Pages: 1 ... 4 5 [6]   Go Down
Author Topic: Fix for GTX970/980 Fans Randomly Turning On issue  (Read 135978 times)
flobelixTopic starter
  • 微星科技
Re: Fix for GTX970/980 Fans Randomly Turning On issue
« Reply #250 on: 02-September-17, 16:36:56 »
Your post has obviously nothing at all to do with the topic "Fix for GTX970/980 Fans Randomly Turning On issue". This isn't a vbios update thread nor is it about gpu temps after reassembling. The temps are fine anyway. If you want to discuss anything about your card or you need help open an own thread.
AMD Ryzen 9 3900X
Windows 10 Pro
Pages: 1 ... 4 5 [6]   Go Up
