Pages: 1 [2]  All   Go Down
Author Topic: X99 PCIe lane switching  (Read 50348 times)
  • 微星科技
Re: X99 PCIe lane switching
« Reply #50 on: 09-July-16, 07:05:34 »
The layout decision is bad and was much criticized. However it is that way on all MSI X99 boards below Gaming 9/Xpower series except for the X99A Raider. You can still use an SLI setup without any problem populating E1 and E5 like suggested. x8/x8 will not hit the performance in a noticeable way.
AMD Ryzen 9 3900X
Windows 10 Pro
strike
« Reply #51 on: 10-July-16, 23:13:13 »
Yes 93C is quite bad, and better to move cards around to get them at x8/x8 but with lower temps.
Thanks for the help and honesty guys! I switched slots and now there's a difference of about 5°C instead of 20°C. So I'm happy with that. Although I wonder what the performance difference between x16/x16 and x8/x8 looks like. Someone who buys a system like this probably wants all the performance they can get. :-P)
CPU:     Intel Core i7 6900K (@ 4.3GHz w/ Corsair H110i GTX) | RAM:  32GB Kingston DDR4-2400                | OS:    Microsoft Windows 10 Pro
MoBo:    MSI X99A Tomahawk (BIOS v2.1)                       | GPUs: MSI GeForce GTX 1080 Gaming X (in SLI) | PSU:   Corsair HX1200i
SSD:     Samsung SSD XP941 512GB                             | HDD:  Western Digital Red Pro 6TB            | SND:   Creative Sound Blaster Z
Case:    Corsair Graphite 760T                               | KB:   CMStorm QuickFireTK (Cherry MX-Red)    | Mouse: Logitech G502 Proteus Core
Display: 27" Dell S2716DG 1440p 144Hz                        | ETC:  Whole bunch of Noctua fans (PWM) hehe
  • 微星科技
« Reply #52 on: 11-July-16, 10:44:54 »
The difference is about 0 - 1%
AMD Ryzen 9 3900X
Windows 10 Pro
naveeed
« Reply #53 on: 10-August-16, 16:54:29 »
Dear all,
I have a pc with following specification.
X99A GAMING PRO CARBON
Bios : 1.2.
INTEL 6800K
CORSAIR H100I COOLER
SAMSUNG SSD 512GB
32GB CORSAIR RAM
1200W PSU
ASUS GTX 980TI X 2
WINDOWS 10 / 106
Nvidia Drivers. Ver. 368.81
TWO MAJOR ISSUE FACING.
1. BOTH GPUs working at x8 Speed.
(Installed 6900K CPU,Which is 40 Lanes,Tested with
two X99A GAMING PRO CARBON Motherboards,
Still the same issue,
2. In Nvidia Control Panel. The first GPU on PCIE1
shows as second GPU & on E5 shows as Primary (No.1)
GPU.
As I feel The GPU#1 on PCIE1 should show #1.
Earliest help is anticipated,
badboy2k
« Reply #54 on: 10-August-16, 22:48:13 »
Dear all, I have a pc with following specification. X99A GAMING PRO CARBON Bios : 1.2. INTEL 6800K CORSAIR H100I COOLER SAMSUNG SSD 512GB 32GB CORSAIR RAM 1200W PSU ASUS GTX 980TI X 2 WINDOWS 10 / 106 Nvidia Drivers. Ver. 368.81 TWO MAJOR ISSUE FACING. 1. BOTH GPUs working at x8 Speed. (Installed 6900K CPU,Which is 40 Lanes,Tested with two X99A GAMING PRO CARBON Motherboards, Still the same issue, 2. In Nvidia Control Panel. The first GPU on PCIE1 shows as second GPU & on E5 shows as Primary (No.1) GPU. As I feel The GPU#1 on PCIE1 should show #1. Earliest help is anticipated,
that board is electrically wired the same as the X99S SLI Plus so 1 and 5 are on shared lanes off slot 1's x16 lanes so its splitting them x8 - x8!
Cooler: corsair H100 cooler
naveeed
« Reply #55 on: 11-August-16, 01:34:50 »
Thanks for your quick reply.
If I connect DP/HDMI Cable to GPU #1, it take as above image.
If I connect DP/HDMI Cable to GPU #2, it take as Primary GPU.
Any clues why the GPU #2 taking as Primary.
Regards
badboy2k
« Reply #56 on: 11-August-16, 01:49:45 »
i think that is a NVIDIA thing to offload the bulk of the display outs to the lower card to keep temps more even when they are used in SLI as the lower card will be cooler then the top one so moving the driving of displays to the lower reduces the heat of the upper card as its just a compute engine only and the cooler card has more headroom for the extra heat a display out generates as its extra processing for the signal!
i do not think that can be changed to flip them back around! (most boards for years from MSI have been like that where the lower is set as primary)
jidri.luks
« Reply #57 on: 04-September-16, 16:39:41 »
I got the issue with my PC like that. I have
i7 5820k
2x MSI R9 390 G8 Gaming
MSI X99A Gaming 7
I use pci-e1 and pci-e 5 and Bios says vga in slot 1 is running at x4 and in slot 5 is running at x8. If I use only one card in first slot, speed is x8, in slot 2 is it x8, not x16 and both cards as I wrote x4/x8  pci-e1/pci-e5. I dont have m.2 ssd and no sound or other pci card. I took both cards to my friend, he has 5820k and same MB. we didnt try CF but both cards single in pci-e1 run at x16, Is my motherboard damaged? And more.....Board Explorer in Bios says, I got all 8 RAM slots empty. I got there 6x8 GB Kingston 2666 mhz ddr4, and today, I was forced to clear CMOS, i did it 20 times and PC still didnt turn on, after 2 hours of trying I find issue, 2 dead ram modules.... Can someone help me figuree it out? Or its tottaly lost, and i would like to claim a warranty. (sorry for my English). I hope everyone understand.
  • T9246ED
  • Administrator
  • Online Online
« Reply #58 on: 05-September-16, 06:40:34 »
@jidri.luks
if you are looking for troubleshooting, please open new own topic and also provide details system specs,
see >>Posting Guide<<
rgiarusso
« Reply #59 on: 07-November-16, 16:13:47 »
Planning out a build and trying to figure out how to go about configuring everything properly (if I need custom BIOS).
Intel i7-6850K (40 PCIe Lane)/MSI X99A Gaming Pro Carbon
2 MSI GTX 1070s, 10Gb Networking Card, MSI GT 710, and Samsung 950 Pro M.2 SSD.
Trying to get the following config:
PCI_E1: x8 - GTX 1070
PCI_E3: x16 - GTX 1070
PCI_E5: x8 - 10Gb Networking
PCI_E6: x4 - GT 710
M.2_1: x4 - SSD
Is this even possible?
badboy2k
« Reply #60 on: 07-November-16, 17:03:12 »
Planning out a build and trying to figure out how to go about configuring everything properly (if I need custom BIOS). Intel i7-6850K (40 PCIe Lane)/MSI X99A Gaming Pro Carbon 2 MSI GTX 1070s, 10Gb Networking Card, MSI GT 710, and Samsung 950 Pro M.2 SSD. Trying to get the following config: PCI_E1: x8 - GTX 1070 PCI_E3: x16 - GTX 1070 PCI_E5: x8 - 10Gb Networking PCI_E6: x4 - GT 710 M.2_1: x4 - SSD Is this even possible?
that is Not possible! if you use a M.2 drive on that board the bottom X8 slot will be switched off and have Zero Lanes!
rgiarusso
« Reply #61 on: 07-November-16, 17:25:07 »
Is there any way to run all four slots plus M.2 on this board?  Or is there another MSI board that could do this?
  • 微星科技
« Reply #62 on: 08-November-16, 04:36:22 »
Four slots + M.2 @ x4 is not possible on any MSI X99 board or on any other X99 board I know. MSI already has one of the most flexible solutions for X99 boards. Four slots is possible but M.2 will than just use the PCH's 2.0 x2 lanes.
AMD Ryzen 9 3900X
Windows 10 Pro
rgiarusso
« Reply #63 on: 08-November-16, 05:50:54 »
I think I've found a solution, at least for my case.
 X99S XPower Gaming Titanium, according to its manual, will support a 3-Way SLI config for a 40-lane CPU of:
PCI_E1 - 3.0 x8, enough for a GTX 1070
PCI_E2 - 3.0 x8, enough for a GTX 1070
PCI_E3 - 0
PCI_E4 -  3.0 x16, enough for a 10Gb Network card
PCI_E5 - 2.0 x 1, enough for a GT 710 (it's just running a 5" terminal display)
PCI_E6 - 0
M2_1 -  3.0 x4, enough for a Samsung 950 Pro M.2 SSD
I'm just worried about airflow over the SSD, but from the looks of the chart, I think I could just swap in a U.2 drive instead.
Am I completely nuts here or could something like this actually work?
  • 微星科技
« Reply #64 on: 08-November-16, 06:14:51 »
All XPower boards share the same basic layout (X99A XPOWER GAMING TITANIUM, X99S XPOWER AC, X99A XPOWER AC). With it your updated layout would theoretically work. The GT 710 would even fit physically in the x1 slot because it's rear on this board apparently open to fit longer cards. Considering bandwith 2.0 x1 would be enough for your task for it.
AMD Ryzen 9 3900X
Windows 10 Pro
FlangeMonkey
« Reply #65 on: 06-December-16, 10:12:17 »
Do you have any high level diagrams like this for the newer X99a boards?
I'm looking at the Tomahawk and notice it switches on the first PCIe and shares bandwidth with the x8 port.
  • 微星科技
« Reply #66 on: 06-December-16, 11:49:35 »
Open an own thread for a particular question about the Tomahawk.
AMD Ryzen 9 3900X
Windows 10 Pro
msi
  • CORPORAL
« Reply #67 on: 13-June-17, 08:01:38 »
On the X99S Gaming 7 where PCI_E2 and PCI_E4 1x slot are connected?
I cant get PCI_E2 slot to work, and dont know why, im using the i7-5820k
  • 微星科技
« Reply #68 on: 13-June-17, 11:48:58 »
PCI_E2 and E4 (PCI-E 2.0 x1 slots) don't share lanes with anything and are directly connected to the PCH. It is no lane switching problem For further support open an own topic please.
AMD Ryzen 9 3900X
Windows 10 Pro
enk37
« Reply #69 on: 28-December-17, 03:20:17 »
Dear MSI Team,
Could you please provide me with X99A Raider PCI-E lane switching diagram? In general my question is if it's possible to use all 5 PCI-E slots as gen1 and M.2 slot at the same time?
  • 微星科技
« Reply #70 on: 28-December-17, 06:47:50 »
All slots on the X99A Raider and the M.2 can be used at the same time.  Like shown in your manual regardless if using 28 lanes or 40 lanes cpu all three Gen3 slots can be used while still providing 3.0 x4 for M.2. The x1 slots are using 2.0 x1 lanes from the PCH anywy and are not affected by slot sharing anyway.
AMD Ryzen 9 3900X
Windows 10 Pro
Moheban79
  • SECOND LIEUTENANT
« Reply #71 on: 29-December-17, 13:00:11 »
So I've almost exclusively bought MSI products in the past, because I've never had issues and this was enough to make me stick to them... until now.
I've recently bought an entirely new system:
- Intel Core i7 6900K
- Kingston HyperX Predator DIMM Kit 16GB (x2)
- MSI X99A Gaming Pro Carbon
- MSI GeForce GTX 1080 Gaming X (x2)
- And a whole bunch of Noctua PWM fans
(Please don't assume that I'm rich or anything. I'm a student. This was a major investment for me. I've used money I saved over the course of about three years!)
Right from the start I've faced issues with the ASMEDIA USB 3 controller (*this*), but since I don't really need that many USB connections anyway, I've decided not to use them and just wait this issue to get fixed per driver update or something.
But there's another problem, that I think is way more severe. The top GTX 1080 of my SLI setup is absolutely suffocating, because MSI thought it would be a great idea to have no free space between dual slot graphic cards on the X99A Gaming Pro Carbon. Sorry for needlessly bashing the engineers of MSI, but I'm just so infuriated about this! Obviously I blame myself for this, too, I should have definitely paid more attention to this before I purchased the motherboard. Well, basically one GTX 1080 is always running up to 20°C hotter than the other one, even with all fans manually set to 100%.
Would SLI still work if I used PCI_E1 and PCI_E5 (with a sound card in PCI_E3 and an SSD in the M.2 slot)? I guess they wouldn't be running in x16 mode then? To be perfectly honest, I'm even too dumb to make sense of the graphs in this thread. And I cannot test this, because I have no SLI bridge that long and before spending about ~$20 on a SLI bridge or even $50+ on a SLI-HB bridge I thought I'd ask you guys.
Thanks in advance!
Try using a Riser Cable Card and you can still use the 2nd PCI-E slot. Just would have to mod your case to reposition the second video card. I recommend ThermalTakes Premium cables.
Code: [Select]
Board: MSI Godlike X99A
Bios: Version 1.8
VGA:   EVGA 980Ti in SLI
PSU:   Corsair AX1200i
CPU: Intel Core i7-6850K
MEM: HyperX 32GB (4 x 8GB) DDR4 2800  HX428C14PBK4/32
HDD: Samsung 950 NVME 512gb
COOLER: Zalman CNPS9900Max
OC: Minimal
OS: Windows 10 64bit Professional
enk37
« Reply #72 on: 10-January-18, 16:01:02 »
Ok, thank you. Than I have quiet strange issue. Currently in M.2 slot I have PCI-E raiser adapter and it doesn't work. Any advise? PCI Gen was set to Gen.2 in BIOS but also tried with Gen.1,but GPU attached through this riser dosn't recognized by Windows, although it works fine through any other PCI-E slot.
Moheban79
  • SECOND LIEUTENANT
« Reply #73 on: 10-January-18, 16:24:17 »
Your running a GPU through a M.2 to PCI-E adapter??  I don't understand how you have this configured. Please write back in more detail and what your trying to do.
Code: [Select]
Bios: Version 1.8
OC: Minimal
nathaniel.c.cooley
« Reply #74 on: 01-February-18, 19:58:16 »
I have the x99s gmaing 7 motherboard with a network card in pcie lane 4 and a msi 980 in the first PCI full slot. Will this motherboard support an NVME m.2 drive?
  • 微星科技
« Reply #75 on: 02-February-18, 08:21:38 »
I assume that you mean PCI_E4 by "pcie lane 4" if so then the M.2 slot is not affected by your setup (vga = PCI_E1 + network card = PCI_E4).
Only populating PCI_E6 would affect PCI-E lanes allocation for the M.2 slot. So you can use an M.2 at full PCI-E 3.0 x4.
AMD Ryzen 9 3900X
Windows 10 Pro
phaktory
« Reply #76 on: 31-October-18, 23:31:54 »
Wow these pictures were helpful.  If only Support had given me these on my open case, I would have a better grasp.  At the same time though, it's throwing me for a loop.
I have an X99S Gaming 9 AC with a 5630K 40 lane CPU.  I'm running a single 1080 Ti video card in PCIE1.  I have an onboard m.2 NVME drive.  I have an expansion card in slot 5 with another m.2 drive.  I also have a second expansion card in slot 3 with another m.2 drive.  Slots 2 and 4 are empty.
I want to add an El Gato x4 capture card but I can't get it to work in slots 2 or 4.  I even moved my add in card in slot 3 to slot 2.  When I did that, the capture card worked but the drive disappeared.  I don't understand why it didn't work in Slot 4 though.  According to the picture, slot 4 doesn't share its lanes.
What I'm THINKING about doing is moving my video card to slot 4 as the manual says that is the x16 slot in a 4 way SLI.  Then putting the Gato in Slot 1 and leaving the m.2 add ins in slots 3 and 5.  I don't REALLY want to do this without some kind of sanity check/assurance it's a lot of work to do that.
My other option is trying to get a PCIE card that will hold multiple m.2 drives but I don't think we have actual bifurcation as an option in the BIOS.
  • 微星科技
« Reply #77 on: 01-November-18, 12:05:50 »
Well, so you have a vga in PCI_E1 and you also populated PCI_E3. That switches both slots to x8 and disables PCI_E2 so that won't work. If you'd populate PCI_E2 PCI_E3 would be disabled. Both share the same lanes.
If you populate PCI_E5 the M.2 slot is switched to PCI-E 2.0 x2 as all PCI-E 3.0 lanes are then used for PCI_E5. A very bad idea if using an NVME drive.
PCI_E 4 on the other hand exclusively uses the other set of 16 lanes from your 40 lanes cpu and should work for that capture card. I'd try the graphics card there (would also allow it to run at x16 unlike it does now)
AMD Ryzen 9 3900X
Windows 10 Pro
Pages: 1 [2]  All   Go Up
