With the latest release of UHD (3840x2160p) TVs, we get some questions about the support on HDMI2.0.
And especially about the support for full color in UHD (3840x2160p) at 60Hz.
The first gfx cards supporting HDMI2.0 are the Nvidia GTX 970 and GTX 980 cards.
These cards support UHD (3840x2160p) @60Hz refresh rate with full color (RGB or YCbCr-4:4:4) if your display are able to support it.
Some TVs support UHD @ 60Hz but with reduced color information (e.g. YCbCr 4:2:0) (Usually 24/30Hz full color is supported)
Some TVs support UHD (3840x2160p) @60Hz refresh rate with full color (RGB or YCbCr-4:4:4) but only on one HDMI2.0 port.
And some manufacturers don't document the capabilities very clearly.
So what should we do to view full color UHD @60Hz over HDMI2.0 on a UHD TV?
1.) Check the TV manufacturer’s website if there is a newer firmware for your TV available.
2.) Check the TV manual which HDMI port(s) can support UHD RGB/4:4:4 @ 60Hz.
3.) Check the TV manual (Samsung and LG) to see if there is a setting called "HDMI UHD (deep)Color", and set it to "On" .
Check the TV manual (Toshiba) to see if there is a setting called "HDMI Input Mode" and set it to "Mode1".
Check the TV Manual (Panasonic) to see if there is a setting called "HDMI Auto Setting" and set it "Mode2".
4.) Install the (Nvidia) gfx drivers and in the driver control panel setup the resolution to 3840x2180p @ 60Hz
5.) If you want to check if the color is reduced or not? Just open the
http://i3.minus.com/ibyJcwdIniHUEs.png (100% zoom) and if you can read 4:4:4 clearly then the colors are not reduced.
P.S.,
Most TV manufacturers recommend using Hi-speed HDMI cables and preferably shorter than 3 meters (some say 5m).
P.P.S.,
I attached extracts from UHD TV manuals, where you can see the different UHD color information from some manufacturers.
P.P.P.S.,
DisplayPort v1.2 also supports UHD (3840x2160p) @60Hz refresh rate with full color (RGB) but most TVs don't have DP ports (I have only seen Panasonic offering DP1.2) .
In some UHD TVs and Monitors you need to enable "Multi-stream" in the TV/Monitor settings menu to enjoy 60Hz UHD.
I haven't come across any UHD monitors with HDMI2.0 yet.
