Author Topic: MSI GTX 970 voltage  (Read 1425 times)
warning077Topic starter
  • CORPORAL
MSI GTX 970 voltage
« on: 28-November-14, 10:57:49 »
What is max (stock) voltage for MSI GTX 970 card?
Mine is at min: 0.85 and at max at 1.225v
ASIC value is 66.9% ... maybe the max voltage is dependant on the ASIC value
TZBC
  • CAPTAIN
Re: MSI GTX 970 voltage
« Reply #1 on: 03-December-14, 01:54:29 »
I saw someone's MSI GTX 970 max voltage can manual adjust to 1.25v at other website discussion.
but my friend's 970 the ASIC is 67.8%, and his min: 0.85v, max: 1.218v (default), manual set the voltage to +87 at Afterburner the max is 1.243v.
Is there any other way to check the max voltage?
We just ran 3D test to see the max voltage...not sure if it is the max value...
