Author Topic: MSI Mobile Workstation Animation Film Case Study  (Read 2675 times)
small starsTopic starter
« on: 24-September-13, 12:44:00 »
NBFOU
  • Notebook Moderator
« Reply #1 on: 24-September-13, 16:29:03 »
Quote from: small stars;49024
MSI GT70 2OK Workstation applied in animation film-MIDA. MSI Workstation play it's role in 3D Animation, motion capture, 3D holographic projection show by running software like Autodesk 3Ds Max, Maya, the Foundry Nuke. If you are planning to run any 3D animation software effectively on your workstation, you'll want to invest in a professional-level OpenGL graphics card like Quadro K3100M. In the case GT70 2OK will be your first choice.
