Author Topic: 4.4 firmware for Me Prime 8 Tablet  (Read 4311 times)
AllanATopic starter
« on: 23-September-14, 07:46:15 »
Hello guys,i have a Me Prime 8 Tablet which is exactly same looks and specs as the MSI Primo 81 tablet. I tried flashing the 4.4 update firmware of the MSI Primo 81 tablet on my Me Prime 8 tablet and it worked! Only proble is that the screen orientation and the gsensor is not working.Is there a fix on it?and also is there any other firmware which is suitable for my tablet?hoping you guys can help me.thanks in advance.
Nichrome
Re: 4.4 firmware for Me Prime 8 Tablet
« Reply #1 on: 23-September-14, 10:49:00 »
Bump removed. Please read forum rules.
Try to flash back to the original that was designed for your tablet, not for the only one. There had been a reason of making 8 and 8.1 different.
AllanATopic starter
« Reply #2 on: 23-September-14, 18:16:57 »
ok sir,thanks.luckily i have a stock rom.just wanna try the 4.4 update.i guess i'll have to google for other similar 4.4 firmware that might work on my tablet.
janalbert.alvarez
« Reply #3 on: 16-February-15, 03:47:03 »
good day! pwede po ba mahingi stock firmware ng me mobile prime 8 please?
KurtC27
  • SECOND LIEUTENANT
« Reply #4 on: 16-February-15, 23:12:36 »
Me Prime 8 Tablet is not MSI brand product through it's a OEM/ODM product by MSI.
You should contact ME Mobile instead not asking a new FW update here.
monster6536
« Reply #5 on: 21-August-15, 12:16:49 »
Hello Allan!
Can you please share the stock firmware of your tablet. I wasn't able to backup mine. And there is no firmware available for this online.
I hope you will read this message.
