Pages: 1 [2]  All   Go Down
Author Topic: Unigine Valley Benchmarks - Extreme HD  (Read 40884 times)
Simon719
  • SERGEANT
Re: Unigine Valley Benchmarks - Extreme HD
« Reply #50 on: 10-November-14, 11:42:38 »
A bit more tweaking, wont get more I reckon without voltage increase? these are the newer 344.65 drivers
CPU - Intel 5930k
MOBO -ASUS X99-S (bios 1601)
GPU - - MSI GTX 970 gaming x2
RAM -16Gb DDR4 2400Mhz
HDD1 - 2x 240 SSD in Raid0
HDD2 - 2TB HDD
PSU- Antec 1000w true power
CASE - Cooler master  HAF X Gaming Tower Case
OS - windows 7 64 bit
  • 微星科技
« Reply #51 on: 10-November-14, 12:08:15 »
Also tweaked some more:
Windows 10 Pro
MSI MAG BUNKER Case
Simon719
  • SERGEANT
« Reply #52 on: 10-November-14, 12:47:03 »
wonder why your max and min are lower than mine, yet score is higher?
I don't think i will bother anymore though, as I will need to up the voltage and am very happy with my in game speeds with thses two cheap cards, in fact they are so cheap I might even try a triple set up at some point lol ;)
CPU - Intel 5930k
HDD2 - 2TB HDD
  • 微星科技
« Reply #53 on: 10-November-14, 13:53:55 »
Because min and max have little relevance. The average fps (what is relevant for gaming speed) are higher.
Windows 10 Pro
MSI MAG BUNKER Case
jpouza
  • CORPORAL
« Reply #54 on: 10-November-14, 14:43:26 »
LOL, this benchmark is such a joke, poorly optimized for high end systems, I see my 3x980 clocked above 1550MHz laughing at 48ºC in my EK WC system, GPU utilization is poor, 43% to 93% max....very bad software...I get average 5400 points in 1080p@max settings, really a joke.
Please use a decent bench tool such as 3DMark.
I can get almost 30k points in FireStrike performance mode.
Cheers
3x980GTX@1500MHz by EK Watercooler system 480mm Rad.
  • 微星科技
« Reply #55 on: 10-November-14, 14:46:00 »
3DMark is decent?  :lol_anim: Unlike 3D Mark Valley shows a realistic gaming performance.
Windows 10 Pro
MSI MAG BUNKER Case
Simon719
  • SERGEANT
« Reply #56 on: 10-November-14, 14:58:53 »
Not Sure it does because I get better performance in games than my mates 780 and also score higher in fire strike so I reckon jp has a point Lol  ;D
CPU - Intel 5930k
HDD2 - 2TB HDD
jpouza
  • CORPORAL
« Reply #57 on: 10-November-14, 15:03:43 »
3DMark is not a perfect tool but uses 3 and 4way SLI better, scales much better.
Oh yeah, so the realistic gaming performance bench says that 3x980 watercooled = 2x970 air cooled? LOL
I don't care about 1080p, even Ultra HD, only 4K matters from now on.
Try to play Crysis 3 at 4K resolution, all settings maximum at 80-90 fps on 2x970 please, then you will remember the days when a 486 DX4 100MHz run slowly Quake 1 via soft mode and a Pentium 166-200MHz was the phenomenal beast of that time. :)
I once had 2x970 EVGA SC ACX 1.0, I know a little what realistic gaming performance is, specially when you play at high resolutions aka 4K with all settings EXTREME.
Cheers
  • 微星科技
« Reply #58 on: 10-November-14, 15:08:22 »
I have two 780ti. They are way faster than 780s and more powerful than a 970 so our cards should perform as seen.
Windows 10 Pro
MSI MAG BUNKER Case
Simon719
  • SERGEANT
« Reply #59 on: 10-November-14, 15:13:02 »
Whew I say 780 and meant of course the ti, same or less than mine and way less than 3×980
CPU - Intel 5930k
HDD2 - 2TB HDD
Simon719
  • SERGEANT
« Reply #60 on: 10-November-14, 15:14:14 »
Well our scores here are almost the same and to close to call, what is your fire strike score?
CPU - Intel 5930k
HDD2 - 2TB HDD
  • 微星科技
« Reply #61 on: 11-November-14, 12:55:04 »
Well, I don't use 3D Mark. Simply check the various reviews of GTX 970 and 980s for comparisons with 780ti.
Windows 10 Pro
MSI MAG BUNKER Case
Simon719
  • SERGEANT
« Reply #62 on: 11-November-14, 13:32:33 »
I have read loads of reviews and done benchmark tests in games along with mates and the 780ti and GTX970 are almost the same in performance (780ti scores a little better in some, but not much more than 970) + (970 cheaper, uses less power and also heat) the GTX980 is superior in all test I have seen to the 780ti, the 980ti will be out soon too on a 384bit bus maybe? and be even better :)
I was going to upgrade from my HD6950 crossfire system to two 780ti in SLI, then I read tests and realised i would better going for two GTX970's, which i did, the really crazy thing is you can buy 3x970 for the same price of 2x980 and 2x780ti (they might be a bit cheaper now than they were?) and the tri 970 are much faster than both, for less money...awesome the future isn;t it lol ;)
 But anyway my valley score above is within 1.4% of yours, so I am happy I made the correct choice  :biggthumbsup: a third one will be on the way soon (or i might just check out the 980ti first lol)
CPU - Intel 5930k
HDD2 - 2TB HDD
  • 微星科技
« Reply #63 on: 11-November-14, 15:18:29 »
The price and low power consumption of 970 is great, considering power the same needs to be said for 980. If already owning a 780ti like me neither is an upgrade option considering performance. "980ti" will be more interesting in this regrad.
Anyway this thread has gone far off topic so lets stick with what this thread is about -> Unigine Valley Benchmarks in Extreme HD
Windows 10 Pro
MSI MAG BUNKER Case
effland253
« Reply #64 on: 17-January-15, 01:27:00 »
Now for a baby Maxwell - MSI Twin Frozr Gaming GTX 750 Ti OC that only uses 60 watts. My whole PC only uses a little over 150 watts at AC wall outlet (Kill A  Watt meter). On bumped up overclock settings temperature peaks at 53 C with quiet fans automatically bumping up 2% to 34% max.
Unigine Valley Benchmark 1.0
Defaults | GPU +220, MEM +220 MHz
FPS:21.624.7
Score:9041034
Min FPS:12.513.5
Max FPS:39.045.2
System
Platform: Windows 7 (build 7601, Service Pack 1) 64bit
CPU model: Intel(R) Core(TM) i5 CPU 650 @ 3.20GHz (3191MHz) x2
GPU model: NVIDIA GeForce GTX 750 Ti 9.18.13.4709 (2048MB) x1
Settings
Render:   Direct3D11
Mode: 1920x1080 8xAA fullscreen
Preset Extreme HD
UBUNTU 14.04.1
FPS:19.021.6
Score:795902
Min FPS:11.413.1
Max FPS:32.737.2
System
Platform: Linux 3.13.0-44-generic x86_64
CPU model: Intel(R) Core(TM) i5 CPU 650 @ 3.20GHz (3191MHz) x4
GPU model: GeForce GTX 750 Ti PCI Express 340.65 (2048MB) x1
Settings
Render:   OpenGL
Preset Extreme HD
Since my system only used about 206 watts max AC input with 116 watt GTX 550 Ti without any issues I am tempted to try a GTX 970 (145 watts) to see if that would work with my existing system without having to bump up my PSU. It is a Dell XPS 8100 that I think has a conservatively rated 350 watt PSU, but Dell never mentioned its PSU rating in spec's (originally just had GT 220 video).
i5 650 3.2 GHz, 8 GB, MSI GTX 750 Ti OC, 32" 1080p HDTV
MSI GE60 20E i7 4700MQ, 8 GB, Nvidia GTX 765m
64-bit Ubuntu 14.04 Linux & 64-bit Win7
cubetrou
  • Heh !
« Reply #65 on: 21-September-15, 23:46:55 »
Thank you
Phenom II X6 1055T
GIGABYTE 78LMT-S2
MSI Gaming R9 290 OC
CoolerMaster G650M
Sharkoon ATX Rebel9
gjbeaudry
  • Mastodon
« Reply #66 on: 16-October-15, 23:17:35 »
So Before I completely clean out my PC tomorrow , its very dust and its definitely time to reinstall windows and then I will install my new MSI R9 390. I thought would run a few final benchmarks on my GTX 660 SLI Rig, it has served me well but 2GB of VRam just dose not cut it anymore. I was pretty surprised with the scores,( I ran about 5 and posted the best all were with in 200 points).
I couldn't believe it beat out a few non oc GTX 970 rigs. These card still have some decent power. I will run a bunch of benchmarks once I get the new card in but I will Probably make a new Thread for that. this one is getting old.
I7-4790K
MSI R9 390
Asus ROG Maximums VI Formula
Antec  Kuhler 920
12 GB DDR3 @ 1600 Mhz
120 GB Sata 6 SSD  X2
1 TB HDD
Blueray/DVD RW
Thermaltake Chaser MK-I
Razer BlackWidow Chroma
Razer DeathAdder Chroma
Nichrome
« Reply #67 on: 17-October-15, 03:06:06 »
Very commonly SLI even from such old series is better than single card. Although it is also matter of processor used in some areas.
emir_1555
  • Imitation is the sincerest form of flattery.
« Reply #68 on: 31-March-16, 14:53:55 »
This is mine. :)
My System Details;
 - CPU: İntel Core i5 6600 3.3GHz
 - Motherboard: MSI Z170A Gaming M3
 - Graphic Card: MSI GTX 960 Gaming 4G
 - RAM: 1x8GB Kingston HyperX Fury DDR4 2666MHz
 - Case: Corsair Carbide Champ Spec-02
 - PSU: Corsair 80+ VS650
 - SSD: Samsung 120GB 850 Evo SSD
 - HDD1: Seagate Barracuda 1TB 7200Rpm
 - HDD2: Toshiba Satellite 1TB USB 3.0 (Portable)
 - DVD Writer: Asus DRW-24F1MT
 - Monitor: Asus VX239H FHD AH-IPS
  • 微星科技
« Reply #69 on: 01-April-16, 00:49:35 »
You are not using Extreme HD preset. This is only for Extreme HD.
Windows 10 Pro
MSI MAG BUNKER Case
justin.ashburn74
« Reply #70 on: 03-April-16, 07:30:13 »
Here's mine (updated with Valley instead of Heaven).  [ ERROR: SPECIFIED ATTACHMENT MISSING ]
System:
i7 6700k @4.2ghz
Gigabyte GA-Z170X Gaming G1 Motherboard
32gb G.Skill Ripjaws 3200mhz DDR4
3x MSI GTX980 Gaming 4G Tri-SLI
512gb Samsung 950 Pro
1tb Samsung 850 Evo
2x Seagate 4tb SSHD Raid 1
Fractal Design Define XL R2 Case
Arctic Cooling Liquid Freezer 240 CPU cooler
  • 微星科技
« Reply #71 on: 03-April-16, 07:37:45 »
That's also not Extreme HD...
Windows 10 Pro
MSI MAG BUNKER Case
justin.ashburn74
« Reply #72 on: 03-April-16, 07:40:12 »
Ahh, just noticed this is for Valley and mine is Heaven. Brb...
System:
i7 6700k @4.2ghz
1tb Samsung 850 Evo
  • 微星科技
« Reply #73 on: 03-April-16, 07:41:09 »
Yes, all wrong then.
Windows 10 Pro
MSI MAG BUNKER Case
justin.ashburn74
« Reply #74 on: 03-April-16, 07:49:08 »
Fixed!
System:
i7 6700k @4.2ghz
1tb Samsung 850 Evo
  • 微星科技
« Reply #75 on: 03-April-16, 09:31:30 »
Aha, seems it doesn't scale well with tri-sli then. Considering three 980 the result is not too groundbreaking. We had better results with 2x 780ti or 2x GTX 970
Windows 10 Pro
MSI MAG BUNKER Case
justin.ashburn74
« Reply #76 on: 17-April-16, 15:02:08 »
Looks like it was my CPU holding me back. New mobo BIOS and OC'd to 4.6ghz and this is my new score. I agree this doesn't scale too well with 3 GPUs though.
System:
i7 6700k @4.2ghz
1tb Samsung 850 Evo
  • 微星科技
« Reply #77 on: 18-April-16, 14:04:49 »
Nice bump at least. I guess Full HD is also simply not demanding enough to make any use of three gpus.
Windows 10 Pro
MSI MAG BUNKER Case
xmad
  • Salisbury MD
« Reply #78 on: 08-May-16, 05:39:44 »
Valley result, no overclock on the cards except what it came with.
The heaven version is more demanding if you use Custom and max settings.
Mainboard: X79A-GD65 (8D)
CPU: I7-3930K
Setting: 2400 CL:10
SSD: Corsair GS 256GB
Corsair Link
Cooling: Corsair H100I
PC Guru
  • CORPORAL
« Reply #79 on: 05-July-16, 15:05:47 »
MSI X99A Godlike Gaming Carbon Motherboard (BIOS ver 2.30)
Intel Core i7 6950X 3.7GHz
Corsair Hydro Series™ H115i 280mm Extreme Performance Liquid CPU Cooler
Corsair Dominator® Platinum Series 128GB (8 x 16GB) DDR4 DRAM 2800MHz
MSI Seahawk NVIDIA GeForce GTX 980ti (x2 in SLI)
Crucial MX200 SSD 500GB (x2)
Seagate Desktop SSHD 4TB ST4000DX001 (x2)
Samsung 950 Pro M.2 512GB SSD (Boot Drive)
LG WH16NS40 Blu-Ray/DVD/RW/M–Disc ODD
Corsair AX1500i Power Supply
Windows 10 Pro x64
Samsung SyncMaster P2770FH 27" Widescreen LED LCD (HDMI)
Samsung 55-inch Smart TV (HDMI)
Sennheiser SD Office Wireless Headset
Dragon 14 Individual Professional
KnowBrainer Professional 2016
Logitech MK520 Mouse & Keyboard
Phanteks Enthoo Primo Special Edition Case
PC Guru
  • CORPORAL
« Reply #80 on: 05-July-16, 15:32:54 »
Windows 10 Pro x64
darren_lopez
« Reply #81 on: 26-October-16, 18:27:49 »
Why did my post on here get deleted?
Stuff:  i7 6700k @ 5 Ghz 1.43v Delidded | ASRock Z170M OC Formula ( M-ATX ) | G.Skill TridentZ 3600 c16 | Sea Hawk EK 1080 @ 2100 mhz  |  ROG Swift | R4 | EVGA 1000 P2 | 1080mm Radiator Custom Loop | HD800 + Asgard 2 + Modi 2 Uber | 850 Evo 1TB | 840 Pro 256GB | 3TB WD Blue | 2TB Barracuda
Hwbothttp://hwbot.org/user/lays/  FireStrike 980 ti @ 1800 Mhz  http://hwbot.org/submission/3183338 http://www.3dmark.com/3dm/11574089
Nichrome
« Reply #82 on: 27-October-16, 04:10:59 »
You are on MSI forum, not ASUS. So I guess that it is obvious, that in such thread, we expect MSI GPU results to be posted.
darren_lopez
« Reply #83 on: 27-October-16, 16:05:33 »
Aw I thought it was for all results, sorry.
me
« Reply #84 on: 24-February-17, 07:01:24 »
I can't link images yet because I'm a noob, but here's what I get:-
FPS 44.2
Score 1851
Min FPS 24.1
Max FPS 82.8
Platform Windows 7 SP1 64-bit
CPU: i5-2500k CPU @ 3.30GHZ
GPU: GTX 1050 ti  21.21.13.7866 (4095MB) x1
Render: Direct3D11
Preset: Extreme HD
thats the 1050 GTX Ti Gaming X 4GB gpu clock @2012
Memory clock @ 4Ghz
I'll update this when I'm no longer a total scrub
attentat22
« Reply #85 on: 20-June-18, 17:14:57 »
Here i come :pompom:.
Kinda creepy compared to the most of your scores.
  • 微星科技
« Reply #86 on: 21-June-18, 10:22:16 »
Doesn't make much sense without your pcs specs.
Windows 10 Pro
MSI MAG BUNKER Case
sudspeed
« Reply #87 on: 29-September-18, 15:42:35 »
would post up photo but i'll just put the details since i don't have the 10 post count requirement yet.
Unigine Valley benchmark
FPS:    77.6
Score: 3249
Min FPS: 21.3
Max FPS: 125.7
Platform: Win 8.1
CPU Model: AMD FX-8320E Eight-Core Processor (4113MHz) x4
GPU Model: NVIDIA GeForce GTX 1080 24.21.14.1163 (4095MB) x1
Render: Direct3D11
Mode: 1920x1080 8xAA Fullscreen
Preset: Extreme HD
have CPU OC'd to 4.1 Ghz, Ram oc'ed to around 2180MHZ GPU utilization primarily sticks around 67-72% with some scenes going up to 92% on an Asus M5A97 LE R2.0 board with a PCIE 2.0x16 slot ( pcie3 along with DDR4 and an intel would probably have me closer to 90s-100 FPS on the benchmark)
GPU only has +100 Memory and +50 core clock, for some reason this thing was hitting 2000MHZ out of the box turbo clock.
Pages: 1 [2]  All   Go Up
