Author Topic: CD-drive only works in PIO mode  (Read 2761 times)
kyaku00x
« on: 05-August-02, 00:30:31 »
that about says it, if i set it to DMA it vanishes. the drive is ms-8156 and my friend has the MSI DVD drive and it also has the same problem.we are running Windows XP. any suggestions please.
Wonkanoby
(No subject)
« Reply #1 on: 05-August-02, 00:34:13 »
  • Best Answer
  • hi
    are you using a modern 80 wire lead
    blue end to board
    P5Q Deluxe
    Intel QX 6700
    4GB OCZ
    60 GB Vertex drive
    ATI 5850
    kyaku00x
    (No subject)
    « Reply #2 on: 05-August-02, 00:37:10 »
    Yes.
    why? does it matter.
    duga
    (No subject)
    « Reply #3 on: 05-August-02, 01:28:55 »
    It hapens with some of ide controlers bad ide drivers for XP.
    I had that problem with Chaintech 7AJA2 and Teac 40X until I updated latest drivers for my MB.
    If that doesnt work try upgrading firmware of your CD drive.
    Foetsjie
    (No subject)
    « Reply #4 on: 14-August-02, 17:37:22 »
    Use a 80 wire ATA66 cable.
    Foetsjie
