Author Topic: core and memory clocks freeze after gamestream need help  (Read 1530 times)
procreat8Topic starter
hi everyone need help with this as i dont know whether my card is faulty and msi support keeps giving me an error when i ask a question. when i start gamestream  my core clocks go to 1113.5 and memory gose to 1502.3. when i exit gamestream the clocks stay at these speeds until i reset or remove the device from device manager and re enable it or i can stop the gamestream service in task manager. ive been in touch with nvidia and they cant replicate the error ive tried the card in three different computers using clean installs of both windows 8.1 and windows 7 driving me mad as the card idles at 48c while this is happening i have a msi gtx 970 gaming 4g latest bios everything stock anybody else have this problem. thanks in advance
TZBC
  • CAPTAIN
Re: core and memory clocks freeze after gamestream need help
« Reply #1 on: 04-December-14, 20:55:35 »
Is this only happened when you use gamestream to play game?
If you play games without gamestream, the GPU core clock and memory clock won't keep the speed?
Do you have another graphics card to try if only GTX 970 gaming will cause this issue?
« Reply #2 on: 05-December-14, 09:59:10 »
hi this only happens when using gamestream if i play games without gamestream all clocks adjust to load i used to have a gtx 780 and that didnt freeze the clocks
  • T9246ED
  • Administrator
« Reply #3 on: 06-December-14, 06:15:23 »
what video drivers versions you have tried?
if i understood well, after you close gamestream, the VGA keeps its clock to load one and do not reduce the clocks to idle,
is this correct?
have you wanted longer period of time?
do you use dual/multiple display config or just single display?
« Reply #4 on: 07-December-14, 08:17:12 »
hi ive tried all driver releases from oct onwards on the latest version now 344.75 yes clocks are stuck at load one and ive waited several hours nothing changes i use single display 1080p .
« Reply #5 on: 07-December-14, 11:00:42 »
dose anybody else have the same problem or is this a unique case
  • T9246ED
  • Administrator
« Reply #6 on: 07-December-14, 11:20:14 »
heaven't hear for other such cases yet
have you tried msi vga drivers from msi web for your card?
« Reply #7 on: 07-December-14, 11:34:43 »
ill give them ago now
« Reply #8 on: 07-December-14, 11:39:10 »
there isnt any nvidia drivers listed only have amd drivers no nvidia
  • T9246ED
  • Administrator
« Reply #10 on: 07-December-14, 12:21:08 »
cheers trying now
« Reply #11 on: 07-December-14, 12:35:37 »
tried them there to old they dont support gamestream
TZBC
  • CAPTAIN
« Reply #12 on: 07-December-14, 20:45:54 »
I think nvidia driver 344.75 is too new, msi have not test it, neither the gamestream function.
You can contact msi for what you need, maybe they will release new driver to fix this problem.  ;D
