Author Topic: Replacing thermal paste R9 290 Gaming 4G, warranty question  (Read 1578 times)
HellFire90Topic starter
Hi! I would like to replace the thermal paste of my GPU. Does removing the cooler to do this voids the warranty? Moreover, can the thermal pads can be re-utilized?
Thanks very much!
  • 微星科技
Just removing and reapplying is fine as long as no physical damage is caused. After reapplying paste on the GPU you can simply put the cooler back on. Pads on ram or so don't need to be replaced as long as they didn't got peeled off.
MSI X299 Gaming M7 ACK (MS-7A90) Bios 1.A0
Windows 10 Pro
MSI MAG BUNKER Case
thanks for the reply! I was worried because there's a sticker of "warranty void" on some of the screws in the back of the gpu..
Nichrome
Sticker is for those who have no idea what they're doing. Or those who wants to have a look what's it like under the heatsink without real purpose (such as thermal paste change)
Errors are red, My screen is blue .I think I deleted, System32
sales
  • CORPORAL
may someone confirm rma without sticker?
Nichrome
I believe you were redirected to contact your card seller or local MSI office? >>How to contact MSI.<<
Usually it does not void warranty if you remove it/break it (as its on a screw) but it still depends on the country you live in and its best to confirm with reseller(shop) or MSI office.
sales
  • CORPORAL
msi support have solve the problem.
