Author Topic: MSI R9 270x 3 Monitor VGA DVI HDMI  (Read 1272 times)
daley.tolandTopic starter
« on: 03-December-14, 21:14:07 »
I've just bought a new monitor.
So now I have a VGA a DVI and a HDMI.
The VGA is being converted through a passive converter and is in a DVI port.
The other DVI is in the bottom DVI slot.
The HDMI is in the HDMI slot.
With all of this I can only use 2 displays at once, the VGA doesn't work.
I've tried to turn it on through CCC however it says one must be disabled for the VGA to work and then the VGA works but the DVI doesn't work.
Can anyone help me?
TZBC
  • CAPTAIN
Re: MSI R9 270x 3 Monitor VGA DVI HDMI
« Reply #1 on: 03-December-14, 23:49:23 »
Does it need at least one Displayport?
sebbe_l_89
« Reply #2 on: 04-December-14, 00:08:14 »
I Think u need 1 Active adapter for it to work with 3 screens :)
sebbe_l_89
« Reply #3 on: 04-December-14, 00:14:53 »
I did have the same problem like you. Read my post and you will see how i solved it! =)
https://forum-en.msi.com/index.php?topic=250768.0
