Author Topic: MSI R9 280X - Severe artifacts  (Read 1523 times)
kartikk127Topic starter
« on: 05-December-14, 04:39:39 »
I bought a R9 280X 3G BF4 some time back and I had some artifacts in crysis 3 so I dismissed it as a game specific issue.
But, recently I got LOTR: Shadow of Mordor and the game displays some very serious artifacts making the game unplayable. The game works perfectly on my other PCs, so I used graphs from MSI AfterBurner & GPU-Z for troubleshooting and found out that the artifacts appear only when the VRAM usage crosses about 2GB.
Its getting very frustrating as I am unable to use the full 3GB VRAM and even lower-end cards can run games better. Please help me in getting this issue resolved.
note: I tried running the GPU in a different PC & I got the same issues.
System Specs:
Main Board: Asus Z77-m pro
Bios Version: 015.042.000.003.000000(113-C3865000-X77)
Video Card: MSI R9 280X 3G BF4
PSU: Seasonic M12II 750W Bronze
12v rail Rating of listed PSU: 62A
CPU: Intel I5 3570K
Memory: 4GB Corsair vengeance 1600MHZ DDR3
SSD/ HDD: Seagate barracuda 1TB 7200rpm
CPU COOLER: Stock Intel cooler
Sound Card: none
Any Additional hardware plugged into your system: No
OC: No
Operating System: Windows 8.1 pro 64bit
Driver: 14.11.2 beta and 14.9 whql
  • T9246ED
  • Administrator
Re: MSI R9 280X - Severe artifacts
« Reply #1 on: 05-December-14, 05:27:40 »
which MSI R9 280X exactly you have?
http://www.msi.com/search/R9%20280X/product/1
have you checked GPU load temp?
can you tell S/N of the card and to save with GPU-Z its vbios, upload it somewhere and give a link to it
to check for possible updates
« Reply #2 on: 05-December-14, 06:24:51 »
This is the MSI R9 280X I have.
msi.com/product/vga/R9-280X-GAMING-3G-BF4.html#hero-overview
S/N: 602-V277-44SB1312121379
GPU Core temprature is in the 80C range.
I have uploaded the bios here.
sendspace.com/file/seizhg
  • T9246ED
  • Administrator
« Reply #3 on: 05-December-14, 06:32:16 »
oki, the vbios is correct one , no crossflash issues
and its also latest version
load temp also looks fine
have you tested the card in another computer?
have you tried the one from msi web for your card?:
http://www.msi.com/support/vga/R9-280X-GAMING-3G-BF4.html#down-driver&Win8.1 64
« Reply #4 on: 05-December-14, 06:37:26 »
Yes, I have tried the GPU on a different computer and it still has the same artifacts issue.
No, I haven't tried the version from the MSI webpage as it seemed old(14.4).
  • T9246ED
  • Administrator
« Reply #5 on: 05-December-14, 06:43:25 »
then looks like its bad video card them since its doing the same on another computer too
you have to send it back to reseller or msi for replacment
« Reply #6 on: 06-December-14, 00:01:40 »
Thank you very much for your help   :)
I have applied for a RMA. Really hope they don't return the device stating that they where unable to reproduce the issue.
  • T9246ED
  • Administrator
« Reply #7 on: 06-December-14, 09:20:02 »
cool, let us know when your issue is solved
