan.
My motherboard is the MSI Z97A Gaming 6 Motherboard.
I did everything that was suggested with no luck to fix it  :(  it keeps going out on me  :(
I did disable the on board Lan and and uninstalled all software and drivers then I went and got this Linksys USB3GIG USB 3.0 Gigabit Ethernet Adapter.
Now that USB Network Adapter is going out on me also,I don't know whats going on please help  :(  before anyone suggests it I am not going
to send it back just cause of the on board Lan,everything else works awesome  :)  its about a month old the motherboard I mean.
Curious could a bad network cable cause this problem? The network cable is about 3 years old or more,its CAT 5e Enhanced 500Mhz,I will be getting
CAT 7 sometime soon.
One more question in a few months I plan to get this Motherboard X99A GODLIKE GAMING Motherboard,does that have the same problems like the other boards with Killer Network?  I hope not for a board that is almost $600.
Or I might wait and get the X99A GODLIKE GAMING CARBON Motherboard.
Thank you in advance for the help.
My current system WIP; http://pcpartpicker.com/p/mnLmnQ
  • 微星科技
« Reply #70 on: 17-February-16, 22:38:49 »
barrekj, please open an own thread.
Windows 10 Pro
MSI MAG BUNKER Case
barrekj
« Reply #71 on: 19-February-16, 13:26:26 »
I will but may I ask why?  if I did that at other forums I would get yelled at for opening multiple forums for the same subject.
  • 微星科技
« Reply #72 on: 20-February-16, 04:49:46 »
Because the rules of this forum don't allow resurrecting old threads. especially when your issue is not really what the thread is about. >>Please read and comply with the Forum Rules.<<
Windows 10 Pro
MSI MAG BUNKER Case
chooxingyu
« Reply #73 on: 27-May-16, 08:49:11 »
Right,
Heres the poop -
Have a nice day.
Hello! You seem like the one with the most experience with getting screwed over by killer products
My PC has been getting tons of BSODs nowadays and verifier.exe points towards a driver under killer e2200 found on my h87g43 gaming motherboard
Since there are only up to windows 8.1 64bit drivers (i am on windows 10 64bit)
Can i follow your instructions with windows 8.1 64bit drivers instead?
And how do i actually delete the killer thingy in the regedit?
evan2024
« Reply #74 on: 04-June-16, 15:49:11 »
I've been lurking here for the past couple of days trying to find a solution to my own problem. I have found a solution for myself and want to share with this forum.
The system: Intel 5930K, Noctua NH-D15s, nVidia GTX 1080 SLI x2, Corsair Vengeance 2666MHz 32GB RAM, Samsung 950 PRO NVMe SSD, MSI X99A Godlike Gaming Carbon, Windows 10 64bit
The problem: Killer AC Wireless 1535 module was not recognized after install of drivers (not visible in Device Manager, taskbar, or Killer application).  Tried drivers from Killer's website as well as the official MSI Godlike Carbon motherboard downloads page. All drivers allowed me to use the Ethernet ports properly but not the wireless.
The solution: After uninstalling all Killer software via 'Programs and Features', the wireless was finally discovered by Windows for some reason but I did not have access to the Ethernet at that point. To regain Ethernet ports functionality, I tried installing the drivers again but I then lost wireless again. So I uninstalled again to restore proper wireless function. THIS TIME I downloaded the "Standard Drivers (no Killer features)" drivers from KillerNetworking.com (http://www.killernetworking.com/support/driver-downloads/standard-drivers). You must install these manually in Device Manager by right-clicking the hardware with the yellow ! error next to it and selecting correct driver folder from your disk. This allowed me to keep all networking ports functional but I do not have access to Killer's networking application.
Note: My problem was limited to the Killer Wifi module not being recognized in Windows 10 with official drivers. My problem was not BSODs or any instability like some on this forum have experienced. This may or may not fix those problems.
wildbillyhd1080p
« Reply #75 on: 08-June-16, 02:53:11 »
I'm having problems with drop-outs in audio or video with Killer e2200. Those Killer Cleaner link are returning a "404 Not Found" Error. Can we please get a new link?
m-bimmer
  • CORPORAL
« Reply #76 on: 29-June-16, 05:14:17 »
Have the exact same issue (with Killer AC Wireless 1535), after a windows 10 update, the wifi connection was completely gone from Network and sharing center, taskbar and killer manager application) but I found it hidden in control panel so I uninstalled its driver.
After uninstalling the Killer software via 'Programs and Features' I still have another one with an old version (Strange) which can not be uninstalled. I guess I have to use the killer cleaner to get rid of it first then follow your steps above. Hopefully, it will work. Fingers crossed.
Yep back to windows after 10 years and bios error 1 is the first thing to see after windows 10 intial setup and wifi is gone after a windows update. How Lovely
MSI Nightblade X2-056EU:
CPU: Intel(R) Core(TM) i7-6700K  @ 4.00 GHz
VGA: Nvidia GTX 980 Ti 500W, DDR5 6GB
SSD/HDD: M.2 PCIe SSD 512GB / 4TB SSHD
Memory: 16 GB DDR4 @ 2133 MHz
BIOS Version: EB106IMS.80F (Build date 10/06/2015), ME version 11.0.0.1178, EC version: 150922.0
OS: Windows 10 Home
Mouse: Mircrosoft Surface mouse & Logitech G502 Protesus Specturum
Wheel:
 Fanatec Clubsport Pedals V3 + Thrustmaster T300RS with Ferrari 599 evo wheel
Keyboard: Microsoft Surface keyboard
Screen: Alienware AW3418dw (3440x1440)
Sound System: Harman Kardon Soundsticks ii
m-bimmer
  • CORPORAL
« Reply #77 on: 30-June-16, 03:52:12 »
   Quote from: mh.emara on Wed Jun 29 2016 12:14:17 GMT+0200 (W. Europe Standard Time)
Killer cleaner does not work to take away that sticky old killer performance suite (1.56.xxx) in programs. Starting a new thread....
OS: Windows 10 Home
Wheel:
armyndefamily
« Reply #78 on: 10-July-16, 00:40:08 »
I have an MSI Z97 Gaming 5 and would like to know what is currently considered the best driver option for the Killer NIC. I'm running Windows 7 64 bit.
Some time has gone by and driver updates have come out so I'm wondering if opinions have changed.
Should I run the whole Killer Suite, just the Killer driver or the Atheros driver?
I'm actually not a heavy gamer, but do some gaming. I talk to my friend a ton on Skype, like hours a day steady. Lots of web browsing and some streaming.
Stability is actually more important to me than raw performance and I want a connection that won't drop randomly while I'm streaming or Skyping.
Thanks in advance for suggestions and feedback!
  • T9246ED
  • Administrator
« Reply #79 on: 10-July-16, 06:39:22 »
i would suggest using standard killer drivers:
http://www.killernetworking.com/product-support/driver-downloads/standard-drivers
they are troubles free
armyndefamily
« Reply #80 on: 10-July-16, 12:00:10 »
So definitely don't bother with the Atheros drivers then? Just curious because isn't the Killer driver, even without the suite, still optimized to prioritize gaming traffic?
  • T9246ED
  • Administrator
« Reply #81 on: 10-July-16, 13:34:32 »
no, standard drivers don't control anything
armyndefamily
« Reply #82 on: 10-July-16, 14:08:38 »
OK I'll take your advice then, but I have 1 last question just because I'm curious.
I compared the new bare Killer driver to the Atheros driver and it's the same 3 files types. A .cat file, an .inf file and a .sys file. The Killer files are all way smaller than the Atheros files, like super tiny. Any idea why? Are the Atheros drivers really bloated or something?
I just like to learn any time I can and am just asking the question to gain information and knowledge.
Thanks for your help!
  • T9246ED
  • Administrator
« Reply #83 on: 10-July-16, 14:09:26 »
which Atheros drivers you mean?
armyndefamily
« Reply #84 on: 10-July-16, 14:24:22 »
If you look at post #19 in this thread, I followed their information and links.
Not sure if I can link other sites here, but the post and download link for the Atheros drivers which now cannot be obtained directly from Qualcom, can be found by doing the google search suggested in post #19 and will take you to a forum post on techpowerup.
Reviews I've read around the web about those drivers all seem to be very positive and that is why I am so curious about all this information.
  • T9246ED
  • Administrator
« Reply #85 on: 10-July-16, 14:30:10 »
dunno can't comment such modification,
but official one stand alone drivers are working fine
armyndefamily
« Reply #86 on: 10-July-16, 14:39:05 »
Oh no, I don't think they are modded drivers, just older drivers that people claim are very stable.
Anyway I won't worry about trying to use those drivers unless I have issues. Instead I will use the ones you suggested. Thank you for replying to all my questions. :)
Also in the future I will update in this thread to let people know the results I get with the drivers you suggested in case others have concerns and want confidence about them working well.
valyyapryadko
« Reply #87 on: 12-October-16, 17:35:30 »
Hello
Since 9 hours without any breaks i've been searching forums trying different solutions to fix my !!!!!IRQL_ NOT LESS OR EQUAL!!!! problem at windows 10 running system with i7 6700k msg gaming M7 motherboard.Rams work fine as i can see them on bios and they are totally new. Yesterday For installing Gears of War 4 i deleted Killer network suite then i decided to instal Suite again because i didn't know it causes that much problems.. then msi app wanted to restart comp, then BSOD all attempts.==== Can't format my hard drives with windows 10 neither windows 8 dvds coz each attempt i can't reach any screen instead that error page IRQL_ NOT LESS OR EQUAL!! Also Can't run my pc on safe mode  .Also I tried disable network lan from bios and it didn't work out as well. I'm stucked. Please suggest me some solutions.
sp00kz
« Reply #88 on: 13-October-16, 18:27:14 »
It doesn't work... I've uninstalled the old driver and the Killer Suit, used the Killer Cleaner and installed the new driver from the "Killer E220x/Win7"-Folder. The installation worked fine but it seems that there is no lan-connection. Before, with the old driver, I had a ping about 17, download speed about 12mb and upload speed 1mb. Now I have a ping about 52, download speed 5mb and a upload speed about 0.60mb. This is the same result as if I'm just connected with wLan.
By the way: I'm going through a dlan-adapter in the internet.
And before I had the problem that the connection has often disrupted for no reason and I had internet speed-drop downs.
Has somebody an idea?
First off, get rid of the powerline adapter.  Seriously, worst networking idea since token ring.  You're better off using 802.11B wireless.
If you prefer using a wired connection, I know I do, then pick up a cheap Intel NIC on amazon and disable the KillerNIC in the bios.  You'll save yourself a lot of time and a massive headache ;)
PCI Single Port NIC $26 https://www.amazon.com/dp/B00030DEQE/ref=wl_it_dp_o_pd_nS_ttl?_encoding=UTF8&colid=UN9DN32VCLVL&coliid=INIWTZ5R8CIMC
PCIe x1 Single Port NIC $27 https://www.amazon.com/dp/B001CY0P7G/ref=wl_it_dp_o_pd_S_ttl?_encoding=UTF8&colid=UN9DN32VCLVL&coliid=I334OUHYTJSMHS
PCIe x2 Dual Port NIC $24 https://www.amazon.com/dp/B004T01KOC/ref=wl_it_dp_o_pd_S_ttl?_encoding=UTF8&colid=35DW2KS7XDY27&coliid=I20VPZLQ6Q6OCF
cmaree076
« Reply #89 on: 22-January-17, 14:32:10 »
Hi guys
Just a useful tip that also might be causing this issue. I thought I also had this issue but it was something different entirely. After trying to re-install all the drivers and use killer cleaner, I discovered that my idiot brother blocked my network port on our router using a parental control application. I removed my PC from the list and then I got my internet connection back. Hope this helps you guys!
Motherboard: MSI Gaming 5
CPU: i5 4670k 3.4Ghz
RAM: Crucial Ballistix 16GB 1866Mhz
GPU: MSI GTX960 Gaming 2G
PSU: Gigabyte 650W
OS: Windows 7 64 Bit
TroyR
« Reply #90 on: 27-January-17, 13:54:05 »
This is why I have never purchased MSI with Killer softwares...Just a total turn off....!
Pages: 1 [2]  All   Go Up
