Author Topic: How can I create the recovery discs for my AIO computer? (For Windows 7 systems)  (Read 4178 times)
SvetTopic starter
  • T9246ED
  • Administrator
  • Online Online
Q.: How can I create the recovery discs for my MSI laptop/AIO computer? (For Windows 7 systems)
A.:
1. Locate the "MSI BurnRecovery" shortcut on your desktop or start menu. Run this program. (Note: If UAC is enabled, press "Yes" to allow the program to run.
2. MSI BurnRecovery will prepare the files. This process may take a few minutes.
3. Click on "Next" to continue.
4. Click on "Advanced".
5. Click on "Create an ISO file for the recovery disc".
6. Select the destination where you want to create the ISO files. (Default is the D: drive)
7. The program will now create the ISO files. This process may take up to 20 minutes.
8. Click on "Finish". Make sure the box is unchecked.
9. Browse to the location of the ISO files. Double-click the recovery_dvd file. (Note: Depending on your system, you will have 1-3 recovery_dvd files)
10. Insert a blank DVD (If the AutoPlay window pops-up, close it). Click on "Burn". It is also recommended to check the box to verify disc after burning.
11. After burn is complete, click on "Close".
12. Double-click the recovery_dvd2 file.
13. Insert a blank DVD (If the AutoPlay window pops-up, close it). Click on "Burn". It is also recommended to check the box to verify disc after burning.
14. After burn is complete, click on "Close". Recovery disc creation is now complete. (You can also delete the ISO files, but it is recommended to keep them)
