Author Topic: MSI R9 270x 2g gaming - artifacts in games  (Read 10632 times)
marandosTopic starter
  • CORPORAL
« on: 01-March-14, 18:12:50 »
Hi!
Like 2 weeks ago I bought whole new PC with r9 270x msi gaming 2g, I tried 4 games on this PC,  unfortunatelly in all games happened artifacts, no idea if its matter of optimalization of game or the drivers are still not good enough for all games or my card is defected...
The 4 games i tried to run are Guild Wars 2 , Battlefield 3 multiplayer and TERA:Rising, The Elder Scrolls Online. Artifacts are the worst in GW2, in other  games are not that annyoing, but still.... They start to show up randomly, sometime after 5 mins, other day after 30mins or 1hour. In TERA it happens not that often like in  GW2 tho.
Here are few screens from GW2 how it looks
In TERA i saw flashy blinking objects like trees or  white rocks like on my pic, red dot on chat is actually my fail of paint skill :s.
When i minimize game and then turn game again on fullscreen, the artifacts are gone and do not happen on desktop.
Is my bios the latest?
VRM Temperature in idle 38*C
During gaming my temperatures arent higher than 60, sometime 70*C. I didn't OC'ed my card or other components.
If i need to change bios and that would help please give me a guide for dummies ^^ never changed bios or vbios before ^^.
S/N of my card : 602-V303-13SB1312019731
Other parts of my PC:
Intel i5 4570
ASRock B85 Pro4
2x 4GB Crucial Ballistix Sport 1333MHz
XFX Pro Series 550W PSU 80+
Windows 7 64bit
I've ran Kombustor for about 15minutes, saw no flickering or artifacts tho.
I tried 13,101 and 14,1 betas Catalysts but didnt used driver sweeper, should I give it a try?
If there are people around who had artifacting problems with r9 200 series and fixed it, would be nice if will speak here ^^.
Sorry if I made a mistakes, English is not my first language :P.
  • 微星科技
Re: MSI R9 270x 2g gaming - artifacts in games
« Reply #1 on: 02-March-14, 06:10:16 »
we can't tell without the actual vbios. A GPU-Z screenshot is useless. Save the vbios to file, upload it to some filehoster and add link here.
AMD Ryzen 9 3900X
Windows 10 Pro
  • CORPORAL
« Reply #2 on: 02-March-14, 07:12:31 »
Thanks for reply!  :grin:
Here it is :)
dropbox(dot)com/s/ryvgniiynhc8cdx/Pitcairn.rom
ANy ideas what can help solve my problem?
  • 微星科技
« Reply #3 on: 02-March-14, 09:30:08 »
Vbios is latest already (TV303MH.102). Try removing current amd driver in safemode using >>Driver Fusion<<. After reboot install latest MSI driver: http://download.msi.com/dvr_exe/AMD_13101_78_vga.zip
Also update the Asrock board's bios to the latest version.
AMD Ryzen 9 3900X
Windows 10 Pro
  • CORPORAL
« Reply #4 on: 02-March-14, 13:26:49 »
I deleted amd driver in safemode using Driver Fusion. After reboot I tried to install the MSI driver that you linked me, after installing it, my CCC didn't run, i was getting error saying :" You can not run the Catalyst Control Center. At this time in the Catalyst Control Center no settings that you can configure". Still I tried to test any game, went to Guild Wars 2, but after few minutes artifacts happened,  like on the screen I posted.  Then I deleted drivers again and went to install amd catalyst 14,2 v1.3 beta, here CCC was working without problems, but still after some playing in Guild Wars 2, I had artifacts.....
About motherboard bios is up to date as I saw.
Is there anything I can still try? Or theres nothing left than sending my card back? I am only scared, that if I send my card to the shop I bought , they might not find any problem, as I said, it not always happen in same minute of gameplay... Can I contact straight to MSI Poland so they maybe make any experienced way diagnosis?
  • 微星科技
« Reply #5 on: 02-March-14, 13:44:43 »
run memtest86 and check for mem errors. Also run attached IntelBurn Test on maximum stress level to check for general stability besides vga.
For contacting MSi you can do so: >>How to contact MSI.<<. None the less rma has to be issued via the reseller.
AMD Ryzen 9 3900X
Windows 10 Pro
  • CORPORAL
« Reply #6 on: 08-March-14, 06:43:39 »
Hi! Wasn't able to try memtest and IntelBurn in last days, today I tried it, memtest 2 passes 0errors, haven't tried more.  This took around 2 hours
I did Intel Burn aswell, 10 tries(not sure how much tries should I set, on the internet i've read 5-20 tries is enough (?) ), stress level max with all threads, thats are right options to do it?
Results were 3.079271e-002  so CPU seems to be stable.
I think I will run 3dmark 2013 also, to check if I get artifacts. I did 3dmark 2013 , my results:
http://www.3dmark.com/3dm/2618832
Any other ideas? Should I try newest drivers from AMD, or wait for MSI driver for this card, any info when they will release something new? or my last way is just RMA card and hope for new one or for getting my money back?
  • CORPORAL
« Reply #7 on: 10-March-14, 10:17:28 »
I did Valley Benchmark also....
Artifacts occured after like 5-10 mins running in benchmark on extreme hd options..... It happened in round2 of benchmark. In round 1 nothing happened...
Do I got anything left than sending back my card to shop where I bought it?
  • 微星科技
« Reply #8 on: 10-March-14, 12:30:13 »
 :think: I can't see any artifacts in the screenshots
AMD Ryzen 9 3900X
Windows 10 Pro
  • CORPORAL
« Reply #9 on: 10-March-14, 14:06:32 »
K I marked the places where you can see artifacts, (white stuff on hills, looks similiar to GW2 case)  white lines lengthening
Other screen without artifact to see diffrence
Was hard to catch at screens, probably video would show it better.
  • 微星科技
« Reply #10 on: 11-March-14, 11:31:11 »
Try the latest beta driver (14.2) after driver removal like suggested before: http://support.amd.com/de-de/download/desktop?os=Windows+7+-+64
AMD Ryzen 9 3900X
Windows 10 Pro
  • CORPORAL
« Reply #11 on: 12-March-14, 11:43:31 »
Still some weird things during benchmark...
Blue blinking grass...
Some weird blinking things....
- here clean screen to compare with last screen...
Any suggestions :(?
  • T9246ED
  • Administrator
« Reply #12 on: 12-March-14, 12:32:59 »
looks like the card is defective or the PSU [XFX] is make some weird things,
can you test the card in another PC?
  • CORPORAL
« Reply #13 on: 12-March-14, 12:41:15 »
Unfortunatelly nope, can't test other GPU or PSU. This only happens in games / benchmarks, on desktop everything is fine. For me it seems more like defective GPU, like I said, artifacts are gone when I minimize game and put it back on fullscreen, then I got some minutes of gameplay without this weird problem.
  • T9246ED
  • Administrator
« Reply #14 on: 12-March-14, 12:42:42 »
well then you have limited options,
RMA the VGA and see how its goes, but if the problem is not in the card the problem will persist.
  • CORPORAL
« Reply #15 on: 12-March-14, 12:48:52 »
Yes, I think I will RMA this card at first. My CPU got integrated graphics so I will be still able to use my computer and hope for just faulty of GPU.
I would prefer to get money back, so I am thinking to go with "green side" this time, saw too much problems with whole R9 series...
  • CORPORAL
« Reply #16 on: 15-March-14, 12:11:47 »
Hey!
I am refreshing because I found something interesting, I hope this will help to find issue with what's going on, as I still didn't contacted with shop. I did full format and installed Windows 8.1 Pro x64. I've tried to install  MSI Graphics Driver 13.101 from MSI site, after extracting it and installing, CCC didn't work, I was getting error saying :" You can not run the Catalyst Control Center. At this time in the Catalyst Control Center, no settings that you can configure" I was getting same thing on Windows 7 x64, so I guess that's something wrong with MSI files, I did some searching and I found that this error can be caused because corrupted files. Is there any other way to get MSI Drivers from other links or so? Would appreciate it to try it out.
After that, I uninstalled this MSI 13,101 and installed AMD 13.12 without problems. Then I ran Valley Benchmarks again, here I noticed something, my vsync was turned off and these strange problems like in last screens I posted still occured. After turning on VSYNC in valley benchmark, it seems like my problems stopped. Then I tried same in Guild Wars 2, seems like it working aswell, was running for around 1 hour for 2 days without problems.  I believe it should work without vsync, shouldn't it? Playing with vsync is always the way, but it reduces my frames by alot....
What you guys think about that?  Someone got any idea whats happening? Might this be still defective card or it's just problems with software of game or drivers? Or maybe its something with GPU and my monitor? If so, my monitor is : LG IPS LED 22EA53.
I don't know what to do now, hope you will help fix it out, as im not sure now if I should still think about sending back my card?....
a00r
  • CORPORAL
« Reply #17 on: 15-March-14, 12:30:39 »
well my r9 270x I got first one was defective... rma it got another and now it seems to be bad as well...
Main Board: MSI Z77A-G45
Bios Version:Version: V2.12, (9/29/2013)
Video Card: msi R9 270X Hawk
PSU: 650W TX650 V2 PSU 80 PLUS Bronzw
12v rail Rating of listed PSU: +12V@53A, -12V@0.8A
CPU: Intel Core i5-3570K CPU @ 3.40GHz, LGA 1155, 77W
Memory: Corsair Vengeance 16GB (2x8GB) DDR3 1600 MHz (PC3 12800)
SSD/ HDD: 120GB SSD, 1TB HDD, 150GB HDD
CPU COOLER: Cooler Master Hyper 212 EVO
OC:No
Operating System: Win 8 Pro 64bit
http://valid.canardpc.com/ub5mlf
alfredo.arguello
« Reply #18 on: 16-March-14, 17:56:20 »
I have the same problem, msi r9 270x gaming g2 with artifacts, they appears while I'm playing dota2, bf4, hawken, ac iv... I'm tested the card with 13.10 and 13.12 driver, indeed with the official what come at the CD. but the artifacts appears anyway. I'm from Venezuela and I'm very scared for the RMA issues what i can will get. because i bought it at amazon but i have all the purchase proof. right now I'm downloading the beta 14.2 amd drivers.
alfredo.arguello
« Reply #19 on: 16-March-14, 21:23:39 »
this happens with many games. in already test the card with 13.10, 13.12 and 14.12 beta, all with the display driver unistaller aplicated before. the card's bios is untouched.
onedrive.live (DOT) com/redir?resid=6195077AD9BFE884%21186
  • 微星科技
« Reply #20 on: 17-March-14, 16:06:49 »
Artifacts can be caused by various issues. For your own issue open an own topic.
AMD Ryzen 9 3900X
Windows 10 Pro
  • CORPORAL
« Reply #21 on: 22-March-14, 17:18:24 »
I've played Need For Speed Rivals, it just uses 30% of gpu as I saw, due to fps limit in game (30) and still shows up artifacts. Guess I'll send card for RMA in 2 days, or still someone have any idea whats going on? Card is not overheating btw.
