Author Topic: PCI SCSI Doesn't work with GF4 4400  (Read 2613 times)
synic
« on: 11-July-02, 07:50:42 »
I swapped my old Herc GF2 out for the new MSI GF4 TI4400 card and found out that my PCI SCSI card doesn't work with it in. Swapped back in the GF2 and it works fine, and also works in a diff PC.
Flashed BIOS of my Abit KG7-RAID, no change...
:censored:?!
synic
(No subject)
« Reply #1 on: 11-July-02, 08:29:49 »
is this to do with the 1.5v thing?
synic
(No subject)
« Reply #2 on: 11-July-02, 18:43:51 »
someone suggested this may have to do with a BIOS limitation about how much ROM space can be used for initialization routines such as video BIOS, mobo BIOS, and any other I/O cards such as the SCSI... Apparently most SCSI cards use 64K or so of memory at init and shrink back to like 16K or so....
Going to play with moving the cards around to change the order of initialization and we'll see if any change occurs...
Assaf
  • GENERAL
(No subject)
« Reply #3 on: 11-July-02, 22:08:15 »
  • Best Answer
  • You can try disabling useless stuff in the bios (COM ports, LPT, gameport......)
