Pages: [1] 2 3 ... 6   Go Down
Author Topic: Live Update issues? See here.  (Read 94257 times)
NichromeTopic starter
Hi all,
This sticky topic has been created so you can report any issues you have with MSI Live Update software.
So if you experience any issue related to this program, please post here instead of creating new thread. We will do our best to help you as long as it's not common problem with particular version of LU.
Please make sure to post Live Update version, error message and code, and also follow this >>Posting Guide<< so we and MSI know what systems/combos are affected by it.
Thanks  :hat tip:
Re: Live Update issues? See here.
« Reply #1 on: 15-June-15, 05:35:31 »
Current Live Update version: v 6.1.023
Download available >>HERE<<
OS support: Win10/Win 8.1/Win8/Win7 32&64 bit
Live Update 6 supports the following MSI product lines and items:
Motherboards: Drivers / BIOS / Utilities;
Graphics Cards: Drivers / BIOS
Do NOT use Live Update for AIO PC and Notebooks.
badash13
« Reply #2 on: 16-June-15, 22:21:14 »
Trying to use Live Update v 6.0.020 to install new Bios v1.40 to 1.50.
I keep getting Download failed.
« Reply #3 on: 17-June-15, 03:49:07 »
You could try using MFlash.
>>Posting Guide<<
insann
« Reply #4 on: 23-June-15, 16:57:06 »
When I scan via LiveUpdate 6.0.021 it show me multiple drivers need to be updated.
After download them all I still has same notifications about these driver.
I did multiple download and multiple restart for my machine but it has same problem.
Board: MSI Z97 Gaming 7
BIOS: 1.A0
VGA:   MSI GTX 970 GAMING 4G
PSU:   EVGA SuperNOVA 850 G2 80 PLUS
Intel core i7-4790k
MEM: Kingston HyperX Savage 16GB (2x8GB) 2400MHz CL11
HDD: 2X Samsung SSD 850 EVO 250GB Raid0
WD Black 1TB
COOLER:Cooler Master Hyper 212 EVO
OC: 16.0GB Dual-Channel DDR3 @ 1199MHz (11-13-14-32)
OS: Windows 8.1 64bit Professional
m3ta
« Reply #5 on: 23-June-15, 22:39:54 »
I can see another problem... Live Update is not able to read your graphiccard bios version.... i got the same problem with my Gaming 5 Board.
In my opinion, i think the root is the MB Bios !
snowsak
  • I like pocket pies!!!!
  • STAFF SERGEANT
« Reply #6 on: 03-July-15, 22:47:16 »
Got same problem too with Gaming 7  motherboard and gaming GTX 970 4G graphic card.Live Update refuses to find my vga bios.
Mobo: MSI Gaming 7 Z97 Bios Version: 1.B0
RAM: G.SKILL F3-1866C10D-16GSR 16GB (2X8GB)
HDD: OCZ VERTEX 4 256GB & 2xWD Caviar 1TB
CPU: INTEL CORE I7-4790K
GPU: MSI Gaming GTX 970 G4
PSU: PC Power & Cooling Silencer 750w
(+3.3V@24A,+5V@30A,+12V@60A)
Mon: LG DM2752D
CPU Cooler: Corsair H80i GTX
Sound: Creative Sounblaster Z
OS: Windows 10 Pro x64
Case: Thermaltake Level GT10
« Reply #7 on: 06-July-15, 11:51:46 »
Did you recently update through a vBIOS request on our forum? If yes, then it might be that this vBIOS is not in MSI's LiveUpdate database yet.
snowsak
  • STAFF SERGEANT
« Reply #8 on: 06-July-15, 14:00:12 »
No i bought my graphic card recently and it was already updated with the most recent BIOS
Actually found whats causing it....
its the motherboard BIOS option "Windows 8/8.1/10 Feature" if you disable it live update can see your graphic card bios.
i tried it couple times and i can confim this.
screenshots attached
Mon: LG DM2752D
« Reply #9 on: 06-July-15, 14:04:35 »
Interesting. Thanks for that info!
snowsak
  • STAFF SERGEANT
« Reply #10 on: 06-July-15, 14:19:10 »
You welcome sir anytime.
Mon: LG DM2752D
YYZ342
« Reply #11 on: 20-July-15, 17:42:49 »
I am using Live Update v6.0.0.24. App will not instal Intel ME driver 10.0.31.1000. It downloads the driver but will not install. Receive no error messages of any kind. Just nothing happens.
I thought I installed the driver manually successfully but Device Manager says I have version 10.0.30.1054. Live Update still says I am on 10.0.28.1000 version. History shows Incomplete. Seems for whatever reason driver version 10.0.31.1000 does not want to install. Any thoughts?
Screenshot attached.
Thnx.
Cheers
« Reply #12 on: 20-July-15, 17:45:34 »
Hi
Try installing it manually:
http://download.msi.com/dvr_exe/intel_me_x99_mb.zip  (it's 31.1000 version)
YYZ342
« Reply #13 on: 20-July-15, 18:17:58 »
Thnx for quick reply.
I tried the file you suggested. No luck.  :bonk:
Device manager and history from Live Update attached.
Thnx.
Cheers
JLio01
  • MAJOR
« Reply #14 on: 20-July-15, 18:28:02 »
Check the ME driver and click total install.
YYZ342
« Reply #15 on: 20-July-15, 18:42:40 »
Thnx. Live Update installed the driver with confirmation pop up. Restarted PC. No joy. Screen shots attached with Live Update tab showing 10.0.28.100 as installed version, 10.0.31.100 as latest version. History tab shows version 10.0.31.100 Installed. Device manager however shows 10.0.30.1054 with date stamp 9/23/2014?
Cheers
JLio01
  • MAJOR
« Reply #16 on: 20-July-15, 18:55:24 »
10.0.30.1054 is the driver version, 10.0.31.100 is the package driver, I guess it's normal. (afaik, normally the package might also contain more than one driver.) Also you'll need to press scan again to check.
YYZ342
« Reply #17 on: 20-July-15, 19:09:17 »
Ok, thnx.
Re-scan took a bit of time; showed no changes to the driver versions displayed in Live Update. Suppose it is a bug then?
Cheers
JLio01
  • MAJOR
« Reply #18 on: 20-July-15, 19:21:17 »
ja..if device manager shows right version then it should be fine. :)
Quietman
« Reply #19 on: 20-October-15, 02:41:06 »
Live Update appears to be downloading version 1.0.1.03 of Command Center but it installs version 1.0.1.02 instead. Also today the same with MSI Gaming APP. Current version 5.0.0.23 but installs 5.0.0.20.
Even the files it downloads have the correct version in the file name but when you run install and run them they are still the previous versions.
Running Live Update version 6.1.009.
UPDATE: After a bit of manual un-installing, deleting and re-installing MSI Gaming APP is up to date. Command Center will not update though. It even tells me a new version is available when I run it, updates, restarts and does the same thing again. I have to say no to updating to stop it.
Board: MSI Z87-G45 Gaming
BIOS: Version 1.9
PSU: 650W SEASONIC M1211 (53A 12v rail)
CPU: Intel i7 4770K 3.5ghz
RAM: Corsair 2x8GB Vengence Pro 2133mhz
HDD: Samsuung 830 256GB SSD, 2x WD 2TB Green (RAID 0), DVD
Cooler: Corsair Hydro H100i
OC: CPU 4.0ghz stock volts, RAM 2133mhz XMP
Case: Fractal Design Arc 2 Midi
OS: Windows 10 64 bit
« Reply #20 on: 20-October-15, 03:11:16 »
I think that LiveUpdate reads it as newer version which is correct, but the update is not yet available for download. Check again in 24-48h or try manually downloading the updates.
Quietman
« Reply #21 on: 20-October-15, 03:22:27 »
Downloading Command Center 1.0.1.03 directly from the MSI website seems to have worked, Thanks!
BIOS: Version 1.9
tmursch
  • SECOND LIEUTENANT
« Reply #22 on: 20-October-15, 09:26:22 »
Running the Live Update and clicking Total Installer.  Get prompt to reboot:
Reboot and they show up again:
Manually running the exe to update:
So I manually uninstalled and reinstalled and still get the same thing.  Time to wait for the next driver update to fix it?
CPU: Intel(R) Core™ i7-6700K 4.00 GHz
MOTHERBOARD: MSI Z170A Krait Gaming
COOLER: Noctua NH-D9L Dual Tower CPU Cooler
RAMG.SKILL Ripjaws 4 Series 32GB (4 x 8GB) DDR4 2800
HDD: 512GB SanDisk X300 SATA III SSD
HDD2: 2TB Toshiba SATA III HDD
HDD3: 500GB SAMSUNG 850 EVO M.2 500GB SATA III SSD
OS: Windows 7 Ultimate x64 SP1 (G
enuine licensed copy)
POWER: EVGA SuperNOVA 1050 Watt Power Supply
VIDEO: EVGA GeForce GTX 980 Ti 06G-P4-4995-KR 6GB SC+
MONITOR: ASUS VG248QE - 144Hz Refresh Rate
« Reply #23 on: 20-October-15, 10:50:08 »
Intel ME is not done by MSI. Go to Intel's website and find latest, compatible driver there.
b.w.collinson
« Reply #24 on: 20-October-15, 15:00:37 »
Hi
can anyone help ?
for some reason live update is telling me that i need to install the intel ME drivers befiore it allows me to update any drivers.
however when i try to install them the intel installer comes up saying the platform is not supported!
also when the live update runs it does not detect any ME drivers.
i have the MSI Z87-GD65 GAMING  with an i5-4670k
this is becoming frustrating can anyone give me some advice?
thanks
JLio01
  • MAJOR
« Reply #25 on: 20-October-15, 23:10:20 »
What ME driver version you tried?
diabloxxyy
« Reply #26 on: 21-October-15, 02:50:54 »
I went through the forums and different sites. In most of them, there's a warning stating not to use Live Update for BIOS updates. However, on some newer topics there are posts, that is works. How to proceed?
Do I manually update the BIOS or can I use the Live Update, which from time to time seems to have a bad day? How is the warranty on that?
Thanks,
« Reply #27 on: 21-October-15, 04:39:39 »
It is not best to use LU for BIOS update. It is too buggy for this. If LiveUpdate bricks the motherboard, warranty is not void as it's MSI's tool. Use MFlash, that is my recommendation or forum flashing tool.
tmursch
  • SECOND LIEUTENANT
« Reply #28 on: 21-October-15, 08:09:24 »
Tried that, doesn't work.
Here is why LiveUpdate fails:
So looked at the XML of the setup file - the problem is the driver version is actually 11.0.0.1160 and not 11.0.0.1168.  That's why mine won't update - it thinks it's already up to date.  Not sure if this is error on Intel or MSI's part.
b.w.collinson
« Reply #29 on: 21-October-15, 11:05:52 »
Hi
i am trying  ME_Consumer_Win8.1_10_11.0.0.1173 from the web page but have also tried the intel page but with the sam results.
worryinly live update does not pick up any drivers to change?
Help ?
JLio01
  • MAJOR
« Reply #30 on: 21-October-15, 18:37:17 »
Hi
Help ?
http://www.msi.com/product/motherboard/support/Z87-GD65-GAMING.html#down-driver&Win8.1 64
How about this one?
Did you install hotfix?
b.w.collinson
« Reply #31 on: 22-October-15, 11:19:13 »
Hi
when i try the link the only thing that shows is the usb 3 driver.
when i tried the hot fix it said it was already installed
Bc
« Reply #32 on: 22-October-15, 12:00:43 »
@ b.w.collinson
Open new thread and follow >>Posting Guide<<
Issue is clearly not with LiveUpdate but somewhere in drivers. We'll try to help you.
snowsak
  • STAFF SERGEANT
« Reply #33 on: 24-October-15, 06:40:15 »
Hi
Just wanna report that on the latest version of live update MSI still havent fixed it to show the graphic card BIOS.
Mon: LG DM2752D
sohma2501
« Reply #34 on: 04-January-16, 10:56:37 »
On windows 7 go to use live update it breaks about halfway through the update then doesnt want to load period.how do I fix this ?and when I go to find the answer nothing comes up....Im using a 970A SLI Krait edition.
JLio01
  • MAJOR
« Reply #35 on: 04-January-16, 17:21:37 »
@sohma2501
What Live Update version you're currently using? Did you update BIOS or drivers and where did it stop loading?
pproctor027
« Reply #36 on: 13-January-16, 12:05:50 »
if i use latest bios update i can no longer use the bios page right just crashes if i use the really old bios its fine any help
« Reply #37 on: 13-January-16, 14:24:36 »
With this amount information there is no solution. See >>Posting Guide<<
kevin
« Reply #38 on: 23-January-16, 12:00:13 »
Tried to download the latest Win 10 x64 version of Live Update (6.1.009), and Windows blocked it as being a virus.  See attached image.
« Reply #39 on: 23-January-16, 16:18:03 »
Ok, thanks.
What link (exactly) you tried to download it from? It is surely false alert of Antivirus but better get things checked :)
gehirael
« Reply #40 on: 24-January-16, 00:54:12 »
Windows Defender is currently flagging all downloads of LiveUpdate as containing Varpes.J!plock. From the support site link http://download.msi.com/uti_exe/LiveUpdate.zip to external download links such as http://www.softpedia.com/get/System/System-Miscellaneous/MSI-Live-Update.shtml#download . The fact that different source links with different file sizes return the same virus diagnosis makes me think it's a false positive, but I'm not particularly willing to take the chance and exclude it without further information. It seems worth looking into. Wouldn't be the first company to have download links altered.
« Reply #41 on: 24-January-16, 00:56:10 »
Will try to find out if it's something wrong with links/software or just false positives.
« Reply #42 on: 24-January-16, 07:30:17 »
Other Moderator tried with Symantec-nothing found. I tried with ESET-found nothing.
Both of you used Windows defender. Seems as false positive.
Though if you are worried about it, speak with microsoft and/or MSI: >>How to contact MSI.<<
rjenkins
« Reply #43 on: 01-February-16, 04:10:21 »
Used Live update to flash my BIOS and now my BIOS is corrupt and I cannot use my PC.
Windows 10 Pro x64
MSI 970 Gaming Motherboard
AMD FX 6300 Black
16GB G-Skill RAM
Gagabyte HD4650 1GB Graphics Card
128GB Crucial SSD for OS
1TB Western Digital for Data
« Reply #44 on: 01-February-16, 04:14:54 »
Quite common issue. That's why forum users recommend Forum's flashing tool and MSI's MFlash (within BIOS).
rjenkins
« Reply #45 on: 01-February-16, 07:54:24 »
Can't get to the BIOS to do anything now. Trying to get a RMA.
Windows 10 Pro x64
AMD FX 6300 Black
16GB G-Skill RAM
stephenturns
« Reply #46 on: 02-February-16, 19:34:28 »
I have the same issue, corrupt BIOS after MSI live update.  Have you got any further in fixing yours?
« Reply #47 on: 03-February-16, 00:36:24 »
Place BIOS file (www.msi.com, download your CURRENT bios that was/is on before attempted to update) on FAT32 formatted USB stick. Disconnect all other drives (etc), clear CMOS ( >>Clear CMOS Guide<< ), plug that single stick on the back of motherboard and turn it on. If that doesn't help, speak with MSI: >>How to contact MSI.<<
tf-spectre
  • SERGEANT
« Reply #48 on: 05-February-16, 07:53:56 »
I keep getting a SoundBlaster Cinema update that Live Update 6 says it needs to download. The trouble is that the driver is already installed after going roung the houses to get it on my system thanks to the support being somewhat unorthodox. Main reason I raise this is because, despite the version it recommends to me, which is already installed, being shown, whenever it downloads, Live Update essentially tells me that I am already running the newer or better driver and stops anyway. Yet it still insists on showing it in the Live Update list regardless, something's obviously broken, but I'm not quite sure what.
« Reply #49 on: 05-February-16, 07:55:24 »
Hi
I'd suggest you contact MSI about this: >>How to contact MSI.<<
It's not really an issue in my opinion, but surely annoying thing to see update to be exactly same version as currently installed one.
Pages: [1] 2 3 ... 6   Go Up
