Pages: 1 ... 3 4 [5] 6 7   Go Down
Author Topic: Live Update issues? See here.  (Read 109063 times)
aluisious81
Re: Live Update issues? See here.
« Reply #200 on: 24-May-18, 22:58:37 »
Not your service. I have called MSI and got a guy who said he would "look into it" and never got back to me (not surprised). The online tickets are totally worthless, that's where I found people who
1) Didn't have any idea what the RGB stuff does. They haven't even read the product manual.
2) Can't do an RMA cross ship. Yeah, I'll pull my motherboard, spend 6-10 weeks gardening at night, and earnestly hope mine is repaired and sent back. What a load that is.
3) Just ignore responses to tickets.
I'm going back to EVGA next time, because they know how to provide service. Whiz bang features are worth nothing when they don't work and aren't supported.
jw1250agl
« Reply #201 on: 20-June-18, 17:03:14 »
I have the current version of Live Update 6. It isn't runny on Windows startup because it would occupy my cpu way too much and take forever to load up. So, I manually check every now and then. However, yesterday I tried start it up and it never loaded. I allowed it to spin up for over 10 mins and all it did was occupy my cpu well over 60% and never opened up. I looked for an update and installed it. I was then able to open it and install a few updates. Today, I'm back to spinning and doing nothing but occupying my cpu. Not sure what's wrong with this app but just not working for some reason.
NovaViper
  • SERGEANT
« Reply #202 on: 30-July-18, 12:03:57 »
For some strange reason, I updated my AMD Chipset drivers to 18.8, but LiveUpdate still registers it as 17.40.2815.1005. It also doesn't  pick up the v7.40.2815.1010 from MSI's website that I had installed prior to intalling 18.8. I've reinstalled LiveUpdate many times and even reinstalled the drivers, yet it still says I haven't updated.
wicaksono_1993
« Reply #203 on: 18-August-18, 00:42:09 »
is update bios using live update reliable?
NichromeTopic starter
« Reply #204 on: 18-August-18, 06:20:43 »
Not at all. BIOS shouldn't be updated via Windows. Only through DOS or MFlash.
debmsi
« Reply #205 on: 10-October-18, 13:34:19 »
Hi
I have an MSI z370A Pro mobo, W10.
 Liveupdate 6.2.0.23 (from the MoBo DVD), installed, launched and perfom a correct  driver updates; It find also a new version of LiveUpdate: 6.2.0.44, so I update It with the newer version: all seems fine, but when I start It nothing is done, No errors in the WEV, the MSI Live Update Service is running... and if I uninstall  LiveUpdate 6.2.0.44 and back to Liveupdate 6.2.0.23 it work correctly: run, scan, and install.
Other with same problem? Any idea?
Tnk's
D.
nurbles62
« Reply #206 on: 13-November-18, 16:11:41 »
I currently have version 6.2.0.36.  When originally installed it seemed to work OK.  After a while, I stopped it from starting at boot because it seemed to be using more CPU than I wanted, but manual scans still worked.  I haven't scanned for a while and when I tried yesterday, nothing happens.  The screens look strange/wrong and very little works at all.  Kinda sad, really.
perfectb
« Reply #207 on: 22-November-18, 12:12:20 »
Is the expected behavior of the 'Registration' tab that your account does not remain logged in?  Seems like entering the login credentials once would allow me to stay logged into the application.
Perhaps this is a result of the fact that I update LiveUpdate itself whenever new versions are available?  I notice some other apps (Gaming App in particular, which controls my motherboard's lighting) resets settings to default upon every update.  This is not terribly inconvenient, though I do have to set my lighting preferences again and toggle the option to load Gaming App on Windows startup each time.  I don't use many of the other MSI apps so it's hard to know if the behavior is the same across all of them, but it seems a bit careless to burn down and blank the user configuration with each application update.  Again, it's not a huge inconvenience but I shouldn't have to manually reenter my settings into an already configured application every time there's a new stable build release...these aren't even major point releases of the software!
Vicky
« Reply #208 on: 22-November-18, 13:35:53 »
Hello!
I updated my MSI Live Update to version 6.2.0.47 two days ago and since then I am not able to login in the registration page with my user name and password.
The Internet connection on my PC is working fine but I keep getting a specific alert after several seconds.
The Live Update is able to scan and install updates normally and the GeForce Experience is logging in without any issues.
I followed very basic troubleshooting, such as restarting the PC or even turning off the Windows Firewall.
It seems the issue is only on the Registration page as everything else is working fine and I'm not sure if this is something I should worry or not.
Any advise is appreciated. Thank you in advance.
I am attaching the screen-shot of the alert.
Board: Z170A PC MATE (MS-7971)
BIOS:  A.A0
VGA:   MSI NVIDIA GeForce GTX 950 2GD5 OCV1
PSU:  Corsair RM Series RM650 650 Watt 80 PLUS Gold Certified Fully Modular PSU
CPU:  Intel CPU Core i5 6500 (1151/3.2 GHz/6 MB)
MEM:2x4GB, Crucial 4GB DDR4-2400 UDIMM CT4G4DFS824A
HDD/SSD: SanDisk SDSSDHII-240G-G25 Ultra II 240GB, Western Digital Blue 3.5" 1TB (7200rpm)
COOLER: N/A
Keyboard:Microsoft Sculpt Comfort Keyboard,  USB
Mouse:Microsoft Wireless Mouse 900,  USB
OC:  None
OS: Windows 7 64bit
Saabjock
  • SERGEANT
« Reply #209 on: 07-December-18, 06:28:57 »
Since when did Google Chrome become an MSI product?
MSI live update does it's scan but will not proceed without me installing Google Chrome.
I guess I'll be doing manual downloads from now on.
I have no plans to install Google Chrome on my computer any time soon.
I like my Opera browser.
« Reply #210 on: 07-December-18, 07:17:03 »
This kind of question should be asked directly to MSI, not to us (forum users).
>>How to contact MSI.<<
Registration error should be fixed with newer version of LiveUpdate.
jrouss28
« Reply #211 on: 08-December-18, 10:03:24 »
Anyone else getting this message?
I have a MEG ACE running live update version 6.2.0.39 there is an update to version 6.2.0.47. Every time i restart the PC it prompts me for the install I run it and get the error below:
"This application did not support this motherboard"
Any thoughts?
Thanks
Warfarin
« Reply #212 on: 26-February-19, 16:22:19 »
E-setup does not appear when I try to update the  BIOS
« Reply #213 on: 26-February-19, 16:39:09 »
What board is it?
Can you try MFlash instead?
Warfarin
« Reply #214 on: 26-February-19, 16:42:51 »
What board is it?
this is z370 kriat.
I dont have USB thumb :cry:
« Reply #215 on: 26-February-19, 17:22:00 »
Well, LiveUpdate itself isn't too stable to update BIOS. I'd strongly suggest getting cheapest 4GB USB stick and update it through MFlash.
robertcohen33
« Reply #216 on: 07-April-19, 11:53:17 »
Funny because when i try to scan for the new Bios V1.5 it never shows up.  But if I go to MSI's the new bios is listed there.  Anyone else have that problem?
« Reply #217 on: 07-April-19, 12:58:42 »
It's because LiveUpdate database isn't being updated.
wvkreg
« Reply #218 on: 19-April-19, 06:48:14 »
Liveupdate issues here. I got a MSI X470 Pro Carbon Gaming AC. Liveupdate version: 6.2.0.56.
The app keeps stating I need to update Killer LAN software and AMD Chipset Drivers. I already have the latest version installed. So why does it keep stating this?
fcoda.96
« Reply #219 on: 27-April-19, 11:25:48 »
Hi, I'm trying to install Live Update 6.2.0.56 but after install the app just won't open. Not even an error dialog. I don't know what to do...
I'm on Windows 10 Home 1809, my motherboard is a H370 Gaming Pro Carbon
rbleroy91
  • RBL_FR
« Reply #220 on: 27-April-19, 13:20:45 »
1/ Install >>Intel Chipset Driver V10.1.17861.8101 (2019-03-06)<< then >>Intel Management Engine Driver V1846.12.0.1177 (2019-03-06)<<. If you have an antivirus, disable it before to run Liveupdate.
2/ What is your bios version?
3/ This being said, personally, I do not recommend use of Liveupdate because of risk with bios updates. You can find all you need >>Here<<.
Hoping it shall help,
:hat tip:
fcoda.96
« Reply #221 on: 29-April-19, 12:58:56 »
I did everything as said, my bios is v1.6 (7B16v16)
Just didn't work, same behavior
Thanks anyway
mhmyasser
« Reply #222 on: 11-June-19, 17:48:39 »
Live update issue with intel chipset drivers that no 1 from the support team can fix " FIXED FINALLY"
that was the problem
a new version detected and i accept to update to it
live update keep on " like the picture"
and it doesn't show any message
after about a month suffering with the support team
i managed to reset my windows 10  after updating it to V1903
and start with a clean version of windows
and that was the way i could fix this issue
12hillangus
« Reply #223 on: 18-June-19, 17:01:13 »
Hi, I dont think this is relevant but can someone please help me, i need to update my bios to be able to use the i7 7700k currently on an i5-6500 trying to update the bios but it comes up with an error saying please copy bios to root key folder, someone please help ive got the file in compressed uncompressed and the two files individualy and dont know what to do i have a MSI B250M Gaming pro micro ATX motherboard.
Help,
Thankyou
« Reply #224 on: 18-June-19, 19:17:26 »
Help,
Thankyou
Please open own topic on this issue.
oneclasact
« Reply #225 on: 12-July-19, 20:07:38 »
I have no error numbers, live update worked fine, however after updating my BIOS from A0.0  to A0.5, I could not get my system to boot up at all. It could not find the operating system, which is on my SSD Drive. MB - MPG Z390 GAMING EDGE AC, W/ 2 HD,  and 1 M.2 SSD, Windows 10 64 bit sys. I called support but got absolutely no usable input or help at all, I felt like i was interrupting their nap. When i went into the BIOS, thru DEL. my storage showed SATA 1- A HARD DRIVE, SATA 2 - EMPTY, SATA 3 - HARD DRIVE, SATA 4 - DVD,  and SATA 5 THRU 8 EMPTY, M2-1 MY SSD DRIVE , AND M2-2 EMPTY.  This is the configuration of my set up. The system could not find my SSD DRIVE  to boot from. After several hours of frustration and no help at all. I finally reset the BIOS  to default. When the screen came up it listed my components as follows , SATA 1 - A HARD DRIVE, SATA 2 - MY SSD DRIVE , SATA 3 -MY OTHER HARD DRIVE, SATA 4 -MY DVD , I found it strange that thru this it showed my SSD drive at SATA 2, I restarted the system. This time I hit F11 (boot menu) and was able to select my SSD drive (at SATA 2), and was able to get my system back up. I set up the SATA drives per the layout in the installation manual that came with my system. Don't know how to get the BIOS to realize my SSD drive is identified in SATA 2 for boot purposes. Any help would be appreciated.
  • 微星科技
« Reply #226 on: 13-July-19, 05:51:06 »
That has nothing to do with Live Update issues. Open your own thread.
AMD Ryzen 9 3900X
Windows 10 Pro
benrith
« Reply #227 on: 14-July-19, 02:46:26 »
When is v19 coming on for b450 tomahawk as lots of people are having issues with upgrading bios to work with ryzen 5 3000...
  • 微星科技
« Reply #228 on: 14-July-19, 05:11:44 »
That is obviously not a Live Update problem and thus off-topic, don't hijack other topics please. Besides nobody here knows when or if a new bios is released. You will have to contact MSI: >>How to contact MSI.<<
AMD Ryzen 9 3900X
Windows 10 Pro
andrewh
« Reply #229 on: 18-July-19, 16:54:15 »
When I did 4 updates today via Live Update 6, each one on windows 10 did a prompt to allow "Msi LiveCloser" to be allowed. It says it is signed by MSI. Is this expected?
EDIT: Just to add a little more detail. This is MSI Live Update 6 with the X370 XPOWER GAMING TITANIUM (MS-7A31). I was doing 4x updates which I believe were AMD chipset driver, intel network driver, gaming center, and xboost. I clicked all 4 then "Total installer" button. I'm forgetting if it was before or after install happened, but each one had windows 10 VAC prompt for "MSI LiveCloser"
bedirhan.ari87
« Reply #230 on: 22-July-19, 11:36:34 »
Hello. I have bought a new PC. I have open the bıos first, later ı get the XMP profile 2 (2133 MHz to 2933 MHz), later my bıos freeze and dont responds. What ı need to do? I dont know much and cant send photo because of 600(?? What s 600 kb man) KB limit.
Only it writes MSI Click Bios 5, CPU speed, ddr speed, A-XMP and Boot priority. Thanks.
And sorry for writing here, please dont ban and help me. That s why I dont know but I cant create a new topic.
  • 微星科技
« Reply #231 on: 22-July-19, 12:39:47 »
It is not hard to create a new topic. Simply click on "New topic" in the correct section. Obviously your issue will not be discussed here.
AMD Ryzen 9 3900X
Windows 10 Pro
alexlll
« Reply #232 on: 24-July-19, 01:51:15 »
I install the driver, reboot the system and I am again offered to install the same driver.
rbleroy91
  • RBL_FR
« Reply #233 on: 24-July-19, 02:00:10 »
To verify that it is not related to an unsuccessfull installation with Liveupdate, install the driver yourself: >>AMD Chipset Driver V19.10.16<<.
Have a good day,
:hat tip:
alexlll
« Reply #234 on: 24-July-19, 03:21:11 »
I installed the driver for your link but nothing has changed. Live update 6 again tells me that I have an old driver.
rbleroy91
  • RBL_FR
« Reply #235 on: 24-July-19, 06:50:34 »
:undecided:
What news if you install the last version from AMD: >>AMD Chipset Drivers (7/7/2019)<<?
:hat tip:
alexlll
« Reply #236 on: 24-July-19, 07:26:17 »
I tried. All the same. But the AMD PCI driver in Device Manager has been updated to a newer one.
andrewh
« Reply #237 on: 25-July-19, 07:54:12 »
Anyone know or is able to contact MSI? I just want to verify MSI LiveCloser is a valid signed program from MSI.
Thanks
rbleroy91
  • RBL_FR
« Reply #238 on: 25-July-19, 11:45:42 »
>>How to contact MSI<<
:hat tip:
nadeau_88
« Reply #239 on: 01-August-19, 11:33:31 »
Good Day, I'm using dragon center for my meg 390 god like and when i try to uptdate the bios it sey i dont have internet connection which is fals anyone ever ran into this issue ?
« Reply #240 on: 01-August-19, 16:50:48 »
Check firewall, and antivirus settings. Might be blocking it.
Maheshvaran_Padiachi
« Reply #241 on: 29-September-19, 11:40:46 »
Hi
Please assist
I cannot download anything from the MSI downloads page for my product or other products.
The message returned is always a web page with the following line of text: File not found."
I have been trying this link among others: http://download.msi.com/uti_exe/mb/Dragon_Center.zip
I have used multiple web browsers (Internet Explorer, Chrome, Edge).
I have used different PC's (Home PC, Laptop)
I have used different connections (Cellular LTE, Home WiFi Fibre)
I have also tried the Live Update on MSI Dragon Centre.
Regards
Mahesh
Board: MPG Z390 GAMING PRO CARBON AC
BIOS:  E7B17IMS.150
VGA:   MSI GTX 970
PSU:  Cooler Master 850w
CPU:  Intel® Core™ i9-9900K Processor
MEM: 2x8GB Corsair
HDD/SSD: 1x Coarsair 1TB NVMe SSD
COOLER: Cooler Master Master Air MA410m
Keyboard: Coarsair
Mouse: Coarsair
OC:  None
OS: Windows 10 64bit Professional
  • 微星科技
« Reply #242 on: 29-September-19, 11:49:10 »
That has nothing to do with this thread that only covers Live Update issues. Open your own thread please.
AMD Ryzen 9 3900X
Windows 10 Pro
antjac72
« Reply #243 on: 06-November-19, 05:50:13 »
Recently LiveUpdate (version 6.2) has stopped working, any interaction ends up with "No internet connection" claim - which is obviously false.
I did not change any AV/firewall settings. Did something broke after the last Windows (W10 64 bits here) update ?
mepsfi
« Reply #244 on: 06-November-19, 19:49:29 »
Im experiencing the same thing here...
Recently LiveUpdate (version 6.2.0.58) has stopped working, any interaction ends up with "No internet connection" claim - which is obviously false.
msi
« Reply #245 on: 07-November-19, 06:28:27 »
Same problem here (and no all internet on all applications work fine, and yes I did reinstall the application)
BUTTERS
  • CORPORAL
« Reply #246 on: 07-November-19, 12:27:40 »
LIVE UPDATE 6 (VER. 6.2) IS SHOWING NO INTERNET CONNECTION EVEN AFTER I HAVE WIFI ON AND OTHER APPS WORKING FINE. AND YES ALREADY REINTALLED 2 TIMES BUT FACING SAME ISSUE.
Roxy
« Reply #247 on: 07-November-19, 14:49:02 »
Hi,Sadly ,I have the same problem with the last version of MSI Live Update which appeared for no reason like that without warning ' No internet connection ':confused2:
                                                -- :wave: But i have a temporary solution for you,during waiting a fix about this problem :juggle: --
I advise you to replace it temporarily by his brother, called (Click for download it directly>)MSI DRAGON CENTER 1.0.0.30 which does the same thing about drivers/software except for the bios
*You need to know:If you use MSI DRAGON CENTER > You had to uninstall MSI Live Update (Both Can't Running on the same Config)or windows will do uninstall it automatically
[Maybe is randomly , Maybe nope but if you have this situation >
At my first use of dragon center, i get an update for MDC on the list 'Dragon Center 1.0.0.60' & When i install it , the software refused to work again even on Running by Adminsettings or after an OS Restart
(Dont panic: you can fix it by uninstall and reinstall MSC ,>no more problems after,Tested today > 0k)
david.veit
« Reply #248 on: 08-November-19, 03:34:57 »
Dear MSI Support,
I used Live Update 6 today to update the BIOS of my MPG x570 Gaming Pro Carbon WIFI. I Installed Live Update 6 and it showed me that I had BIOS Version 1.0. The newest Version 1.4 was available for download. I checked it in the software and pressed install. It downloaded the software and after the download was finished it prompted "Do you want to restart PC in flash mode." or something like this. I clicked yes and the PC shut down. Now the PC is not booting anymore. It is not even showing anything on the monitor. I'm also not able to enter the bios because of this. I tried connecting a different monitor via DVI instead of HDMI.
After about 30 minutes I tried pressing the reset and power button which did not do anything. Then I tried holding the power button for longer which shut down the PC, but on the next start it would still just show a black screen and don't do anything.
How should I proceed with this issue?
EDIT: My hardware specs
CPU: AMD Ryzen 5 3600x
GPU: AMD Radeon RX 590
EDIT: By reseting the CMOS I was able to boot again. I will now try do flash the BIOS manually.
Also I forgot to mention that I want to update the BIOS because I have problems using 4 RAM modules.
Best regards,
David
rbleroy91
  • RBL_FR
« Reply #249 on: 08-November-19, 04:08:20 »
Dear MSI Support,
Here, we are only end users, not MSI Support
:users:
Contact directly MSI Support: >>How to contact MSI<<.
In waiting, their eanswer, my advice is to open a new topic about your problem. Forum users will then help you to diagnose and, I hope, to resolve.
Have a good day,
:hat tip:
Pages: 1 ... 3 4 [5] 6 7   Go Up
