Author Topic: Extremely SLOOOOOW boot. HELP!  (Read 795 times)
maxoman10Topic starter
« on: 18-June-15, 15:23:02 »
This just started happening yesterday. Whenever I boot up my computer, I see the MSI splash screen, and I hear a beep. The beep normally lasts one second, but this beep lasted about ten seconds. The MSI screen stays there for about 30 seconds, then I get the driver loading screen. It stays there for about a minute. Then the screen goes black for 20 seconds. Then the windows logo shows, and the computer boots up normally and is fast. This just concerns me, as this is only at the hardware level. Does anyone know what's happening?
Nichrome
Re: Extremely SLOOOOOW boot. HELP!
« Reply #1 on: 18-June-15, 16:35:47 »
https://valid.x86.fr/mbld36
gijohny17
  • SERGEANT
« Reply #2 on: 19-June-15, 08:53:49 »
Something in your PC is not fitted right. Look at RAM.GPU or the cables. At my old PC that was my problem when something similar happened.
MOBO: X99S Gaming 7
PSU: Corsair RM850x (Updated 26/07/2016)
CPU: i7 5820k
CPU Cooler: Corsair H100i
RAM: G.Skill 4x4GB 2666Mhz
SSD: Crucial MX100 512GB
HDD: WD Caviar Black 1TB
GPU: MSI GTX 980 Gaming V
darkhawk
« Reply #3 on: 19-June-15, 22:43:53 »
I would post more information. What motherboard do you have?
System 3MSI Z390 GodlikeIntel i9 9900K32GB DDR4 @ 3600 MHz MSI RTX 2070 Gaming Z 8GB
