Author Topic: [REQUESTS] Vbios - MSI R9 290X Gaming 4G  (Read 1996 times)
fullinfusionTopic starter
« on: 27-November-14, 12:20:26 »
Model: MSI R9 290X GAMING 4G
S/N: 602-V308-06SB1403010367
I need the bios for the legacy #1 vbios and also the UEFI GOP #2 Bios.
I had a back up of both files, and had a HDD fail on me.
The card is not working as I tried a bios from TechPower up and I believe its for the 1st gen card because it wont work with this card.
I have the flashing tools ready But I just need the proper Vbios for this card. I have a Msi gaming 290 running now so I can see the 290X to flash it.
Thanks and sorry for asking.
  • 微星科技
Re: [REQUESTS] Vbios - MSI R9 290X Gaming 4G
« Reply #1 on: 27-November-14, 13:20:03 »
Have no legacy available but the UEFI GOP:
Use the attached.
Create a bootable usb stick (https://forum-en.msi.com/index.php?topic=165175.0).
Then unpack the previously provided archive (TV308MH_161.rar) and put the included file (TV308MH.161) on that stick.
Rename TV308MH.161 to 161.rom. Put the atiflash.exe also included in the archive on the USB stick too. Now boot from the stick.
Type atiflash -p -f -noaper 0 161.rom [ENTER] and let it flash the vbios.
AMD Ryzen 9 3900X
Windows 10 Pro
« Reply #2 on: 27-November-14, 13:27:52 »
 :dance:
You MSI guys always amaze me in your service. thank you so much
« Reply #3 on: 27-November-14, 13:54:09 »
Use the attached.
Can you tell me the difference the Bios I did have with this card, vs the bios you linked me to?
I had written down the bios a few days ago and it was
015.043.000.004.000000
the bios you gave is
015.046.000.006.000000
Thanks
Nichrome
« Reply #4 on: 27-November-14, 14:07:29 »
For vBIOSes we don't have any release notes, unless they're VERY crucial like fan fix or temp reading fix.
These numbers are not really vBIOS versions. It's all within the coding inside the file  :biggthumbsup:
« Reply #5 on: 27-November-14, 14:15:13 »
Ok thank you for the bios anyways, at least the card is back up and running again  :worship:
