Author Topic: Gpu problem  (Read 754 times)
wabin777Topic starter
Gpu problem
« on: 07-December-14, 10:43:59 »
So i recently bought a msi gtx 970, about two months ago, and everything was working fine. But now my core clock is at 406 mhz and my mem is at 810 mhz. Video games are "working", but the frame rate is terrible. Anyone know what the problem is? Help would be much appreciated.
Nichrome
Re: Gpu problem
« Reply #1 on: 07-December-14, 10:52:10 »
You could try some previous nvidia drivers and see if that helps.
  • T9246ED
  • Administrator
Re: Gpu problem
« Reply #2 on: 08-December-14, 03:05:26 »
what has been changed before this issue to start?
can you also list full system specifications? see >>Posting Guide<<
which one exactly?
if you run 3DMark11, Furmark/Kombuster to test does the VGA clock goes to max?
