Author Topic: Live Update 6 error message  (Read 2685 times)
bob27nliTopic starter
« on: 19-June-15, 05:28:41 »
Been using Live Update6 without any errors until recently.  Trying to update to latest version I get the following message:
C:\Program Files (x86)\MSI\Live Update\unins000.msg is missing.  Please correct the problem or obtain a new copy of the program.
Here are snapshots of the two errors I am receiving.
I cannot uninstall the old copy or install a new copy because I get the same message.
I know most of you will say not to use Live Update, but I've been using it without any errors until recently.  Any way to repair it?
  • T9246ED, Бивша комета
  • Administrator
Re: Live Update 6 error message
« Reply #1 on: 19-June-15, 05:34:16 »
you can try this uninstaller to complete remove any entries:
http://download.cnet.com/IObit-Uninstaller/3000-2096_4-75161625.html
before resintall it
« Reply #2 on: 19-June-15, 09:01:53 »
getting the same error message when using that program to uninstall
  • Administrator
« Reply #3 on: 19-June-15, 09:25:13 »
after uninstall go and delete the live update folder manually before reinstall it
