Author Topic: MSI 970 Gaming 4G Fan problem  (Read 2608 times)
GothmothTopic starter
« on: 06-November-14, 12:46:34 »
got my 970 today....as you can see in the screenshot my fans are going ON then OFF all the time.
and the temps are not high enough so that the fan should start spinning at all.
Nichrome
Re: MSI 970 Gaming 4G Fan problem
« Reply #1 on: 06-November-14, 12:50:21 »
This seems to be the 0% fan mode. When did you buy the card? As for me this looks like MSI's solution towards non working fan at all.
« Reply #2 on: 06-November-14, 12:52:22 »
i ordered the card on 17 october and they was send from an amazon center in france this week to me in germany.
so i guess it´s a pretty new card. had the donut shaped fan sticker.
gpu-z says "revision A1".
no idea what other info could be helpfull.
i only wonder because all reviews say the fans should not be running under ~60° celsius.
Varg
  • SECOND LIEUTENANT
« Reply #3 on: 06-November-14, 13:00:38 »
This is a problem in the latest Nvidia drivers. Use 344.16 and the problem is gone.
Intel Core i7 4771| MSI Z87-G43| C300 256 GB| 2x Hitachi 7K4000 4TB| Corsair Vengeance Red 8GB DDR3-1600 CL7 | MSI GTX 970 Gaming| Creative Soundblaster Z| Logitech G51| Samsung SH-B123L| LG IPS277L| Arc Midi| Windows 8.1 Pro 64-bit NL
« Reply #4 on: 06-November-14, 13:02:26 »
mhm... can i use the latest nvidia driver too?
i was just downloading 344.60 for call of duty advanced warfare.
Varg
  • SECOND LIEUTENANT
« Reply #5 on: 06-November-14, 13:06:59 »
344.60 still has the same problem. Don't know why but both 344.48 and 344.60 have it.
« Reply #6 on: 06-November-14, 13:10:32 »
you are right just tried the 344.60 driver.... same issue. :-(
that can´t be good for the fans... it sure puts more stress on them than a constant running speed.
by the way: msi live update reports i have the NV316MH.180 bios.
