Author Topic: Z97 Gaming 7 keyboard freezes at BIOs  (Read 2396 times)
mudyTopic starter
  • SERGEANT
« on: 20-October-14, 19:02:49 »
Hi just got the Z97 GAMING 7 motherboard couple of days ago and every time I apply a mild OC my keyboard freezes after 5-10 minutes of staying in the BIOS. Mild OC of 4/4.1GHz with 1.125vcore, for eg., renders my keyboard frozen and I've to press the reset button. This started happening since yesterday. Before this it never used to happen. The lights of the keyboard stays on, it even switches on/off when num lock is pressed, but nothing else responds, like the arrow key don't do anything!!
I'd this a known issue?? I did read some where that msi motherboards send to be having the USB issues but in not a hundred percent sure.
-------------------Uncle Devil-------------------
MOBO – MSI Z97 Gaming 7
CPU – Core i5 4690K @ 4.2GHz @ 1.125
CPU COOLER – Corsair H105
RAM – G.Skill TridentX 2400MHz DDR3 32GB
SSD – Samsung 840 Pro 512GB x2 in RAID0
GPU – GTX 780 Ti 3GB in SLI
CASE – Cooler Master HAF-X
PSU – Corsair AX1200i Watt
MONITOR – DELL U3011
JLio01
  • MAJOR
Re: Z97 Gaming 7 keyboard freezes at BIOs
« Reply #1 on: 20-October-14, 19:58:30 »
What's the BIOS ver.? Since you OCed your mobo, can't tell what causes the issue..try clear cmos
mudyTopic starter
  • SERGEANT
« Reply #2 on: 22-October-14, 02:33:55 »
I just updated to v1.7.
Nichrome
« Reply #3 on: 22-October-14, 02:56:09 »
Try to remove OC with >>Clear CMOS Guide<< and see if it works fine then
JLio01
  • MAJOR
« Reply #4 on: 22-October-14, 02:58:29 »
what's your keyboard then?
