Pages: 1 2 [3] 4 5 6   Go Down
Author Topic: Live Update issues? See here.  (Read 94258 times)
NichromeTopic starter
Re: Live Update issues? See here.
« Reply #100 on: 31-January-17, 13:11:09 »
Might be software bug. I'd suggest you contact MSI about it: >>How to contact MSI.<<
c3str.01
  • CORPORAL
« Reply #101 on: 01-February-17, 11:09:24 »
ok i will try
byproduct
  • SERGEANT
« Reply #102 on: 17-February-17, 07:07:14 »
that support method doesn't seem to be working
bit like msi's driver & update system... crashes at will
my suggestion to anyone having these issues is, if you get a chance to get out from under this board... take it.
LoneWorg
« Reply #103 on: 21-February-17, 03:13:21 »
yes liveupdate seems its not up to date
you can use latest one from msi web for your board,
and use M-Flash to flash it
Ok - just fyi, same here :
- Using MSI Live Update 6.2.0.07, downloaded yesterday to give it a try.
- Updated my BIOS (mb = z170A gaming M5) from v1.1 to v1.A0 (big update :) ).
That went well but I was surprised to see that live update only proposed an update up to 1.A, given that I see a few other BIOS updates on MSI website for the z170A gaming M5. When I ran live update once more it said I was up to date for that bios version so it's like it does not see the latest updates that have been posted on the support site.
i7 6700k / msi Z170A gaming m5 / sli gtx980 msi twin frozr V / 32GB ddr4 G.skill ripjaws pc19200
« Reply #104 on: 21-February-17, 03:25:38 »
@LoneWorg
Can you check Chipset (if it shows Z170 or Z270) displayed under "Board Explorer"? If it is Z270, can you post screenshot please? (And create new thread then).
LoneWorg
« Reply #105 on: 21-February-17, 04:05:11 »
Ok Nichrome will do (and edit this post at the same time). But just so you know, before reading your post, I just updated my BIOS to the latest version (1.D0) using m-flash. Went well. I opened Live Update 6 to run it and see what it said about my MB BIOS version, and it states 1.D0 now (so it was able to read the version of my MB correctly despite the fact that it was not aware of this latest version).
Now, gonna check on the board explorer in the bios and take a pic.
[ps : and thanks for the username update ;) ]
[EDIT]
Done. I posted the pictures in a new thread :  https://forum-en.msi.com/index.php?topic=282359.msg1600479#msg1600479
kjhansen1995
« Reply #106 on: 27-February-17, 12:01:31 »
2 days ago while running Live Update 6 I got the Notification for my Norton that it had blocked something.
« Reply #107 on: 27-February-17, 14:56:57 »
Oh yes. Some MSI software gets, sometimes, false positives. I wouldn't worry about it. There was a time when basic calculator ( + - / * ) I did in C++ was detected as Trojan ;D
But you may contact MSI about it: >>How to contact MSI.<<
tarengrim
« Reply #108 on: 08-March-17, 23:10:52 »
Hello everyone
I recently downloaded the live Update 6 Software to my PC, in oder to update the Bios of my PH61A-P35 (B3) to the newest Version, hoping it would allow me to use my new MSI Gaming RX 480 8GB Card. Currently slotting the Card into the PC seems to prevent the System from booting. I read in some posts that updating might help.
So Live update 6 Scans my mother board and tells me Version 1.7 is the newest (updating, does not help with the RX 480),  though it seems there are newer (ME8) Versions out. My question now: Are they save to use (never did a "Manual" update), and is there a reason Live Update 6 is not offering/finding them? Oh and of course, will updating help with my Problem at all, or am I just wasting time?
Hope I posted this in the correct thread.
« Reply #109 on: 09-March-17, 00:30:19 »
Hi
Open new topic on this. LiveUpdate can't help with this flashing.
cpdowell
« Reply #110 on: 13-March-17, 07:00:26 »
I tried to update the BIOS on my Z270 Gaming M7 motherboard using Live Update and the screen went black and the system never returned. Two hours later, after trying to move the mouse and press keys to no avail, I turned off the power and it will not reboot giving a code 0d on the LED. So, Live update cannot update the BIOS on Win 10 x64 apparently???
How do I recover my system from this when I cannot get to BIOS Setup?
Thanks
« Reply #111 on: 13-March-17, 07:29:17 »
@cpdowell
https://www.msi.com/Motherboard/support/Z270-GAMING-M7.html#down-manual
Download the manual, and proceed using Flash BIOS (Page 54).
MiKe2018
« Reply #112 on: 16-March-17, 10:55:46 »
I don't know if this is glitchy but why am I getting an option to downgrade the BIOS in live update? (B150 Gaming M3)
« Reply #113 on: 16-March-17, 10:58:46 »
It is most likely out of date (database that LU6 uses to check for updates).
fokkised
« Reply #114 on: 16-March-17, 14:39:38 »
ran bios through liveupdate 6 now i have no sound. realtek sometime even detects as me plugging speakers in and then out. any way i can fix this?
bockadilla
  • CORPORAL
« Reply #115 on: 21-March-17, 00:33:39 »
Hey!
I've been having issues for a little while now with the Live Update app. There's a new update for my Intel ME Drivers (11.6.0.1036) but for some reason it won't install (or at least Live Update says it isn't installed). I've tried updating it automatically from the app and manually as well though Live Update still says there's a new update available.
Here's a screenshot:
Any idea how to fix this and install the new driver? Is there any downside to not installing the driver?
Thanks.
Motherboard: MSI Z170A GAMING PRO CARBON
GPU:   MSI GTX 970 GAMING 4G
CPU:  Intel Core i7 6700k
RAM: G.Skill Ripjaws 4 DDR4 4x4GB, 2400MHz
Storage:  ADATA Premier SP550 240GB SSD + Seagate Barracuda 3TB
PSU:  Antec EDGE 650W
OS: Windows 10 Pro 64bit
« Reply #116 on: 21-March-17, 00:48:50 »
Hi
Go to your product page ( find it at www.msi.com ), and download the driver manually.
For this you might also need to update BIOS, as version within BIOS must match the one installed in Windows.
I will continue to say: LU is not worth the risk. Good to check if there is an update, but update things manually.
psmcguire57
« Reply #117 on: 26-March-17, 21:10:48 »
#84, same issue here, Z170A M5, Win10 64 Pro.
Got the same issue here. Just updated to LU 6.2 still broken. Been broken for 6 months. Not much help from MSI so far.
bockadilla
  • CORPORAL
« Reply #118 on: 30-March-17, 05:13:22 »
Hi
Thanks for your reply. I have already tried a manual install, and I'm pretty sure I have the latest BIOS installed too but I'll have another look. I just find it odd that there's no error message or anything. It says it installed correctly but still shows as not updated. Is there somewhere in Program Files or something where I can check the version of the drivers manually?
xspanza
« Reply #119 on: 30-March-17, 09:07:28 »
Hello, I have recently built I new PC with the Gaming M3 motherboard, Everything was working fine until I used live update 6 to download and install the latest updates. Once they were finished I was asked to restart my computer, Once that was finished everything looked to be fine but I couldn't move my mouse hear anything from my headphones or type in my password, The LED's on my keyboard would turn on but once I was booted up into windows they shutoff and none of my USB devices are working. They just won't work once booted up into windows. I have tried unplugging the devices and plugging them back in but they still wont work. I really don't reinstall windows just because of some USB updates.
« Reply #120 on: 30-March-17, 09:16:31 »
You could try booting into safe mode, and removing all drivers that were installed/updated by LU6. Then install those manually, downloading from product page found at www.msi.com
nutterlover258
« Reply #121 on: 31-March-17, 07:48:34 »
just ran the very latest bios update and now the PC will not boot at all mmm tried taking out the bois battery and shorting out the pins to reset the bios and nothing, the
machine will not boot, F**K Sake also now i find out that this chip does not support 4 sticks of 8GB Ram at 2666Mhz only 2 16GB total and if you want 32GB its 2 x 16GB sticks only. but that is the least of my issues now as this machine will not freaking boot at all, why did MSI and AMD release these products in this state, If this was a car it would not be allowed on the road.
  • 微星科技
« Reply #122 on: 31-March-17, 08:25:49 »
What has it to do with Live Update? Did you use Live Update?
Windows 10 Pro
MSI MAG BUNKER Case
xspanza
« Reply #123 on: 31-March-17, 16:10:37 »
OK, So I have managed to get into windows by going into windows 7 installation mode. So I could use my keyboard/mouse but once in razer synapse it doesn't show my product or in CUE. I tried going in windows Safe Mode (Does not Work) :( I tried reinstalling drivers for the mouse and keyboard it didnt help, Looks like anything that is using USB is not working in normal windows.. I currently have all MSI drivers installed except the optional Google ones. In summary USB devices start working only when in WIndows installation mode but the drivers for these USB devices don't recognise them (Razer Synapse Corsair Drivers). I would like any suggestion to help me, Thanks :) if this is the wrong place to post this please direct me to where I could find help.
  • 微星科技
« Reply #124 on: 31-March-17, 16:39:03 »
Open a new thread in Gaming Motherboards section: https://forum-en.msi.com/index.php?board=122.0
Windows 10 Pro
MSI MAG BUNKER Case
simonmarr85
« Reply #125 on: 08-April-17, 18:16:12 »
Hello Everyone,
Was wondering if anyone else was seeing this. Since the latest version of live update 6, my installation of Intel wifi Drivers (*version 19.20.0000.5007) seams to just not want to install. It downloads successfully, the prompt changes to "install Intel WIFI Drivers now ... Please wait" and then nothing. I left it in this state for 8 hours, came back and the prompt was still please wait. I force the program to close, restart the PC, run another MSI live update scan, and its still listed as requiring an update.
Many thanks in advance for any assistance.
MSI Z170I Gaming Pro AC
MSI Geforce GTX 1070
Windows 10 64 Bit
Intel i7-7700K
Nidhoggr
  • LIEUTENANT COLONEL
« Reply #126 on: 08-April-17, 18:49:10 »
Does the WLAN work? If so, then I wouldn't worry about it. Live Update is buggy. The motherboard's support website still has a April 2015 driver listed (18.40.0000.4009) as newest.
"If it ain't broke, don't fix it"
danielclegg87
« Reply #127 on: 10-April-17, 08:24:37 »
My Liveupdate keeps showing AMD CHIPSET Current version (9.0.000.8) Online Version (16.50.2601)
I have downloaded the drivers from the site and from live update and installed but still shows that Version 9 is installed.
Please help
  • T9246ED
  • Administrator
« Reply #128 on: 10-April-17, 08:56:09 »
@danielclegg87
what mainboard you have?
danielclegg87
« Reply #129 on: 10-April-17, 09:04:11 »
@danielclegg87 what mainboard you have?
Hi, i have the B350 TOMAHAWK
  • T9246ED
  • Administrator
« Reply #130 on: 10-April-17, 09:08:26 »
here is a link to the latest chipset drivers:
http://download.msi.com/dvr_exe/amd_chipset_drivers_am4.zip
jrmatics
« Reply #131 on: 17-April-17, 14:43:26 »
i give up... been trying since 4/9 to update, install, uninstall,.... some install partially, some not at all... first time in a million years i have this problem with a motherboard on windows 10
jacki-baldes
« Reply #132 on: 27-April-17, 13:27:53 »
LiveUpdate tells me my Bios is up to date, but i got version H.10 on my tomahawk b350 arctic.
MSI Support Page tells me H.1 was release more than 1 month ago and 1.34 is the newest version.
« Reply #133 on: 27-April-17, 15:39:14 »
1.34 is a BETA version which LiveUpdate will never show.
casiernick
  • CORPORAL
« Reply #134 on: 29-April-17, 10:50:07 »
Since a week I'm getting this notification when Live Update asks to scan for updates.
I'm connected to the internet and I've reinstalled the software. But there seems to be another issue. Maybe with the server?
Does someone has an idea?
(click here if the image does not work)
  • T9246ED
  • Administrator
« Reply #135 on: 29-April-17, 13:07:41 »
uninstall it
and you can get latest drivers/BIOS from msi web page for your board
casiernick
  • CORPORAL
« Reply #136 on: 30-April-17, 05:22:45 »
I'm to lazy to check manually every now and then...
Isn't it the whole point of the software that it does that for you?
Nidhoggr
« Reply #137 on: 30-April-17, 11:57:40 »
For the most part you don't really need to check that often. Its sort of like BIOS updates. While they may fix issues, if you don't have issues it may be best not to update.
The only thing that you should update frequently is GPU drivers.
MSI Live Update is a great in theory, but unfortunately, it fails to deliver and actually can cause problems (especially Windows based BIOS updating).
casiernick
  • CORPORAL
« Reply #138 on: 01-May-17, 05:14:25 »
From a point of view of a security professional this feels just wrong.
Updates are often to fix security breaches and not updating is like leaving the door open.
« Reply #139 on: 01-May-17, 06:55:37 »
It's not like outdated LED software will get hackers to your PC.. :rolleyes:
And from a point of view of a user, "if it ain't broken, don't fix it"
If you still cannot use it, but really need it, please contact MSI: >>How to contact MSI.<<
rae_mes
« Reply #140 on: 07-May-17, 05:04:05 »
Hello all.
So I have this: GIGABYTE GA-970A-D3P -- AMD 970
and MSI Live 6 came installed on my PC. I have only have my PC for about a year. Never really noticed when Live Update stopped working, but every time I turn my computer on it says "The platform does not support this application."
Is there anything I can do about this to actually get Live working? Should I even bother to use it?? I have tried looking through the Support Center and can only get so far.
Anything helps. Thanks!
Nidhoggr
« Reply #141 on: 07-May-17, 11:23:42 »
Hello all.
and MSI Live 6 came installed on my PC. I have only have my PC for about a year. Never really noticed when Live Update stopped working, but every time I turn my computer on it says "The platform does not support this application." [ ERROR: SPECIFIED ATTACHMENT MISSING ]
Is there anything I can do about this to actually get Live working? Should I even bother to use it?? I have tried looking through the Support Center and can only get so far. [ ERROR: SPECIFIED ATTACHMENT MISSING ]
MSI LiveUpdate is for MSI products only. I don't know why it was installed on a computer without a MSI motherboard, but it serves no purpose on the computer. Find updates to your motherboard on the Gigabyte support website.
londonsmee
  • CORPORAL
« Reply #142 on: 10-May-17, 08:01:46 »
Issue I have with live update 6
It didn't inform me there was a Bios update for my x370 motherboard.
badboy2k
« Reply #143 on: 10-May-17, 08:05:27 »
last time i looked at Live Update 6 they had moved the BIOS update to a separate tab in the software near the end where the <> is to scroll through the options! did it not see it there or did it not see it at all?
Cooler: corsair H100 cooler
yuvathejaer
  • SERGEANT
« Reply #144 on: 07-June-17, 11:43:16 »
Realtek sound manager missing after updating through live update. Also problems with Nahimic drivers
naki68er
« Reply #145 on: 09-June-17, 13:02:48 »
Just did update to MSI live update 6.2.0.19 today and it was fine, when i started to download MSI gaming APP, it crash my PC. The MSI gaming APP was running my CPU @ 100% and would not stop until I uninstalled it. Once i Uninstall the MSI Gaming APP my PC went right back down to 3% CPU usage. plz fix the Gaming APP thank you.
I7 5820k  Over Clock 4.1GHZ
MIS X99A Gaming pro carbon ( MS-7A20 )
Motherboard BIOS version 1.30
operating system/ Windows 10 64-bit
Geforce GTX 1080TI
Graphics card BIOS version/ 86.02.39.00.01
naki68er
« Reply #146 on: 09-June-17, 13:06:13 »
Just did update to MSI live update 6.2.0.19 today and it was fine, when i started to download MSI gaming APP, it crash my PC. The MSI gaming APP was running my CPU @ 100% and would not stop until I uninstalled it. Once i Uninstall the MSI Gaming APP my PC went right back down to 3% CPU usage. plz fix the Gaming APP thank you. I7 5820k Over Clock 4.1GHZ MIS X99A Gaming pro carbon ( MS-7A20 ) Motherboard BIOS version 1.30 operating system/ Windows 10 64-bit Geforce GTX 1080TI Graphics card BIOS version/ 86.02.39.00.01
msantos21
« Reply #147 on: 09-June-17, 18:24:44 »
I am having the same issue as naki68er, updated to the new gaming app and my computer became super sluggish. CPU usage went up to 97%. makes computer horrible to use. Once I went to task manager and ended task on gaming app cpu usage went down to 3% and my PC went back to normal.
vidalsh68
  • SERGEANT
« Reply #148 on: 09-June-17, 18:43:05 »
Same crash here under A99 XGaming Pro Carbon...
Last Live Update and Gaming App brokes system...
MSI x299 MEG CREATION, i9 7940x, MSI GTX 1080 Gaming X, Corsair HX1000i, NZXT Kraken x62 x 2 + G1, 970 evo, crucial P1, WD Blue, BPX, 32GB Optane, Corsair Scimitar, Newskill Hanshi, Phanteks Enthoo Luxe Tempered, Focusrite 18i20. TASCAM vls3 x 5. ACER GN27HLB nvidia 3Dvision 144hz.
jan
« Reply #149 on: 14-June-17, 02:36:02 »
Same here. Tried to uninstall everything and clean - that did not help. Went back to previous version of gaming app.
Pages: 1 2 [3] 4 5 6   Go Up
