Author Topic: The Cause of the GTX 9x0 GAMING 4G's fan spinning issue  (Read 1546 times)
CeremonyTopic starter
This applies to all GTX 970 and 980 GAMING 4G cards and possible future models with the same fan (e.g. 8G):
The Issue:
Once the card goes above 60°C, the fans should kick in. However, sometimes, one of the fans is in a bad starting position and the initial starting voltage is not enough to start one of the fans, so it just twitches in place. The card assumes a fan failure and spins the other fan at 100% to counter a possible HW-failure of the card due to overheating. Additional, the noise gets the attention of the user!
The culprit:
Blame either cheap fans/motors or badly adjusted starting voltage! Either way, it's MSI fault :undecided:
The (semi) fix:
Give the fan that's not turning a jumpstart: Just get it to turn if ever so slightly and the built in motor should be able to continue turning it by itself!
This unfortunately isn't a fix, as it will most definitely occur again - at least once its rested. Over the months and years to come, this should be a more frequent issue than now - even for those that aren't plagued by this problem yet!
The real fix:
RMA the card or hope for a BIOS update that fixes the starting voltage of the fans - if that is even possible.
I hope this helps!
  • 微星科技
Re: The Cause of the GTX 9x0 GAMING 4G's fan spinning issue
« Reply #1 on: 16-November-14, 15:30:08 »
Thanks for contributing but this has been discussed over and over and everyone knows by now.
https://forum-en.msi.com/index.php?topic=184604.0
https://forum-en.msi.com/index.php?topic=183618.0
AMD Ryzen 9 3900X
Windows 10 Pro
« Reply #2 on: 16-November-14, 16:47:43 »
Sorry >_< Feel free to merge it with those threads then!
P.S. I guess RMAing is the way to go then?
Nichrome
« Reply #3 on: 16-November-14, 16:52:35 »
Yes RMA is the only way to do it, at least now.
« Reply #4 on: 16-November-14, 17:33:05 »
K sent in the RMA request (german MSI though). I expect a replacement with 0 downtime... This card is nearly brand new after all.
Also - has this issue been properly fixed in the new batch? As it seems to be a rather common issue that may occur over time... My last card is over 4 1/2 years old and was still working flawlessly before I sold it (the oven GTX480)
