Pages: 1 [2] 3 4 ... 19   Go Down
Author Topic: Username change requests  (Read 118598 times)
Nichrome
Re: Username change requests
« Reply #50 on: 23-February-15, 12:04:55 »
The profile for mikael.s.nystrom has been updated successfully.
https://valid.x86.fr/mbld36
miny321
« Reply #51 on: 23-February-15, 12:36:23 »
Cheers!
Nichrome
« Reply #52 on: 23-February-15, 14:39:38 »
 :hat tip:
MadeInBeats
  • The Beat Box
  • SERGEANT
« Reply #53 on: 24-February-15, 04:09:03 »
Hi Nichrome.. can you change my display to MadeInBeats?
Thanks muchly. :-)
The Beat Box
Case: ITX / Cool Master Elite 110
OS: Windows 7 64bit Ultimate
MB: MSI B85I (MSI 7851) / BIOS V3.6
CPU: Pentium G3258 OCed @ 4.2 GHz / Core 1.16V / all other voltages auto / Stock cooler Max Temp 71 Degrees.
GPU: MSI R9 270X / 2GB Gaming / ITX Profile / Stock OC /
RAM: 8GB (2x4GB) Kingston HyperX Fury / Auto speed & XMP enabled/ 1333Mhz / Timings 8,8,8,22 / 1.5V
Storage: 120GB PNY Optima SSD 510Mbs Read / 1TB 2.5" Toshiba MQ01ABD100 130Mbps Read
PSU: Corsair CXM 430
Nichrome
« Reply #54 on: 24-February-15, 11:36:04 »
The profile for matthewdavenport64 has been updated successfully.
 :hat tip:
Keystone Nyan Cat
« Reply #55 on: 27-February-15, 21:51:31 »
Could my name be changed to "Keystone Nyan Cat" please? The current one is based of my email for some reason. Thanks! :)
badboy2k
« Reply #56 on: 27-February-15, 22:11:15 »
The profile has been updated successfully.
Cooler: corsair H100 cooler
Carl
« Reply #57 on: 05-March-15, 15:47:19 »
Could you please change mine to "Carl"
Thanks.
badboy2k
« Reply #58 on: 05-March-15, 16:12:32 »
Done!
Carl
« Reply #59 on: 05-March-15, 16:28:33 »
Thanks!!
badboy2k
« Reply #60 on: 05-March-15, 17:10:58 »
your welcome  :hat tip:
shaolin
« Reply #61 on: 21-March-15, 02:55:38 »
Could one of the admins kindly change my user name to "shaolin" if not already taken. If so add another n to the username at the end.
Thanks
  • Online Online
  • 微星科技
« Reply #62 on: 21-March-15, 04:09:43 »
Username has been changed from v.l.biasi to shaolin.
Note that login is still under old name, just name displayed is changed.
Core i7 7820X @ 4302.24 MHz (43 * 100.05 MHz, fixed all cores), 1.126v - delidded and using der8auer Skylake-X Direct Die Frame
MSI GeForce RTX 2080 GAMING X TRIO --> MSI GeForce GTX 1080 Ti GAMING 11G
Windows 10 Pro
MSI MAG BUNKER
Marcy
« Reply #63 on: 06-April-15, 12:24:46 »
I don't mean to be a bother, but is there any chance the moderator could change my username to "Marcy" or if that's taken  "Marcyroars"? That'd be great.  ;D
Nichrome
« Reply #64 on: 06-April-15, 12:37:26 »
The profile for lilvampgirl has been updated successfully.
Username (login detail) remains as it was.
TheNoseKnows
« Reply #65 on: 12-April-15, 11:54:45 »
Hello. Please change my username to TheNoseKnows please. Thanks a lot!
badboy2k
« Reply #66 on: 12-April-15, 12:26:27 »
 The following errors occurred when trying to save your profile:
    The selected username/display name has already been taken.
please pick another!
thenoseknows
« Reply #67 on: 12-April-15, 12:54:20 »
Oops, it looks like I already have a forum account, one I created way back in 2010 and forgot about, haha. :rolleyes_anim: Would it be possible to delete my new account?
TheNoseKnows
« Reply #68 on: 12-April-15, 12:56:40 »
Just to confirm: I am "him" (aka thenoseknows). Please delete this account. Sorry about that!
TheNoseKnows
« Reply #69 on: 13-April-15, 02:01:55 »
Um...did you delete my old account? My new account is still here, but I can't log in to my old one. But I guess it's not important so long as the username is now available. Could you please rename this account to TheNoseKnows? Thanks. :)
ElectricHumanBeing
« Reply #70 on: 13-April-15, 02:06:34 »
Please, change my to "ElectricHumanBeing"
CPU:   Intel Core i5-3470
Motherboard: MSI Z77A-G43 (MS-7758)
Graphics card: N750TI-2GD5/OC
Kingston HyperX KHX1600 2x4Gb
Power: Corsair CX430 W
SSD: Samsung Pro 840
HDD: Samsung SpinPoint F1
  • T9246ED, Бивша комета
  • Administrator
« Reply #71 on: 13-April-15, 02:31:26 »
done
all done
done
ElectricHumanBeing
« Reply #72 on: 14-April-15, 01:48:58 »
klaasvaak
« Reply #73 on: 17-April-15, 09:29:23 »
Please change my username also. Change it to Holland or whatever. Never gave permission to make it public!
MSI Z97-G45 Gaming
Intel Core i5 4690
Sapphire R9 290
Corsair Vengeance Pro Red2x4GB
Windows 8.1 64 bit
Nichrome
« Reply #74 on: 17-April-15, 09:44:36 »
There's a sticky post for username change requests.
https://forum-en.msi.com/index.php?topic=251041.50
Also please provide exact username you wish to have, else you will be changed to "ForumUser" with random number at the end.
krazy_fanboy
« Reply #75 on: 18-April-15, 08:36:15 »
Can you change my username to krazy_fanboy?
  • Administrator
« Reply #76 on: 18-April-15, 08:45:28 »
done, but stop using the forum report system for communication!
klaasvaak
« Reply #77 on: 22-April-15, 03:55:54 »
Please change my username in >> klaasvaak <<
MSI Z97-G45 Gaming
Intel Core i5 4690
Sapphire R9 290
Windows 8.1 64 bit
  • Administrator
« Reply #78 on: 22-April-15, 03:57:28 »
done
Obscure
« Reply #79 on: 03-May-15, 17:33:08 »
Could you please change my username to "Obscure" or "Arclite" if the first one is already taken?
Thanks in advance.
badboy2k
« Reply #80 on: 03-May-15, 19:16:22 »
i have changed your display name but your login is still the same as before!  :hat tip:
TitanXXX
  • SERGEANT
« Reply #81 on: 08-May-15, 00:05:49 »
I would like to change my User name to TitanXXX.
Thank you.
Watercooled Gaming system
MSI X99 Gaming 9 ACK
i7-5930K 4.4Ghz
Corsair Vengeance LPX 32GB 2400Mhz
 3 x Nvidia GeForce Titan X (3 Way SLI) EK waterblocks
 1TB Samsung 850 EVO | 12TB HDD
EVGA 1600W G2 power supply
 Corsair Air 540
 LG 34UM95-P Ultra wide 4K monitor.
http://www.3dmark.com/fs/5713199     HOF #19 (3x) :) World's fastest 5930K system 8-))
Kangawallafox_IT
« Reply #82 on: 10-May-15, 16:25:49 »
having the same issue is it something i have to do or do i just post what i would like to change it to (if so i would like to change my name to Kangawallafox_IT) please haha
Nichrome
« Reply #83 on: 10-May-15, 17:16:57 »
The profile for has been updated successfully.
Displayname is only changed. You still have to login with the same username it created, or email.
Kangawallafox_IT
« Reply #84 on: 10-May-15, 17:19:32 »
thanks heaps mate appreciate it.
Nichrome
« Reply #85 on: 10-May-15, 17:19:49 »
You're welcome  :hat tip:
Deckard_Ca1n
« Reply #86 on: 19-May-15, 00:03:43 »
Could you change my username to " Ca1n "  thanks in advance. :biggthumbsup:
  • Online Online
  • 微星科技
« Reply #87 on: 19-May-15, 00:07:52 »
Nope, not possible. The selected username/display name has already been taken. Stay with the current or choose another.
Windows 10 Pro
MSI MAG BUNKER
Deckard_Ca1n
« Reply #88 on: 19-May-15, 00:57:07 »
ok maybe" Deckard_Ca1n "  thanks boss    8-))
  • Online Online
  • 微星科技
« Reply #89 on: 19-May-15, 00:58:39 »
New display name has been applied.
Windows 10 Pro
MSI MAG BUNKER
Wazabi
  • CORPORAL
« Reply #90 on: 19-May-15, 01:13:00 »
Is it possible to change my name to Wazabi?
Thanks!
  • Online Online
  • 微星科技
« Reply #91 on: 19-May-15, 01:14:34 »
Yep, done. Like before note that login is still under old name, just name displayed is changed.
Windows 10 Pro
MSI MAG BUNKER
DarnedNut
« Reply #92 on: 20-May-15, 17:24:06 »
Could you change my Forum name to DarnedNut please?
badboy2k
« Reply #93 on: 20-May-15, 17:45:28 »
Done!
login is still the same!
PsylentNoise
  • PRIVATE E-1
« Reply #94 on: 28-May-15, 11:06:10 »
Can you please change my user name to PsylentNoise ?
badboy2k
« Reply #95 on: 28-May-15, 11:09:27 »
Done!  :biggthumbsup:
login is still under old name!
PsylentNoise
  • PRIVATE E-1
« Reply #96 on: 28-May-15, 11:21:58 »
Thank you!
Thorium19
« Reply #97 on: 07-June-15, 04:05:22 »
Could you please change my name to Thorium19 ?
  • Administrator
« Reply #98 on: 07-June-15, 04:22:44 »
done
Thorium19
« Reply #99 on: 07-June-15, 04:28:28 »
Pages: 1 [2] 3 4 ... 19   Go Up
