Author Topic: MSI N750Ti TF 2GD5/OC, random black screen from hdmi output  (Read 1149 times)
didi_volenteTopic starter
Bought a MSI N750Ti TF 2GD5/OC and connected it to two monitors. My main monitor is connected to the hdmi port, and the other to the DVI one. I get random black screens on my main monitor. They last about 3-4 seconds, and my secondary screen just runs on happily. Unfortunately the latter screen doesn't support hdmi, otherwise I'd simply switch the outputs to see if it's the monitor or the card. However, I do suspect the card because I can 'break' or trigger the black screen by manipulating the hdmi cable at the card's output.
Anyway, is this a known issue or should I experiment a bit more? If it is know, what's a good solution?
I did update my drivers, btw.
Cheers!
  • T9246ED
  • Administrator
Re: MSI N750Ti TF 2GD5/OC, random black screen from hdmi output
« Reply #1 on: 05-December-14, 04:36:37 »
what do you mean by this?
have you tried different HDMI cable? or/and different display with HDMI?
« Reply #2 on: 05-December-14, 08:02:29 »
That I only have one monitor with an hdmi input.
Will try a different cable, and see above.
« Reply #3 on: 06-December-14, 02:47:15 »
Cable it was!
Please whip the producer of the cables that you put in your vga-card boxes.  :-P)
  • T9246ED
  • Administrator
« Reply #4 on: 06-December-14, 03:06:23 »
 :biggthumbsup: :pompom: :pompom:
