Author Topic: r9 270. games randomly freezes.  (Read 745 times)
PatriotaTopic starter
« on: 28-November-14, 16:57:25 »
 Sory for My English. This kind of problem apears only when im playing games. In Windows mode there is no problem. When I played on integrated graphic card past one year there was everything fine. But since I bought R9 I have that problem. Games like AC IV, Shadow of Mordor, Watch Dogs do PC freezes. Background sounds continue.  No problems in f.e. Alien Isolation or Bordelands 2. Freezes appears somtimes after beginin of playing games, sometimes after 2h, sometimes not at all. Only hard reset helps with that problem. There is no graphic artifacts, glitches etc, FPS drops only defenitly freeze. I can hear loop sound in my headphones. I did a lot of steps to resolve it. Ive installed many diffrent drivers, updated BIOS in motherboard, re instal OS, reconnect cables. Graphic card have normal temps like about 58C. I dont know what to do else... My spec is: Silentiumpc deus g1 500w, i5 4570, B85 G43 and 128Gb SSD plextor m5s. Please help me. Should I give to warranty service? Or maybe thats is something else?
Nichrome
Re: r9 270. games randomly freezes.
« Reply #1 on: 28-November-14, 16:59:34 »
I suggest you try different PSU.
« Reply #2 on: 29-November-14, 00:39:15 »
Its will be difficult...
In diffrent forum users suggested me that might be supply/ power section (not memory or core) overheating on graphic card. What do you think about that theory?
Nichrome
« Reply #3 on: 29-November-14, 02:50:08 »
PSU=power supply unit
« Reply #4 on: 03-December-14, 05:35:27 »
I know what does it mean and i think thats might be psu.
